Subject: |
Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection |
"Wang, Andrew via Tech-talk" <[email protected]> |
To: |
EPICS tech-talk <[email protected]> |
Date: |
Fri, 9 Dec 2022 02:21:44 +0000 |
Hi all,
Basically, I was wondering if there is a better way to know if communication to an instrument
has been lost. I understand that this can be done either by simplying looking at the IOC shell for disconnection errors or checking if the STAT field is set to COMM.
I was wondering if there is another method of determining if the instrument is still connected or not besides the two methods described above. Additionally, I would like to have a record called "is_instrument_connected", that holds a value like 1 to indicate
the instrument is connected and a 0 if it is not. I feel like there is a better way than me trying to use a calcout record and check if any record has its STAT field set to COMM. Like, is it possible to monitor for connection status without needing to process
a record whose device type is StreamDevice and check its STAT field?
Thank you,
Andy
- Re: Ways to know if instrument connected via TCP/IP through StreamDevice has lost connection Mark Rivers via Tech-talk
Re: Using one substitution file for multiple template files Wang, Andrew via Tech-talk
<2022>
2025
2026
Re: [EXTERNAL] Phoebus Rules for Tooltips Kasemir, Kay via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
