Hello Mark, I have faced a similar problem, however in my case I am using a Tibbo device, and the TCP connection was being closed due to inactivity. I suspect it is a VSPDL driver issue, and did not have the bandwidth to get into it.Ultimately I programmed the controller to operate on Modbus TCP and worked around the problem. I feel in your case looking into the Moxa driver would help.
Regards, Kuldeep
I have an Allen-Bradley SLC5/03 PLC. I use an RS-232 connection from a Windows PC to the PLC for programming it. This works fine when I connect to a real serial port on the PC. However, that is inconvenient because that is over 50 meters from the PC, and I have 2 PLCs and only 1 serial port, so I need an A/B switch. I would like to use a multi-port Moxa terminal server instead. I have installed the Moxa software on the PC that makes COM2 appear as a Windows COM port, using one of the serial ports on the terminal server.
I then try to configure the Allen-Bradley RSLinux software to use COM2 with their DF1 protocol using the "Auto-Configure" option. This "almost" works. If I disconnect the serial cable from the Moxa to the PLC and run Auto-Configure it fails to find the matching baud rate and parity. This is expected of course, since it is not communicating at all. If I connect the cable it does correctly find the baud rate and parity, so it is communicating OK. However it then reports "Failed to dine error checking mode!". There are 2 choices for error checking, BCC, and CRC. Both fail.
I don't understand this, since I think the BCC and CRC are both done in software on the PC end. If the Moxa is providing sufficient emulation of a COM port to allow the baud rate and parity to be configured OK, why it is failing to configure the error checking?
Any ideas are welcome!
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20230216/5e756718/attachment.html>
Subject: Digest Footer
Tech-talk mailing list Tech-talk at aps.anl.gov
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
End of Tech-talk Digest, Vol 17, Issue 90
Moxa Terminal Server question Koennecke Mark via Tech-talk
RE: Moxa Terminal Server question Mark Rivers via Tech-talk
<2023>
node-epics-ca: A Channel Access client for Node.js (FFI implementation) Wang, Lin via Tech-talk
<2023>
ANJ, 20 Feb 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
