1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: pasynOctetSyncIO error reading image status=4
To: "Sintschuk, Michael" <[email protected]>, tech-talk <[email protected]>
Date: Thu, 2 Mar 2023 17:43:21 +0000
Hi Michael,
The message is printed here:
https://github.com/areaDetector/ADPSL/blob/b1924604516eca006cab8a63b7c9fc094df35fe2/pslApp/src/PSL.cpp#L589
The status is the return from pasynOctetSyncIO->read in this line:
https://github.com/areaDetector/ADPSL/blob/b1924604516eca006cab8a63b7c9fc094df35fe2/pslApp/src/PSL.cpp#L585
pasynOctetSyncIO->read is here, and it just returns the status from pasynOctet->read().
https://github.com/epics-modules/asyn/blob/3434727d5a1ba090bb423b4c7395fdb77a57eebd/asyn/interfaces/asynOctetSyncIO.c#L218
The asynStatus enums are defined here:
https://github.com/epics-modules/asyn/blob/3434727d5a1ba090bb423b4c7395fdb77a57eebd/asyn/asynDriver/asynDriver.h#L48
status=4 thus means asynDisconnected.  That seems to indicated that the socket between the IOC and the PSL server has disconnected.
You can turn on asynTraceIODriver on that socket and see exactly what is being sent and received.  You can uncomment and change these lines in your st.cmd:
asynSetTraceIOMask("PSLServer",0,ESCAPE)
asynSetTraceMask("PSLServer",0,ERROR|DRIVER)
asynSetTraceFile("PSLServer", 0, "PSLServer.out")
The last line will send the output to a file, which may be more convenient.  You may also need to add this line:
asynSetTraceIOTruncateSize(“PSLServer”, 0, 10000000) so that you do not limit the output to just 80 bytes.
From: Tech-talk <[email protected]> On Behalf Of Sintschuk, Michael via Tech-talk
Sent: Thursday, March 2, 2023 11:20 AM
To: tech-talk <[email protected]>
Subject: pasynOctetSyncIO error reading image status=4
Hi all,
like announced in this tech-talk:
https://epics.anl.gov/tech-talk/2021/msg02173.php
I’m now trying to setup a FDS camera from Photonic Science with the ADPSL module. After adding some slightly changes to the Keywords that are send to the PSViewer-server or received from it, I can communicate with the camera without any IOC-crashes. I forked the ADPSL-module here:
https://github.com/MichaS-git/ADPSL
However, from time to time I receive some deprecated images (some lines show ~50k counts, although it is a darkfield image and the rest image has ~200 counts) and the IOC shows this error code:
2023/03/02 16:51:43.266 PSL:getImage: error reading image, status=4, dataLen=12117504, nCopied=12117503, maxRead=1, nRead=1453
In the PSViewer (the vendor software that runs parallel) the image appears fine. It seems to appear random but I have the feeling that it happens more often when I increase the exposure time to higher than ~2s. Can anyone say what that error with status=4 actually means?
Here is my complete IOC-start with the errors:
#!../../bin/linux-x86_64/PSLioc
## You may have to change PSLioc to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","PSLioc")
epicsEnvSet("TOP","/mnt/soft-bam01/epics/IOC/PSLioc")
epicsEnvSet("SUPPORT","/soft/epics/inst-3.15.7")
epicsEnvSet("ASYN","/soft/epics/inst-3.15.7/asyn/4-40-1")
epicsEnvSet("BUSY","/soft/epics/inst-3.15.7/busy/1-7-2")
epicsEnvSet("CALC","/soft/epics/inst-3.15.7/calc/3-7-4")
epicsEnvSet("SSCAN","/soft/epics/inst-3.15.7/sscan/2-11-3")
epicsEnvSet("AUTOSAVE","/soft/epics/inst-3.15.7/autosave/5-10-1")
epicsEnvSet("AREA_DETECTOR","/soft/epics/inst-3.15.7/areaDetector-R3-11")
epicsEnvSet("ADCORE","/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore")
epicsEnvSet("ADSUPPORT","/soft/epics/inst-3.15.7/areaDetector-R3-11/ADSupport")
epicsEnvSet("ADPSL","/soft/epics/inst-3.15.7/areaDetector-R3-11/ADPSL")
epicsEnvSet("EPICS_BASE","/soft/epics/base")
dbLoadDatabase("../../dbd/PSLioc.dbd",0,0)
PSLioc_registerRecordDeviceDriver(pdbbase)
epicsEnvSet("PREFIX", "XRFDS:")
epicsEnvSet("PORT",   "PSL")
epicsEnvSet("QSIZE",  "20")
epicsEnvSet("XSIZE",  "2744")
epicsEnvSet("YSIZE",  "2208")
epicsEnvSet("NCHANS", "2048")
#epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore/db")
# Create the asyn port to talk to the PSL server on port 50000
drvAsynIPPortConfigure("PSLServer","hzb1.exp.helmholtz-berlin.de:50000", 0, 0, 0)
asynOctetSetOutputEos("PSLServer", 0, "\n")
asynOctetSetInputEos("PSLServer", 0, "\n")
#asynSetTraceIOMask("PSLServer",0,2)
#asynSetTraceMask("PSLServer",0,255)
#asynSetTraceFile("PSLServer", 0, "PSLServer.out")
# PSLConfig(const char *portName, const char *serverPort,
#          int maxBuffers, size_t maxMemory,
#          int priority, int stackSize)
PSLConfig("PSL", "PSLServer", 0, 0)
#asynSetTraceIOMask("$(PORT)",0,2)
#asynSetTraceMask("$(PORT)",0,9)
dbLoadRecords("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore/db/ADBase.template","P=XRFDS:,R=cam1:,PORT=PSL,ADDR=0,TIMEOUT=1")
dbLoadRecords("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore/db/NDFile.template","P=XRFDS:,R=cam1:,PORT=PSL,ADDR=0,TIMEOUT=1")
dbLoadRecords("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADPSL/db/PSL.template",   "P=XRFDS:,R=cam1:,PORT=PSL,ADDR=0,TIMEOUT=1")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "PSL", 0, 0)
dbLoadRecords("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore/db/NDPluginBase.template","P=XRFDS:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PSL,NDARRAY_ADDR=0")
# Make NELEMENTS in the following be a little bigger than 2744*2208
dbLoadRecords("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore/db/NDStdArrays.template", "P=XRFDS:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PSL,TYPE=Int16,FTVL=SHORT,NELEMENTS=6100000")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 20, 0, "PSL", 0)
dbLoadRecords("NDFileTIFF.template",  "P=XRFDS:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=PSL")
# Create 1 statistics plugins
NDStatsConfigure("STATS1", 20, 0, "PSL", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=XRFDS:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=2744,YSIZE=2208,NCHANS=2048,NDARRAY_PORT=PSL")
NDTimeSeriesConfigure("STATS1_TS", 20, 0, "STATS1", 1, 23)
dbLoadRecords("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore/db/NDTimeSeries.template",  "P=XRFDS:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Load all other plugins using commonPlugins.cmd
#< $(ADCORE)/iocBoot/commonPlugins.cmd
set_savefile_path("/soft/epics/IOC/PSLioc/iocBoot/PSLioc/autosave")
set_requestfile_path("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADPSL/pslApp/Db")
set_requestfile_path("/soft/epics/IOC/PSLioc/iocBoot/PSLioc")
set_requestfile_path("/soft/epics/inst-3.15.7/areaDetector-R3-11/ADCore/ADApp/Db")
set_requestfile_path("/soft/epics/inst-3.15.7/calc/3-7-4/calcApp/Db")
set_pass1_restoreFile("auto_settings.sav")
iocInit()
Starting iocInit
## EPICS R3.15.7
## EPICS Base built Dec 20 2019
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from '/soft/epics/IOC/PSLioc/iocBoot/PSLioc/autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=XRFDS:,D=cam1:")
epics> auto_settings.sav: 352 of 352 PV's connected
2023/03/02 16:48:49.460 PSL:getImage: error reading image, status=4, dataLen=12117504, nCopied=12117502, maxRead=2, nRead=1377
epics>
epics> 2023/03/02 16:51:32.720 PSL:getImage: error reading image, status=4, dataLen=12117504, nCopied=12117503, maxRead=1, nRead=1185
2023/03/02 16:51:48.603 PSL:getImage: error reading image, status=4, dataLen=12117504, nCopied=12117503, maxRead=1, nRead=1959
2023/03/02 16:51:55.546 PSL:writeReadServer, status=1, sent
Stop
2023/03/02 16:51:55.552 PSL:getImage: error reading image, status=1, dataLen=12117504, nCopied=8333289, maxRead=2048, nRead=0
2023/03/02 16:51:55.581 PSL:writeInt32: error, status=1 function=8, value=0
2023/03/02 16:51:55.581 XRFDS:cam1:Acquire devAsynInt32::processCallbackOutput process write error
2023/03/02 16:52:05.499 PSL:getImage: error reading image, status=4, dataLen=12117504, nCopied=12117502, maxRead=2, nRead=1603
2023/03/02 16:52:10.847 PSL:getImage: error reading image, status=4, dataLen=12117504, nCopied=12117502, maxRead=2, nRead=51
Best Regards
Michael
AW: pasynOctetSyncIO error reading image status=4 Sintschuk, Michael via Tech-talk
Prev: pasynOctetSyncIO error reading image status=4 Sintschuk, Michael via Tech-talk
Next: Segmentation fault (core dumped) using SimDetector ioc lynn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: AW: pasynOctetSyncIO error reading image status=4 Sintschuk, Michael via Tech-talk
