1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: #define usage in Sequencer
From: Hyung Jin Kim via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 3 Apr 2023 08:01:20 +0900
Dear Mark,
After my sequencer file is renamed as ".st", it works fine.
Best regards,
HJ
On 4/3/23 00:22, Mark Rivers wrote:
I believe I understand the problem.  This is from the sequencer manual:
Depending on the application, it might be useful to pre-process the SNL source with a C pre-processor (cpp). Using the C pre-processor allows you to include other SNL files, define macros, and perform conditional compilation. snc supports this by interpreting cpp-generated line markers, so that error and warning messages refer to the line numbers in the un-pre-processed SNL source.
The build rules that the sequencer adds to the EPICS build system are such that files with the extension .st are preprocessed, while those with the extension .stt are not.
So if you name your file .stt then the C pre-processor is not run.  But #define is handled by the C pre-processor.  So you need to name your file .st not .stt.
I tested this on my system, and I get the same error as you if the file is named .stt, but it works fine if it is named .st.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Hyung Jin Kim via Tech-talk <tech-talk at aps.anl.gov>
Sent: Sunday, April 2, 2023 7:25 AM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: #define usage in Sequencer
Dear All,
I tried to set a size of array using predefined value in sequencer code as follows:
program sncTest
#define A_SIZE 3
double test_array[A_SIZE];
assign test_array to {"{S}:r1", "{S}:r2", "{S}:r3"};
monitor test_array;
However, it gives an error when it is compiled. #define is not allowed in sequencer. An used sequencer version is 2-2-6.
../sncTest.stt:3: lexical error: invalid character
../sncTest.stt:3: syntax error near token ''
../sncTest.stt:3: parser giving up
#define usage in Sequencer Hyung Jin Kim via Tech-talk
Re: #define usage in Sequencer Mark Rivers via Tech-talk
Prev: Re: #define usage in Sequencer Mark Rivers via Tech-talk
Next: 03/04/2023 19:01:51 自动保存草稿 lynn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 03 Apr 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
