1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: areaDetector error in mingw, windows
To: tech-talk <[email protected]>, lynn <[email protected]>
Date: Thu, 13 Apr 2023 13:31:14 +0000
Hi Lynn,
You probably don't really need GraphicsMagick.  I suggest you changed areaDetector/configure/CONFIG_SITE.local to set WITH_GRAPHICSMAGICK=NO.
See if you then get any other errors.
From: Tech-talk <[email protected]> on behalf of lynn via Tech-talk <[email protected]>
Sent: Thursday, April 13, 2023 5:38 AM
Subject: areaDetector error in mingw, windows
    I want to use areaDetector, using Ming 64,Windows Home 64.
    base 7.0.7, asyn, areaDetector and other module are all new version from git.
    I am not quite sure about how to install it, using windows lib and software. But I know linux way, so i install it just like linux OS, except EPICS_HOST_ARCH or something.
I did these, before i make areaDetector :
1) base,asyn, busy and other module was installed well and prepare areaDetector( ADSupport, ADCore)
2) cp and modify  release.local, release_libs.local,release_prods.local,config_site.local
3) make and error came out( error message at bottom)
4) Then I tried CONFIG_SITE.local.linux-x86.win32-x86-mingw,CONFIG_SITE.local.linux-x86.win32-x86-mingw-static  and CONFIG_SITE.local.WIN32, all  failed.
5) I also try to configure areaDetector, using GraphicsMagick external, still in mingw environment.
configure && make :
libtool:   error: Could not determine host file name corresponding to
libtool:   error:   'Magick++/lib/.libs/' :
And I want to know:
Considering i did much work using linux way in mingw environment.
1) how to fix the error below?
2) if you have better way, please let me know it.
Output of areaDetector make: (in Mingw 64)
 C:/msys64/mingw64/include/objidl.h:11436:11: error: reference to 'byte' is ambiguous
11436 |     const byte *pv,
C:/msys64/mingw64/include/c++/12.2.0/bits/cpp_type_traits.h:406:30: note: candidates are: 'enum class std::byte'
  406 |   enum class byte : unsigned char;
C:/msys64/mingw64/include/rpcndr.h:63:25: note:                 'typedef unsigned char byte'
   63 |   typedef unsigned char byte;
In file included from C:/msys64/mingw64/include/msxml.h:311,
                 from C:/msys64/mingw64/include/urlmon.h:458,
                 from C:/msys64/mingw64/include/objbase.h:163:
C:/msys64/mingw64/include/oaidl.h:587:5: error: reference to 'byte' is ambiguous
  587 |     byte *pRecord;
make[6]: *** [/home/dell/base-7.0.7/configure/RULES_BUILD:267: Image.obj] Error 1
make[6]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc/Magick++/lib/O.windows-x64-mingw'
make[5]: *** [/home/dell/base-7.0.7/configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[5]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc/Magick++/lib'
make[4]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: lib.install] Error 2
make[4]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc/Magick++'
make[3]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: Magick++.install] Error 2
make[3]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp/GraphicsMagickSrc'
make[2]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: GraphicsMagickSrc.install] Error 2
make[2]: Leaving directory '/home/dell/areaDetector-master/ADSupport/supportApp'
make[1]: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: supportApp.install] Error 2
make[1]: Leaving directory '/home/dell/areaDetector-master/ADSupport'
make: *** [/home/dell/base-7.0.7/configure/RULES_DIRS:85: /home/dell/areaDetector-master/ADSupport.install] Error 2
$ uname -a
MINGW64_NT-10.0-22000 DESKTOP-M04F14I 3.4.6.x86_64 2023-04-01 11:43 UTC x86_64 Msys
$ gcc --version
gcc.exe (Rev10, Built by MSYS2 project) 12.2.0
$ make --version
GNU Make 4.4.1
Built for x86_64-pc-msys
Lynn
Re:Re: areaDetector error in mingw, windows lynn via Tech-talk
Prev: Re: areaDetector error in mingw, windows Ralph Lange via Tech-talk
Next: Is the Sequencer and SNL still widely used? Murray, Doug via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Next: Re:Re: areaDetector error in mingw, windows lynn via Tech-talk
