Hi Mark and Ralph, Thank you for your answer. I choose an easy way, set WITH_GRAPHICSMAGICK=NO and work well. Actually, I intend to use xspress3 module in mingw of windows. And i did these thing and met some error again. 1) i installed xspress3 module well, but there isn't bin file( mingw-64, base7.0.7, asyn, areaDetector and others good). I want to know. Could I do some setting, make the bin file of xspress3 came out directly after make command? 2) Since there isn't bin file, I try: [1] create an ioc using makeBaseApp.pl. [2] add st.cmd of xspess. But something wrong during [1]. I did these: (a) type: $(BASE)/bin/windows-x64-mingw/makeBaseApp.pl -t example example (b) type: $(BASE)/bin/windows-x64-mingw/makeBaseApp.pl -i -t example example (c) choose windos-x64-mingw, The following target architectures are available in base: windows-x64 windows-x64-mingw P.S. There are two file in my &(BASE)/bin/. "window-x64" and "windows-x64-mingw" (d) make, no error (e) start the ioc --$ ../../bin/windows-x64-mingw/example.exe st.cmd #!../../bin/windows-x64-mingw/example < envPaths epicsEnvSet("IOC","iocexample") epicsEnvSet("TOP","/home/dell/all") epicsEnvSet("EPICS_BASE","/home/dell/base-7.0.7") cd "/home/dell/all" Invalid directory path, ignored ## Register all support components dbLoadDatabase "dbd/example.dbd" filename="../dbStatic/dbLexRoutines.c" line number=276dbRead opening file dbd/example.dbd example_registerRecordDeviceDriver pdbbase registerRecordDeviceDriver failed aSub registerRecordDeviceDriver failed aai *** *** registryJLinkAdd failed trace registryJLinkAdd failed pva ## Load record instances dbLoadTemplate "db/user.substitutions" dbLoadTemplate: error opening sub file db/user.substitutions dbLoadRecords "db/exampleVersion.db", "user=dell" filename="../dbStatic/dbLexRoutines.c" line number=276dbRead opening file db/exampleVersion.db dbLoadRecords: failed to load 'db/exampleVersion.db' dbLoadRecords "db/dbSubExample.db", "user=dell" filename="../dbStatic/dbLexRoutines.c" line number=276dbRead opening file db/dbSubExample.db dbLoadRecords: failed to load 'db/dbSubExample.db' cd "/home/dell/all/iocBoot/iocexample" Invalid directory path, ignored iocInit Starting iocInit checkDatabase: menuConvert not defined. iocBuild: Aborting, bad database definition (DBD)! Base 7.0.7 was right. These process should be good in linux. I don't know what is wrong with it. So could someone do me a favor. I just want to use xspress in mingw. Regards, Lynn 在 2023-04-13 21:31:14,"Mark Rivers" <rivers at cars.uchicago.edu> 写道:
ANJ, 15 Apr 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
