1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: Problem using ADPICam driver
From: Jörn Dreyer via Tech-talk <[email protected]>
Cc: [email protected]
Date: Fri, 28 Apr 2023 14:25:50 +0200
Hi Mark,
Am Freitag, 28. April 2023, 14:00:07 CEST schrieben Sie:
> > Hi Jörn,
> > the other Software is a code that I wrote based on the ADPiCam driver for
> > a system called Karabo developen at EuXFEL. I tested it on the same Linux
> > system.
> Is it really based on ADPiCam, or just the vendor PiCAM SDK?
I used ADPICAM as a guide how to best implement it, but of course no copy and
paste as I had to use a certain naming scheme for variables and functions. In
addition I had to write separate classes for each type of Detector as I could
not hide parameters that do not exist in a given device.
Meanwhile I got a hint from Princeton Instruments that the problem is related
to a certain version of libusb used on the system:
> With that being said, I have used the SDK personally on Ubuntu 22.04 LTS --
in order to get it to work properly with USB cameras, I had to clamp libusb to
version 1.0.23-2build1.
So I will try that next, as my system uses version 1.0.26 of the library. I
have to compile an old version on my system and test again.
Jörn
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Abt. FWKX                    Tel: +49 351 260 3263
                                       Fax: +49 351 260 123263
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
Tel: +49 (0) 351 260 1234
http://www.hzdr.de
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
Problem using ADPICam driver Jörn Dreyer via Tech-talk
Re: Problem using ADPICam driver Jörn Dreyer via Tech-talk
Re: Problem using ADPICam driver Mark Rivers via Tech-talk
Prev: Re: Problem using ADPICam driver Mark Rivers via Tech-talk
Next: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Job Opportunities: Controls Software Developers and DevOps Engineer, STFC ISIS Facility, Oxfordshire, UK Ivan Finch - STFC UKRI via Tech-talk
