1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: EPICS 3.15.9 build system weird behaviour upon missing g++
From: "Dmitry Yu. Bolkhovityanov via Tech-talk" <[email protected]>
Cc: [email protected]
Date: Fri, 28 Apr 2023 22:15:24 +0700 (+07)
Hi Andrew,
On Thu, 27 Apr 2023, Andrew Johnson wrote:
There are two implementations of epicsTempFile.cpp which provide a function that are needed by the e_flex and antelope programs (versions of lex and yacc). Those programs are required by the build process in the src/libCom directory as a result of these dependency rules in src/libCom/as/RULES:
 # This is a Makefile fragment, see src/libCom/Makefile.
 # Extra rule since asLib_lex.c is included by asLib.c
 asLib$(DEP): asLib_lex.c
 asLib.c: asLib_lex.c
 # Ensure that lexer and parser are built before they are needed
 asLib.c: $(EPICS_BASE_HOST_BIN)/antelope$(HOSTEXE)
 asLib_lex.c: $(EPICS_BASE_HOST_BIN)/e_flex$(HOSTEXE)
 asLib_lex.c: $(INSTALL_INCLUDE)/flex.skel.static
The asLib$(DEP) target expands to asLib.d which gets included into the Makefile, so that causes both e_flex and antelope to be built in the first-pass of the make process for libCom. The asLib_lex.c file is generated by running e_flex on the asLib_lex.l source file, and asLib.c is created by antelope from the asLib.y source file.
Thanks for pointing the direction!
It's possible that removing the asLib$(DEP) rule might clean this up, but I don't know if the result will actually build. Please let me know if you find a solution that removes some of this complexity.
I'll try to, but I doubt I'm able to completely grok the operation of EPICS build system.
(Shame on me, even the principle of "HOST_OPT=NO" functioning is still a mystery: there are no references to $(HOST_OPT) besides 6 items in *win32-x86.win32-x86 files, yet the "HOST_OPT=NO" does affect Linux builds. Must be something with computed variable names...)
 Is there any document describing how EPICS build system is configured to
 ignore *some* errors (curiously, without a use of ".IGNORE:", "--ignore"
 or "-" before commands)?
It's not not documented or explicitly configured by our build system at all, it just occurs implicitly because of the above dependency rules and the fact that the build -includes all the generated .d files.
Thanks!  That looks like the final piece of the puzzle.
If those commands happen on GNU make's preliminary pass for "Automatic Prerequisites Generation", then that strange behaviour with ignoring *some* errors becomes clear: make supposes some commands can fail due to not-yet-ready files (which are supposed to be made during preliminary passes, and those passes can be multiple, not only one "first").
Unfortunately, the principles of what errors to ignore aren't clearly specified (and can even change between "make" versions). Thus, the build system behaviour looks completely weird.
 P.S. I'm trying to investigate this problem not because of "missing g++"
 (which is obviously a non-issue), but to understand how the EPICS build
 system works.  Which, in turn, is needed to solve another class of
 problems: when something goes wrong during build, e.g. "genApps" SIGSEGVs
 on some architectures (due to a buggy gddUtils.h), the error isn't shown
 "as is" immediately but the build process continues and only the "induced"
 error due to a missing file is shown later.
There have been several fixes committed to the 3.15 branch on GitHub since the 3.15.9 release, at least one of which related to gdd so I recommend you take a look at the branch tip in case that resolves those issues.
Do you mean https://git.launchpad.net/epics-base/log/src/ca/legacy?h=3.15 ? There's only one minor tweak (in a weird-looking code which I fail to understand :)) after 3.15.9 release date.
Or is there any other place to look at?
The gdd code is another area that has circular dependencies and requires compilation during the first pass.
Oh, yeah, that very "genApps" binary :)
To be honest we are only continuing to build gdd because it's needed by the Channel Access PV Gateway which many sites rely on; the original authors of that code have left the community and nobody really wants to touch it, although we do have to keep it running because we still need the gateway.
I understand that with all my heart. I spent a lot of time trying to learn using libcas -- wading through the thickets of gdd, aitTypes and asynchronous IO classes. A rather thankless job.
With best regards,
Dmitry
Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Dmitry Yu. Bolkhovityanov via Tech-talk
Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Johnson, Andrew N. via Tech-talk
Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Andrew Johnson via Tech-talk
Prev: Re: Problem using ADPICam driver Jörn Dreyer via Tech-talk
Next: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Dmitry Yu. Bolkhovityanov via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: EPICS 3.15.9 build system weird behaviour upon missing g++ Andrew Johnson via Tech-talk
