1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: timestampField not retrieved using CA provider for pvac::ClientChannel
From: "Bisegni, Claudio via Tech-talk" <[email protected]>
To: Andrew Johnson <[email protected]>, "Veseli, Sinisa" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 5 May 2023 19:44:31 +0000
Should be a my mistake because if I use the pvget with the specific parameter it work:
developer@e058f4bc2090:/workspace$ pvget -p ca -r "field(field,timeStamp,alarm)" ca:variable:a
ca:variable:a structure
    alarm_t alarm
        int severity 0
        int status 0
        string message
    time_t timeStamp 2023-05-05 19:22:59.521
        long secondsPastEpoch 1683314579
        int nanoseconds 521323913
        int userTag 0
I am digging into it.
Anyway, thank you for point me in the right direction
Claudio
Date: Friday, 5 May 2023 at 12:24
To: Andrew Johnson <[email protected]>, Veseli, Sinisa <[email protected]>, [email protected] <[email protected]>
I fixed the error reported by Sinisa (the reference to other channel for the sum)
I changed the pv name and not I’m trying to get data from ca:variable:a(below) could be some problem on c++ layer of pvData?
I done:
caput ca:variable:a.PROC 1
and the I got:
structure
    double value 1
    alarm_t alarm
        int severity 0
        int status 0
        string message
    display_t display
        double limitLow 0
        double limitHigh 0
        string description
        string format F6.0
        string units
    control_t control
        double limitLow 0
        double limitHigh 100
        double minStep 0
    valueAlarm_t valueAlarm
        boolean active false
        double lowAlarmLimit nan
        double lowWarningLimit nan
        double highWarningLimit nan
        double highAlarmLimit nan
        int lowAlarmSeverity 0
        int lowWarningSeverity 0
        int highWarningSeverity 0
        int highAlarmSeverity 0
        byte hysteresis 0
regards
Claudio
Date: Friday, 5 May 2023 at 11:46
To: Bisegni, Claudio <[email protected]>, Veseli, Sinisa <[email protected]>, [email protected] <[email protected]>
Hi Claudio,
Please try running the command
caput ca:variable:sum.PROC 1
and then run your client again. I suspect that the timestamp of your CALC record is still undefined i.e. 0,0 and that's why it isn't getting displayed.
- Andrew
On 5/5/23 1:23 PM, Bisegni, Claudio via Tech-talk wrote:
Hi yes sure:
This is my code:
auto ca_provider  = std::make_unique<pvac::ClientProvider>("ca", epics::pvAccess::ConfigurationBuilder().push_env().build());
auto  channel = std::make_shared<pvac::ClientChannel>(provider.connect(pv_name, opt));
auto op = channel->get(this, pvd::createRequest("field()"));
I need to specify that I connect to a IOCs launched with “sofIOC -d xyz.db” this si the content of the DB:
record(ao, "ca:variable:a")
    field(DRVH, "100")
    field(DOL, "0")
    field(PINI, "YES")
record(ao, "ca:variable:b")
    field(DRVH, "100")
    field(DOL, "0")
    field(PINI, "YES")
record(calc, "ca:variable:sum")
    field(SCAN, "1 second")
    field(INPA, "variable:a")
    field(INPB, "variable:b")
    field(CALC, "A+B")
I got this as answer on get operation:
structure
    double value 3
    alarm_t alarm
        int severity 0
        int status 0
        string message
    display_t display
        double limitLow 0
        double limitHigh 0
        string description
        string format F6.0
        string units
    control_t control
        double limitLow 0
        double limitHigh 0
        double minStep 0
        byte hysteresis 0
Date: Friday, 5 May 2023 at 11:05
To: Bisegni, Claudio <[email protected]>, [email protected] <[email protected]>
I am not sure I understand what is going on. Perhaps you could include your code so we can see what exactly you are trying to do?
Also, if you'd like to get all fields, the string 'field()' or just empty string '' should work:
>>> print(c.get('field()'))
epics:nt/NTEnum:1.0
    enum_t value
        int index 0
        string[] choices [Off, On]
    alarm_t alarm
        int severity 0
        int status 0
        string message
    time_t timeStamp
        long secondsPastEpoch 1683129086
        int nanoseconds 834120910
        int userTag 0
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
Sent: Friday, May 5, 2023 12:56 PM
To: Veseli, Sinisa <[email protected]>; [email protected] <[email protected]>
I tried to set request field as:
pvd::createRequest("field(value, timeStamp, alarm, display, control, valueAlarm)
but I didn’t get the timeStamp Field in PVStructure. The request field work well for all other (for CA provider) for the PVA provider, instead, I always got every field also if I put only “filed(value)” in the request.
I’m wrong somenting….
Claudio
Date: Friday, 5 May 2023 at 10:44
To: Veseli, Sinisa <[email protected]>, [email protected] <[email protected]>
Thank you for yor help, is effect on get operation I use the default request, so Iat this point I need to use pvd::createRequest("field(value, timeStamp, alarm, display, control, valueAlarm)")); to retrieve all field
I’ll give a try!
Thank you very much.
Claudio
Date: Friday, 5 May 2023 at 09:55
To: [email protected] <[email protected]>, Bisegni, Claudio <[email protected]>
I am not sure exactly why is there a difference in behavior between caget and pvget, but you should be able to get timestamps if you request them explicitly:
$ caget -a S01-DAQTBT:Strm:DataCaptureC
S01-DAQTBT:Strm:DataCaptureC   2023-05-03 10:51:26.834121 Off
PV request string like field(value,timeStamp) should work from C++:
>>> from pvapy import *
>>> c = Channel('S01-DAQTBT:Strm:DataCaptureC', CA)
>>> print(c.get('field(value,timeStamp)'))
epics:nt/NTEnum:1.0
    enum_t value
        int index 0
    time_t timeStamp
        int userTag 0
Hope this helps,
Sinisa
Siniša Veseli
(630)252-9182
From: Tech-talk <[email protected]> on behalf of Bisegni, Claudio via Tech-talk <[email protected]>
Sent: Friday, May 5, 2023 11:39 AM
Subject: timestampField not retrieved using CA provider for pvac::ClientChannel
Hello EPICS tech,
I'm working with last epics release and I have notice that making a get operation for an IOC using a CA provider for crete a pvac::ClientChannel I don't receive the timestamp field:
I noticed that also the official caget has the problem:
developer@e058f4bc2090:/workspace$ pvget variable:sum
variable:sum 2023-05-05 16:34:54.607 3
developer@e058f4bc2090:/workspace$ caget variable:sum
variable:sum 3
so is a client library problem or a server or something else?
Thank
you in advance.
Claudio
Complexity is free, it's Simplicity that takes work.
Re: timestampField not retrieved using CA provider for pvac::ClientChannel Andrew Johnson via Tech-talk
timestampField not retrieved using CA provider for pvac::ClientChannel Bisegni, Claudio via Tech-talk
Re: timestampField not retrieved using CA provider for pvac::ClientChannel Veseli, Sinisa via Tech-talk
Re: timestampField not retrieved using CA provider for pvac::ClientChannel Bisegni, Claudio via Tech-talk
Prev: Re: timestampField not retrieved using CA provider for pvac::ClientChannel Bisegni, Claudio via Tech-talk
Next: Re: timestampField not retrieved using CA provider for pvac::ClientChannel Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
