1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: More precise timing for record processing
From: "Sobhani, Alex via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 29 May 2023 01:35:27 +0000
The SCAN field lets you choose from .1, .2, .5, 1, 2, 5, or 10 seconds. In cases where this is not enough, is there a simple way to make a record process at other intervals such as 2.7 seconds or 5.4 seconds, specified at runtime? I know you can add options for more periods of the SCAN field by editing dbd files, but you cannot change your mind at runtime.
I envision something like this:
record(timer, “BL0:mytimer”){
                field(PERI, 2.7)
                field(FLNK, “BL0:mytrigger”)
And then subfields to enable/disable it.
Does anything like this exist? I would imagine that something like this would be very generally useful.
Alex
Re: More precise timing for record processing Mark Rivers via Tech-talk
Re: More precise timing for record processing Arnold, Ned D. via Tech-talk
Prev: Issues with epics module and ISEG HAL service libraries Yann Mandza via Tech-talk
Next: Re: Issues with epics module and ISEG HAL service libraries Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Re: Issues with epics module and ISEG HAL service libraries André Hartmann via Tech-talk
Next: Re: More precise timing for record processing Mark Rivers via Tech-talk
ANJ, 30 May 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
