1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: problem reading data from PLC S7NODAVE
From: Maren Purves via Tech-talk <tech-talk at aps.anl.gov>
To: Abhishek Dutta <abhishekdutta777 at gmail.com>
Cc: s7nodave-maintainer at oss.aquenos.com, tech-talk at aps.anl.gov
Date: Mon, 7 Aug 2023 10:32:35 -1000
Aloha,
as your two records process independent of one another you may very well have one record get the reply to the other.
I'd suggest to
- try only one of the records at first
- slow the scan rate down (you're in development, not in production)
- using FLNK/SLNK to connect them after determining that they work individually
Maren Purves
Head of Instrument and Telescope Software
East Asian Observatory
On Mon, Aug 7, 2023 at 5:22 AM Abhishek Dutta via Tech-talk <tech-talk at aps.anl.gov> wrote:
Sir,
I've been trying to establish communication with S7 1500 PLC. Trying to read IW0, MD0.
While starting the IOC, I don't get any syntax error etc. The message shows following:
#!../../bin/linux-x86_64/myS7
< envPaths
epicsEnvSet("IOC","iocmyS7")
epicsEnvSet("TOP","/ics/tools/myS7")
epicsEnvSet("ASYN","/ics/tools/asyn4-38")
epicsEnvSet("S7NODAVE","/home/training/Desktop/ics/tools/s7nodave-3.0.2")
epicsEnvSet("EPICS_BASE","/ics/tools/base-7.0.6")
epicsEnvSet("ETHER_IP","/ics/tools/ether_ip")
epicsEnvSet("SNCSEQ","/ics/tools/seq-2.2.9")
epicsEnvSet("AUTOSAVE","/ics/tools/autosave-R5-10-2")
epicsEnvSet("STREAM","/ics/tools/StreamDevice-master")
epicsEnvSet("BUSY","/ics/tools/busy-1-6-1")
epicsEnvSet("PVXS","/ics/tools/pvxs")
epicsEnvSet("PYDEVICE","/ics/tools/PyDevice-R1.1.1")
cd "/ics/tools/myS7"
dbLoadDatabase "dbd/myS7.dbd"
myS7_registerRecordDeviceDriver pdbbase
#var mySubDebug 1
#traceIocInit
cd "/ics/tools/myS7/iocBoot/iocmyS7"
## Load record instances
#dbLoadTemplate "user.substitutions"
#dbLoadRecords "user.db"
< hall.cmd
s7nodaveConfigureIsoTcpPort("HallPLC","192.168.0.1",0,1,0)
s7nodaveConfigurePollGroup("HallPLC",'default',1.0,0)
s7nodaveConfigurePollGroup("HallPLC",'fast',0.1,0)
dbLoadRecords "hall1.db"
iocInit
Starting iocInit
## EPICS R7.0.6
## Rev. 2021-09-28T15:27-0400
## Start any sequence programs
#seq sncExample, "user=training"
epics> 2023/08/01 21:01:20.281 HallPLC error while reading 2 bytes from PLC address IB0.
2023/08/01 21:01:20.283 HallPLC error while reading 4 bytes from PLC address FB0.
IOC name is myS7 and following is the hall1.db file. It resides in the same st.cmd directory:
record(ai, "hall_ip1")
field(SCAN,"1 second")
field(DTYP,"s7nodave")
field(INP, "@HallPLC(DLV=0,DHV=27648) IW0 int16")
field(EGU,"V")
record(ai, "hall_uvolt")
field(INP, "@HallPLC MD0 float")
field(EGU,"V")
Please suggest solution for the same.
Abhishek Dutta
problem reading data from PLC S7NODAVE Abhishek Dutta via Tech-talk
Prev: Re: netDev "channels" record type problem Shuei YAMADA via Tech-talk
Next: Re: netDev "channels" record type problem Владимир Сергейчик via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: problem reading data from PLC S7NODAVE Abhishek Dutta via Tech-talk
Next: Using opencv with areaDetector William Smith via Tech-talk
ANJ, 08 Aug 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
