Hello,
I have a strange problem in a areaDetector plugin I currently writing. I want
to fill a mbbo record with the strings from an std::vector I get from a
library function. I copy the elements of the std::vestor to a pre allocated
char** array and fill values and severities arrays. In my writeInt32 function
I do a call to
doCallbacksEnum(strings, values, severities, nEntries, function, 0)
This leads to a crash with SIGSEGV. After recompiling my code and the asyn
module with debug symbols I managed to track down the problem to an
uninitialized variable in asynManager:
#0 0x00007ffff7f33417 in interruptStart (pasynPvt=0x0, plist=0x7fffc37f9568)
at ../../asyn/asynDriver/asynManager.c:2438
2438 port *pport = pinterruptBase->pport;
looking at pinterruptBase it returns 0x0.
The backtrace leading to this crash is:
#1 0x00007ffff7f56b57 in asynPortDriver::doCallbacksEnum(char**, int*, int*,
unsigned long, int, int)
(this=0x745a90, strings=0x73f4b0, values=0x744000, severities=0x744060,
nElements=7, reason=80, address=0)
at ../../asyn/asynPortDriver/asynPortDriver.cpp:3363
#2 0x00007ffff7df1e4b in NDFileOpenPMD::writeInt32(asynUser*, int)
(this=<optimized out>, pasynUser=<optimized out>, value=<optimized out>)
at ../NDFileOpenPMD.cpp:192
My driver is derived from NDFilePlugin as:
NDPluginFile(portName, queueSize, blockingCallbacks,
NDArrayPort, NDArrayAddr, 1,
0, 0, asynGenericPointerMask | asynEnumMask,
ASYN_CANBLOCK, 1, priority, stackSize, 1, true)
So in my understanding it should be configured to be able to use enum
functions.
Can anybody help me to figure out what I'm doing wrong? I did a crosscheck
with other areaDetector plugin drivers if there is a special setting missing
and also looked at the examples from asy, but could not figur out whjat is
wrong in my code.
Jörn Dreyer
- Re: Problem writing enum entries from asyn driver (areaDetector) ino a databse record. Mark Rivers via Tech-talk
Re: Dante Siddons, David via Tech-talk
<2023>
2025
Re: Dante Mark Rivers via Tech-talk
<2023>
2025
