1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: RE: preventing changing an EPICS motor's commanded position
From: "Goetze, Kurt via Tech-talk" <[email protected]>
To: "Gregory, Ray" <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Tue, 3 Oct 2023 18:19:42 +0000
Hi Ray,
“motor.db” loads a bo record, “$(P)$(M)_able”, that the motor record’s SDIS field points to.
We use this to enable/disable the motor record.  When disabled, writes to the motor record’s .VAL field are not allowed.
Kurt
From: Tech-talk <[email protected]> On Behalf Of Matt Newville via Tech-talk
Sent: Tuesday, October 3, 2023 10:06 AM
To: Peterson, Kevin M. <[email protected]>; Gregory, Ray <[email protected]>; [email protected]
Subject: Re: preventing changing an EPICS motor's commanded position
Ray,
Perhaps what you're looking for is simply to set the Motor Record low and high limits to the drive value you want to maintain.
You could also set the SPMG field to 0 or 'Stop'.  That would allow someone to change the VAL field (which is what you said you wanted to not allow), but it will prevent the Motor from actually moving until SMPG is changed back to 2 or 'Go'.   Both of these use the exposed interface to the Motor Record, so in principle can be changed at any time.   But they are also not uncommon things to do for motors that you want to not accidentally move.
On Tue, Oct 3, 2023 at 8:17 AM Kevin Peterson via Tech-talk <[email protected]> wrote:
Ray,
Can you provide more details about what "disabling the axis" means?  The
behavior of the motor record's CNEN field, which is labeled "Torque" on
the motorx_all screen, is controller dependent; for some controllers
CNEN enables/disables drive power, for other controllers CNEN switches
between open and closed loop control, and some drivers do nothing when
CNEN is changed.
Kevin
On 10/2/23 12:32, Gregory, Ray via Tech-talk wrote:
> Hi,
> How can I prevent changing an EPICS motor record’s commanded position
> (.VAL field) without disabling the axis?
> Thank you,
> Ray
> Ray Gregory
> Oak Ridge National Laboratory
--Matt Newville <newville at cars.uchicago.edu> 630-327-7411
Re: preventing changing an EPICS motor's commanded position Maren Purves via Tech-talk
Re: preventing changing an EPICS motor's commanded position Rolf Keitel via Tech-talk
preventing changing an EPICS motor's commanded position Gregory, Ray via Tech-talk
Re: preventing changing an EPICS motor's commanded position Kevin Peterson via Tech-talk
Re: preventing changing an EPICS motor's commanded position Matt Newville via Tech-talk
Prev: Re: preventing changing an EPICS motor's commanded position Matt Newville via Tech-talk
Next: Re: preventing changing an EPICS motor's commanded position Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
