1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: preventing changing an EPICS motor's commanded position
From: Rolf Keitel via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Tue, 3 Oct 2023 18:52:54 -0700
Title: signature text
The statement below is not correct. If a record is disabled, both CA clients and other database records can write to a record's .VAL field. If the record is later re-enabled and processes, this may lead to unexpected consequences or discontinuities.
If you just want to prevent CA clients to modify a record's .VAL field you should set the .DISP field to 1.
HTH - rolf -
On 2023-10-03 11:19 a.m., Goetze, Kurt via Tech-talk wrote:
Hi Ray,
“motor.db” loads a bo record, “$(P)$(M)_able”, that the motor record’s SDIS field points to.
We use this to enable/disable the motor record.  When disabled, writes to the motor record’s .VAL field are not allowed.
Kurt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Matt Newville via Tech-talk
Sent: Tuesday, October 3, 2023 10:06 AM
To: Peterson, Kevin M. <kmpeters at anl.gov>; Gregory, Ray <gregoryrd at ornl.gov>; tech-talk at aps.anl.gov
Ray,
Perhaps what you're looking for is simply to set the Motor Record low and high limits to the drive value you want to maintain.
You could also set the SPMG field to 0 or 'Stop'.  That would allow someone to change the VAL field (which is what you said you wanted to not allow), but it will prevent the Motor from actually moving until SMPG is changed back to 2 or 'Go'.   Both of these use the exposed interface to the Motor Record, so in principle can be changed at any time.   But they are also not uncommon things to do for motors that you want to not accidentally move.
On Tue, Oct 3, 2023 at 8:17 AM Kevin Peterson via Tech-talk <tech-talk at aps.anl.gov> wrote:
Ray,
Can you provide more details about what "disabling the axis" means?  The
behavior of the motor record's CNEN field, which is labeled "Torque" on
the motorx_all screen, is controller dependent; for some controllers
CNEN enables/disables drive power, for other controllers CNEN switches
between open and closed loop control, and some drivers do nothing when
CNEN is changed.
Kevin
On 10/2/23 12:32, Gregory, Ray via Tech-talk wrote:
> Hi,
> How can I prevent changing an EPICS motor record’s commanded position
> (.VAL field) without disabling the axis?
> Thank you,
> Ray
> Ray Gregory
> Oak Ridge National Laboratory
--Matt Newville <newville at cars.uchicago.edu> 630-327-7411
Rolf Keitel, Ph.D.
Researcher Emeritus
e-mail: rolf at triumf.ca
------ Home ------
4158 West 13th Ave
Vancouver, BC, V6R 2T6
604 228 0594
------ Office: ------
604 222 7453
TRIUMF Canada’s particle accelerator centre
4004 Wesbrook Mall Vancouver, BC, V6T 2A3
www.triumf.ca | Twitter | Facebook | Instagram
TRIUMF is located on the traditional, ancestral, and unceded territory of the xʷməθkʷəy̓əm (Musqueam) people,
who for millennia have passed on their culture, history, and traditions from one generation to the next on this site.
RE: preventing changing an EPICS motor's commanded position Goetze, Kurt via Tech-talk
preventing changing an EPICS motor's commanded position Gregory, Ray via Tech-talk
Re: preventing changing an EPICS motor's commanded position Kevin Peterson via Tech-talk
Re: preventing changing an EPICS motor's commanded position Matt Newville via Tech-talk
Prev: Re: preventing changing an EPICS motor's commanded position Maren Purves via Tech-talk
Next: RE: preventing changing an EPICS motor's commanded position Goetze, Kurt via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 04 Oct 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
