1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: How to use INSTALL_LOCATION with system directories
From: Lucas Russo via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>
Date: Tue, 10 Oct 2023 10:20:31 +0200
Regardless of the location our sites decide, does it make sense to try
to support that use case straight out of the box (box = epics base makefile rules)?
I don't really care about the staging area, that being out of source build or not,
so INSTALL_LOCATION could be $(TOP) or something I have write access to,
that is fine. I think I'm just concerned with the final installation step or FINAL_LOCATION,
from what I understand now.
So, does it make sense to add or split rules in EPICS base (maintaining
backwards compatibility) to provide that?
Something like:
make build
sudo make FINAL_LOCATION=/opt/test install
Or whatever target name to compile and one target for installing the binaries/libs/etc?
Lucas
On Tue, Oct 10, 2023 at 10:01 AM Abdalla Ahmad <[email protected]> wrote:
I agree. As you said, you could simply install it at your home directory and append to the PATH variable, for me when I developed the RPM packages for EPICS base and most of its support modules and extensions, I chose “/opt” just for the convention, my original target was to streamline the process of installing EPICS base and needed drivers because it became more of a repeated routine with time, we now just do “yum install epics-base stream-device” and we have a complete stream-device support ready.
Best Regards,
Abdalla.
Sent: Tuesday, October 10, 2023 10:54 AM
Cc: Lucas Russo <[email protected]>
Yes, agree.
But, while I'm a kinda surrogate system administrator, I'm not a system administrator :), so unless I was to e,g, install a new version of a compiler I  wouldn't write into it.
Maren Purves
Head of Instrument and Telescope Software
East Asian Observatory / JCMT
On Mon, Oct 9, 2023 at 9:48 PM Abdalla Ahmad <[email protected]> wrote:
To my knowledge, the difference is just a convention. If I remember correctly, the Linux FHS states that “/opt” is used for 3rd party packaged applications, while “/usr/local” is used by system administrators to install software locally (using “make” for example) so that it does not override any system files.
Best Regards,
Abdalla.
From: Tech-talk <[email protected]> On Behalf Of Lucas Russo via Tech-talk
Sent: Tuesday, October 10, 2023 10:08 AM
To: Maren Purves <[email protected]>
Hi Maren,
I think my question is why not? That's one usual place where you
install binaries/libaries in a linux system that is not a package
(.deb, .rpm). To my knowledge the recommendation is /usr/local
for "local" packages.
Lucas
On Mon, Oct 9, 2023 at 8:25 PM Maren Purves via Tech-talk <[email protected]> wrote:
The part I don't understand is why you want to install it in system space in the first place.
We never have. Install it somewhere you have write access to and add that to your $PATH?
Maren Purves
East Asian Observatory/JCMT
On Mon, Oct 9, 2023 at 5:28 AM Ralph Lange via Tech-talk <[email protected]> wrote:
On Mon, 9 Oct 2023 at 17:03, Jure Varlec via Tech-talk <[email protected]> wrote:
On 10/9/23 16:15, Lucas Russo via Tech-talk wrote:
Caution: This email originated from outside of Cosylab.
Hi Ralph, Abdalla,
I understand. Because there's no separate "installation phase" it
doesn't seem possible to achieve what I was thinking.
Lucas
Hi Lucas,
Why not? Unless I misunderstood what you want, you could do
make INSTALL_LOCATION=${HOME}/tmp/staging/ FINAL_LOCATION=/opt/test
sudo mv ${HOME}/tmp/staging/ /opt/test
sudo chown -R epics:epics /opt/test  # Or root, or whatever
Perhaps having the staging directory under $(TOP) or /tmp makes more sense, it depends on your case, but you get the idea. Would this work for you?
Or, if you really want to use make, you can obviously use INSTALL_LOCATION for your staging area, FINAL_LOCATION for the target area and add something like
final-install:
       mkdir -p $(FINAL_LOCATION); cp -a $(INSTALL_LOCATION)/* $(FINAL_LOCATION)
to the end of your top Makefile.
Cheers,
~Ralph
Re: How to use INSTALL_LOCATION with system directories Ralph Lange via Tech-talk
How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Lucas Russo via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Jure Varlec via Tech-talk
Re: How to use INSTALL_LOCATION with system directories Maren Purves via Tech-talk
RE: How to use INSTALL_LOCATION with system directories Abdalla Ahmad via Tech-talk
Prev: RE: How to use INSTALL_LOCATION with system directories Abdalla Ahmad via Tech-talk
Next: Question regarding ADPluginFile driver Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Next: Re: How to use INSTALL_LOCATION with system directories Ralph Lange via Tech-talk
