1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Subject: Re: [EXTERNAL] Re: PVA connection problem
From: Jörn Dreyer via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, "Kasemir, Kay" <[email protected]>
Date: Wed, 18 Oct 2023 09:02:25 +0200
Hi Kay,
thanks for the explanation. My problem comes from the local firewall that most Linux distros install and that helps to keep load from the system as it blocks most of the broadcast traffic. One does not want to switch it off, especially on laptops.
To get the UDP connection from the IOC to my host working, I had to add a complex rule to my firewall configuration:
rich rules:
        rule family="ipv4" source address="A.B.C.D/X" destination address="A.B.C.E/X" protocol value="udp" accept
Unfortunately you have to do this for each machine that runs an IOC with PVA protocol. Depending on X one could probably set C,D and E to 0 to access a whole set of a subnet. I tested that with D and E set to 0.
Hope this helps others.
Regards
Jörn
Am Dienstag, 17. Oktober 2023, 16:37:36 CEST schrieb Kasemir, Kay:
> > course port XXX is not covered by the firewall rules and is random
> Yes, that’s a known issue with the original PVA server implementation, https://github.com/epics-base/pvAccessCPP/issues/159 .
> You simply can’t use the original PVA server via firewalls unless you allow all UDP traffic, which isn’t practical.
> With the newer PVXS implementation of the PVA server, that’s been fixed.
> A firewall usually involves a gateway, and when you use the PVXS-based PVA gateway, https://mdavidsaver.github.io/p4p/gw.html, you can place that behind a firewall just fine. The IOCs handled by that PVA gateway may still use the original PVA server with random UDP ports, but that’s not a problem inside your controls network. The gateway that you reach via the firewall will stick to the known UDP port for searches and replies. Or you might actually use TCP-only name lookup and avoid UDP altogether for the gateway & firewall.
> From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
> Date: Tuesday, October 17, 2023 at 10:30 AM
> To: [email protected] <[email protected]>
> Subject: [EXTERNAL] Re: PVA connection problem
> Hello
> Sorry for not citing the old messages. I just found the topic on tech-talk as I was looking for a strange behavior I observed when playing around with NDPluginPVA.
> I was able to do a "pvget some_pv" on the machine where the IOC is running, but not on another machine. I had exactly the same ideas as commented here (adding ports 5075/5076 to the firewall) but without luck.
> Then I started up wireshark and tested with and without firewall and figured out whats going on.
> Without firewall:
> Clients sends from port XXX to 5076
> Server replies from port YYY to XXX
> Client can read data!
> With firewall:
> Client replies with ICMP message
> Server gives up, no data transfered!
> Of course port XXX is not covered by the firewall rules and is random (> 50000 in my case). One can get around this if you open your firewall for all UDP traffic.
> But that is not what you really want to do in a bigger network with lots of broadcast traffic. So opening ports 5075/5076 is not necessary.
> So my hope is that one can force pvget/pvput to use a dedicated port that can be added to the firewall rules.
> Regards,
> Jörn
Re: PVA connection problem Jörn Dreyer via Tech-talk
Re: [EXTERNAL] Re: PVA connection problem Kasemir, Kay via Tech-talk
Prev: Alternative Glassman PS FJ option Han Lee via Tech-talk
Next: Re: Alternative Glassman PS FJ option Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <2023>  2024  2025  2026
Prev: Re: [EXTERNAL] Re: PVA connection problem Kasemir, Kay via Tech-talk
Next: Streamdevice reads weird 1 byte null data Hyung Jin Kim via Tech-talk
