1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: fanout is not working
From: "Tran, Phi Dung via Tech-talk" <tech-talk at aps.anl.gov>
To: "Pearson, Matthew" <pearsonmr at ornl.gov>, "Goetze, Kurt A." <goetze at anl.gov>
Cc: Tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 1 Nov 2023 14:20:51 +0000
Hi Matthew,
I changed TWV to REL and used caput to test each motor separately since I want to make relative motions.  I just added DOL into my fanout field but it did not work either.  I used caput to $(P)-F, it updated to the new value however the motors did not move! P=XF:19IDC-ES-GO{Ymove}Mtr for the macro.
Phi
Sent: Wednesday, November 1, 2023 9:59 AM
To: Goetze, Kurt A. <goetze at anl.gov>; Tran, Phi Dung <ptran1 at bnl.gov>
Subject: RE: fanout is not working
Are you sure writing the position to $(M).TWF actually works with caput? Normally TWF (and TWR) just accept a ‘1’ to initiate a relative move specified by the distance in TWV. If the 3 motors are moving, they may just be moving a TWV relative distance.
What you may want is this instead?
record(dfanout, "$(P)-F") {
    field(DESC, "move ib,ob,ds MTR")
    field(OUTA, "$(OUTBOARDMTR) PP MS")
    field(OUTB, "$(INBOARDMTR) PP MS")
    field(OUTC, "$(DOWNSTREAMMTR) PP MS")
Cheers,
Matt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Goetze, Kurt via Tech-talk
Sent: Tuesday, October 31, 2023 1:48 PM
To: Tran, Phi Dung <ptran1 at bnl.gov>
Subject: [EXTERNAL] RE: fanout is not working
Hi Phi,
You’re close, but I don’t think you can poke the motor record’s value into the dfanout that way.
One way you could do it is by processing the motor record, FLNK the motor record to the dfanout, and have the dfanout’s .DOL field set to the motor record’s .VAL field (NPP).  That may not be the exact solution but that’s the direction I would head.
Kurt
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Tran, Phi Dung via Tech-talk
Sent: Tuesday, October 31, 2023 11:31 AM
To: tech-talk at aps.anl.gov
Subject: fanout is not working
I have created a virtual motor and can successfully use the `caput` and `caget` commands to set and read its value, respectively. However, my `dfanout` record is not moving the motors with relative motions as expected. I have confirmed that the motors respond correctly when I use `caput` to directly interact with the fields in `dfanout`.
record(motor, "$(P)"){
      field(DTYP, "Soft Channel")
      field(DESC, "Move Y,ib,ob,ds mtrs")
      # Where to write the setpoint to
      # Output to upstream, inboard and outboard motors
      field(OUT, "$(P)-F PP MS")
      field(PREC,"7")
#Move Y motors ib,ob,ds in same direction
    field(OUTA, "$(OUTBOARDMTR).TWF PP MS")
    field(OUTB, "$(INBOARDMTR).TWF PP MS")
    field(OUTC, "$(DOWNSTREAMMTR).TWF PP MS")
    field(PREC, "7")
Please advice.
Thank you,
Phi
Re: fanout is not working Pete Jemian via Tech-talk
RE: fanout is not working Pearson, Matthew via Tech-talk
fanout is not working Tran, Phi Dung via Tech-talk
RE: fanout is not working Goetze, Kurt via Tech-talk
Prev: RE: fanout is not working Pearson, Matthew via Tech-talk
Next: Re: fanout is not working Pete Jemian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
ANJ, 01 Nov 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
