Hej Pedro,
That depends. There may be an easy way to do what you want –
on the driver level.
Are you using a model 3 driver ?
/Torsten
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "Nariyoshi, Pedro via Tech-talk" <tech-talk at aps.anl.gov>
Reply to: "Nariyoshi, Pedro" <nariyosh at frib.msu.edu>
Date: Tuesday, 28 November 2023 at 16:36
To: Kevin Peterson <kmpeters at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: Re: Simulated limit switches on motorSim motor
Hi Kevin,
I figured I could try to remove the SPC_NOMOD from the dbd (and a bo/calcout record to write to it), but it feels too hackish. What I was really trying to figure out is if there was a field I could put a link in
to set the limit switch fields (similar to RDBL/DINP/etc).
Sent: Tuesday, November 28, 2023 10:18:13 AM
To: Nariyoshi, Pedro; tech-talk at aps.anl.gov
[EXTERNAL] This email originated from outside of FRIB
Pedro,
The HLS/LLS/RHLS/RLLS fields are read-only.
Kevin
On 11/21/23 12:24, Nariyoshi, Pedro via Tech-talk wrote:
> Hi,
> I am working on creating virtual motors to control some slits. One
> problem I have is that I couldn't find a way to set the
> HLS/LLS/RHLS/RLLS fields. Is there a way to control these (whether
> having an input link to these values or a writing them directly with a
> calcout or bo record)?
> Thank you very much
> *Pedro Nariyoshi*
- Re: Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
- Simulated limit switches on motorSim motor Nariyoshi, Pedro via Tech-talk
- Re: Simulated limit switches on motorSim motor Kevin Peterson via Tech-talk
Re: "duty cycle" records Kevin Peterson via Tech-talk
<2023>
<2023>
ANJ, 28 Nov 2023 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
