1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Subject: Re: LabCA for MATLAB Installation error
To: tech-talk at aps.anl.gov
Cc: Giovanni Franzini <giovanni.franzini at lnf.infn.it>, Straumann Till Sascha via Tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 18 Dec 2023 10:26:47 +0100
Dear Giovanni  and all
I am also struggling to get LabCA to compile under Windows, and I found this thread from the summer.
Did you mange to get LabCA to work/compile with MINGW under windows 10?
Any hints on how to get this working are most welcome, I am normally using EPICS/Matlab under Linux but in this case I am stuck with windows, and would very much like a Matlab / EPICS integration.
Best
Bo
On 15-06-2023 08:41, Straumann Till Sascha via Tech-talk wrote:
Hi Giovanni.
I don't have a matlab license for windows, so I can't test this ATM.
You could try to simply delete and comment the
  typedef int pid_t;
and the following lines where 'getpid()'  is defined and _getpid declared.
I probably introduced these hacks a long time ago when windows didn't
declare these items yet.
Maybe Jim (on bcc) has additional recommendations - he has a lot of
experience with labca under windows.
HTH
- Till
On 14.06.23 14:35, Giovanni Franzini via Tech-talk wrote:
Hello,
I would like to have some help.
I am trying to install LabCA 3.8.1 with MATLAB 2023 in Windows10.
I have set my path in the RELEASE as
BASE_SUBDIR=/base/
EPICS_BASE=/c/msys64/home/Gio-Ufficio/base-7.0.7
MATLABDIR = /c/MATlink
(MATlink is a symbolic link to the installation directory: C:\Program
Files\MATLAB\R2023a)
MATLIB_SUBDIR = win64/mingw64
(I also tried win64/microsoft)
When I run make (through MSYS2 MINGW64 ) I get the following error:
$ make
make: git: No such file or directory
make -C ./configure install
make[1]: Entering directory
'/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure'
make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
     T_A=windows-x64-mingw install
make[2]: Entering directory
'/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
perl -CSD
/c/msys64/home/Gio-Ufficio/base-7.0.7/bin/windows-x64-mingw/convertRelease.p
l checkRelease
echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
make[2]: Leaving directory
make[1]: Leaving directory
make -C ./ezca install
make[1]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca'
'/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
make[2]: Nothing to be done for 'install'.
make[1]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca'
make -C ./glue install
make[1]: Entering directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue'
'/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
g++          -DMATLAB_APP    -D_MINGW -D__USE_MINGW_ANSI_STDIO      -O3
-Wall      -m64    -DEPICS_BUILD_DLL -DEPICS_CALL_DLL    -I. -I../O.Common
-I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32
-I../../include
-I/c/msys64/home/Gio-Ufficio/base-7.0.7/include/compiler/gcc
-I/c/msys64/home/Gio-Ufficio/base-7.0.7/include/os/WIN32
-I/c/msys64/home/Gio-Ufficio/base-7.0.7/include -I../../ezca
-I/c/MATlink/extern/include    -o ini.obj -c ../ini.cc
../ini.cc:22:13: error: conflicting declaration 'typedef int pid_t'
    22 | typedef int pid_t;
In file included from C:/msys64/mingw64/include/pthread.h:64,
                  from
C:/msys64/mingw64/include/c++/13.1.0/x86_64-w64-mingw32/bits/gthr-default.h:
35,
                  from
C:/msys64/mingw64/include/c++/13.1.0/x86_64-w64-mingw32/bits/gthr.h:148,
                  from
C:/msys64/mingw64/include/c++/13.1.0/ext/atomicity.h:35,
                  from
C:/msys64/mingw64/include/c++/13.1.0/bits/ios_base.h:39,
                  from C:/msys64/mingw64/include/c++/13.1.0/ios:44,
                  from C:/msys64/mingw64/include/c++/13.1.0/ostream:40,
                  from
C:/msys64/home/Gio-Ufficio/base-7.0.7/include/epicsTime.h:32,
                  from
C:/msys64/home/Gio-Ufficio/base-7.0.7/include/db_access.h:21,
                  from
C:/msys64/home/Gio-Ufficio/base-7.0.7/include/cadef.h:39,
                  from ../ini.cc:8:
C:/msys64/mingw64/include/sys/types.h:68:17: note: previous declaration as
'typedef _pid_t pid_t'
    68 | typedef _pid_t  pid_t;
../ini.cc:24:16: warning: 'int _getpid()' redeclared without dllimport
attribute: previous dllimport ignored [-Wattributes]
    24 | extern "C" int _getpid();
make[2]: ***
[/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_BUILD:263: ini.obj]
Error 1
make[1]: ***
[/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_ARCHS:58:
install.windows-x64-mingw] Error 2
make[1]: Leaving directory '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue'
make: *** [/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_DIRS:85:
glue.install] Error 2
Any idea on what is the problem?
Thank you
Giovanni
RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
LabCA for MATLAB Installation error Giovanni Franzini via Tech-talk
Re: LabCA for MATLAB Installation error Straumann Till Sascha via Tech-talk
Prev: Re: [EXTERNAL] EPICS vs. EPICS Base consistency on website? Johnson, Andrew N. via Tech-talk
Next: RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024
Prev: Cross-haired xy coordiate from XYGraph Zhang, Tong via Tech-talk
ANJ, 18 Dec 2023 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
