Hi Bo,
Do you see the same error as Giovanni saw, or are you getting a different build failure?
Freddie
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of boj via Tech-talk
Sent: 18 December 2023 09:27
To: [email protected]
Cc: Giovanni Franzini <[email protected]>; Straumann Till Sascha via Tech-talk <[email protected]>
Subject: Re: LabCA for MATLAB Installation error
Dear Giovanni and all
I am also struggling to get LabCA to compile under Windows, and I found this thread from the summer.
Did you mange to get LabCA to work/compile with MINGW under windows 10?
Any hints on how to get this working are most welcome, I am normally using EPICS/Matlab under Linux but in this case I am stuck with windows, and would very much like a Matlab / EPICS integration.
Best
Bo
On 15-06-2023 08:41, Straumann Till Sascha via Tech-talk wrote:
> Hi Giovanni.
> I don't have a matlab license for windows, so I can't test this ATM.
> You could try to simply delete and comment the
> typedef int pid_t;
> and the following lines where 'getpid()' is defined and _getpid
> declared.
> I probably introduced these hacks a long time ago when windows didn't
> declare these items yet.
> Maybe Jim (on bcc) has additional recommendations - he has a lot of
> experience with labca under windows.
> HTH
> - Till
> On 14.06.23 14:35, Giovanni Franzini via Tech-talk wrote:
>> Hello,
>> I would like to have some help.
>> I am trying to install LabCA 3.8.1 with MATLAB 2023 in Windows10.
>> I have set my path in the RELEASE as
>> BASE_SUBDIR=/base/
>> EPICS_BASE=/c/msys64/home/Gio-Ufficio/base-7.0.7
>> MATLABDIR = /c/MATlink
>> (MATlink is a symbolic link to the installation directory: C:\Program
>> Files\MATLAB\R2023a)
>> MATLIB_SUBDIR = win64/mingw64
>> (I also tried win64/microsoft)
>> When I run make (through MSYS2 MINGW64 ) I get the following error:
>> $ make
>> make: git: No such file or directory
>> make -C ./configure install
>> make[1]: Entering directory
>> '/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure'
>> make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
>> T_A=windows-x64-mingw install
>> make[2]: Entering directory
>> '/home/Gio-Ufficio/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
>> perl -CSD
>> /c/msys64/home/Gio-Ufficio/base-7.0.7/bin/windows-x64-mingw/convertRe
>> lease.p
>> l checkRelease
>> echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
>> make[2]: Leaving directory
>> make[1]: Leaving directory
>> make -C ./ezca install
>> '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca'
>> '/home/Gio-Ufficio/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
>> make[2]: Nothing to be done for 'install'.
>> make -C ./glue install
>> '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue'
>> '/home/Gio-Ufficio/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
>> g++ -DMATLAB_APP -D_MINGW -D__USE_MINGW_ANSI_STDIO
>> g++-O3
>> -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I.
>> -I../O.Common
>> -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32
>> -I../../include
>> -I/c/msys64/home/Gio-Ufficio/base-7.0.7/include/compiler/gcc
>> -I/c/msys64/home/Gio-Ufficio/base-7.0.7/include/os/WIN32
>> -I/c/msys64/home/Gio-Ufficio/base-7.0.7/include -I../../ezca
>> -I/c/MATlink/extern/include -o ini.obj -c ../ini.cc
>> ../ini.cc:22:13: error: conflicting declaration 'typedef int pid_t'
>> 22 | typedef int pid_t;
>> In file included from C:/msys64/mingw64/include/pthread.h:64,
>> from
>> C:/msys64/mingw64/include/c++/13.1.0/x86_64-w64-mingw32/bits/gthr-default.h:
>> 35,
>> from
>> C:/msys64/mingw64/include/c++/13.1.0/x86_64-w64-mingw32/bits/gthr.h:1
>> 48,
>> from
>> C:/msys64/mingw64/include/c++/13.1.0/ext/atomicity.h:35,
>> from
>> C:/msys64/mingw64/include/c++/13.1.0/bits/ios_base.h:39,
>> from C:/msys64/mingw64/include/c++/13.1.0/ios:44,
>> from
>> C:/msys64/mingw64/include/c++/13.1.0/ostream:40,
>> from
>> C:/msys64/home/Gio-Ufficio/base-7.0.7/include/epicsTime.h:32,
>> from
>> C:/msys64/home/Gio-Ufficio/base-7.0.7/include/db_access.h:21,
>> from
>> C:/msys64/home/Gio-Ufficio/base-7.0.7/include/cadef.h:39,
>> from ../ini.cc:8:
>> C:/msys64/mingw64/include/sys/types.h:68:17: note: previous
>> declaration as 'typedef _pid_t pid_t'
>> 68 | typedef _pid_t pid_t;
>> ../ini.cc:24:16: warning: 'int _getpid()' redeclared without
>> dllimport
>> attribute: previous dllimport ignored [-Wattributes]
>> 24 | extern "C" int _getpid();
>> make[2]: ***
>> [/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_BUILD:263:
>> ini.obj]
>> Error 1
>> make[1]: ***
>> [/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_ARCHS:58:
>> install.windows-x64-mingw] Error 2
>> make: ***
>> [/c/msys64/home/Gio-Ufficio/base-7.0.7/configure/RULES_DIRS:85:
>> glue.install] Error 2
>> Any idea on what is the problem?
>> Thank you
>> Giovanni
- Re: LabCA for MATLAB Installation error boj via Tech-talk
- LabCA for MATLAB Installation error Giovanni Franzini via Tech-talk
- Re: LabCA for MATLAB Installation error Straumann Till Sascha via Tech-talk
sscan mda format convert 顾月良 via Tech-talk
<2023>
2025
2026
<2023>
2025
2026
