Hi, I think it may just be missing an epicsShareFunc for lcaMexGblInit() - I have pushed an addition to the same branch
Freddie
-----Original Message-----
Sent: 03 January 2024 14:39
To: Akeroyd, Freddie (STFC,RAL,ISIS) <[email protected]>; Michael Davidsaver <[email protected]>; Mark Rivers <[email protected]>; [email protected]
Cc: Giovanni Franzini <[email protected]>
Subject: Re: LabCA for MATLAB Installation error
Dear Freddie and all
The supplied patch did indeed help and the build process proceeded
further on.
Unfortunately I still run into an error
The "Relevant part" of the output is (as I understand it), the Full
output is give at the bottom for context :
make -C ./matlab install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/matlab'
The system cannot find the path specified.
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/makeMakefile.pl
O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
make[2]: Entering directory
'd:/EPICS/epics-labca-labca_3_8_1/matlab/O.windows-x64'
D:/Matlab2022a/bin/mex.bat CXXFLAGS= -DMATLAB_APP ../lcaGetNelem.c -I.
-I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
-I../../include/os/WIN32 -I../../include
-ID:/EPICS/base-3.15.9/include/compiler/msvc
-ID:/EPICS/base-3.15.9/include/os/WIN32
-ID:/EPICS/base-3.15.9/include -I../../ezca -I../../glue
LDFLAGS=" \$LDFLAGS" ../../lib/windows-x64/mezcaglue.lib
../../lib/windows-x64/ezcamt.lib
D:/EPICS/base-3.15.9/lib/windows-x64/ca.lib
D:/EPICS/base-3.15.9/lib/windows-x64/Com.lib
Building with 'Microsoft Visual C++ 2022 (C)'.
Creating library lcaGetNelem.lib and object lcaGetNelem.exp
lcaGetNelem.obj : error LNK2019: unresolved external symbol
lcaMexGblInit referenced in function mexFunction
lcaGetNelem.mexw64 : fatal error LNK1120: 1 unresolved externals
make[2]: *** [../Makefile:116: lcaGetNelem.mexw64] Error -1
make[2]: Leaving directory
make[1]: *** [D:/EPICS/base-3.15.9/configure/RULES_ARCHS:58:
install.windows-x64] Error 2
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/matlab'
make: *** [D:/EPICS/base-3.15.9/configure/RULES_DIRS:85: matlab.install]
Error 2
which seems to be an issue compiling the mex files. Maybe in
inkompertibility between version of the components?
Thanks again for your help and input on getting this to work.
Best
Bo
Full make output:
d:\EPICS\epics-labca-labca_3_8_1>make
process_begin: CreateProcess(NULL, git describe, ...) failed.
makefile:24: pipe: No error
make -C ./configure install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
O.windows-x64 ../..
'd:/EPICS/epics-labca-labca_3_8_1/configure/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/convertRelease.pl
checkRelease
echo MEXEXT=.mexw64 >>MATLAB_CONFIG_INCLUDE
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/configure'
make -C ./ezca install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
O.windows-x64 ../..
'd:/EPICS/epics-labca-labca_3_8_1/ezca/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m ezca.d -I.
-ID:/EPICS/base-3.15.9/include ezca.obj ../ezca.c
cl -nologo -FC -D__STDC__=0 -D_CRT_SECURE_NO_DEPRECATE
-D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy- -W3 -MD
-DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I. -I..
-I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include
-ID:/EPICS/base-3.15.9/include -c ../ezca.c
ezca.c
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(570): warning C4311: 'type
cast': pointer truncation from 'epicsThreadId' to 'unsigned long'
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(575): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(612): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(618): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(713): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(715): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4905): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(4934): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5032): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5034): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5529): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5546): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5590): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5595): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5697): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5716): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(5755): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6963): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(6999): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7191): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7217): warning C4311: 'type
d:\EPICS\epics-labca-labca_3_8_1\ezca\ezca.c(7263): warning C4311: 'type
link -nologo -subsystem:windows -dll -LTCG -incremental:no -opt:ref
-release -MACHINE:X64 -out:ezcamt.dll -implib:ezcamt.lib
ezca.obj D:/EPICS/base-3.15.9/lib/windows-x64/ca.lib
Creating library ezcamt.lib and object ezcamt.exp
Generating code
Finished generating code
"Installing shared library ../../bin/windows-x64/ezcamt.dll"
mkdir ../../bin
mkdir ../../bin/windows-x64
"Installing library ../../lib/windows-x64/ezcamt.lib"
mkdir ../../lib
mkdir ../../lib/windows-x64
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/ezca'
make -C ./glue install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
O.windows-x64 ../..
'd:/EPICS/epics-labca-labca_3_8_1/glue/O.windows-x64'
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m ini.d -I.
-ID:/Matlab2022a/extern/include ini.obj ../ini.cc
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m multiEzca.d
-I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc
-ID:/Matlab2022a/extern/include multiEzca.obj ../multiEzca.c
ctrlC-polled.d -I. -I../O.Common -I. -I. -I..
-ID:/Matlab2022a/extern/include ctrlC-polled.obj ../ctrlC-polled.c
perl -CSD -MExtUtils::Command -e rm_f gitstring.c.new
perl > gitstring.c.new -e "print(\"const char *gitRevisionString =
\\\"labca_3_8_1 - ef74a39\\\";\n\")" > gitstring.c.new
perl -MFile::Compare -e 'exit( compare(@ARGV[0],@ARGV[1]) )'
gitstring.c.new gitstring.c || perl -e "unlink(\"gitstring.c\");
rename(\"gitstring.c.new\",\"gitstring.c\")"
Can't find string terminator "'" anywhere before EOF at -e line 1.
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m gitstring.d
-ID:/Matlab2022a/extern/include gitstring.obj gitstring.c
perl -CSD D:/EPICS/base-3.15.9/bin/windows-x64/mkmf.pl -m mglue.d -I.
-ID:/Matlab2022a/extern/include mglue.obj ../mglue.c
cl -EHsc -GR -DMATLAB_APP -nologo -FC -D__STDC__=0
-D_CRT_SECURE_NO_DEPRECATE -D_CRT_NONSTDC_NO_DEPRECATE -Ox -GL -Oy-
-W3 -w44355 -w44344 -w44251 -MD -DEPICS_BUILD_DLL
-DEPICS_CALL_DLL -TP -I. -I../O.Common -I. -I. -I..
-ID:/Matlab2022a/extern/include -c ../ini.cc
ini.cc
cl -DMATLAB_APP -nologo -FC -D__STDC__=0
-W3 -MD -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common
-I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32
-I../../include -ID:/EPICS/base-3.15.9/include/compiler/msvc
-ID:/Matlab2022a/extern/include -c ../multiEzca.c
multiEzca.c
d:\EPICS\epics-labca-labca_3_8_1\glue\multiEzca.c(27): warning C4005:
'isnan': macro redefinition
D:\Windows Kits\10\include\10.0.22621.0\ucrt\corecrt_math.h(280): note:
see previous definition of 'isnan'
D:\Matlab2022a\extern\include\mex.h(197): warning C4005: 'printf': macro
redefinition
D:\EPICS\base-3.15.9\include\epicsStdio.h(41): note: see previous
definition of 'printf'
-ID:/Matlab2022a/extern/include -c ../ctrlC-polled.c
ctrlC-polled.c
-ID:/Matlab2022a/extern/include -c gitstring.c
gitstring.c
-ID:/Matlab2022a/extern/include -c ../mglue.c
mglue.c
D:/Matlab2022a/extern/lib/win64/microsoft/libut.lib
D:/Matlab2022a/extern/lib/win64/microsoft/libmx.lib
D:/Matlab2022a/extern/lib/win64/microsoft/libmex.lib -out:mezcaglue.dll
-implib:mezcaglue.lib ini.obj multiEzca.obj ctrlC-polled.obj
gitstring.obj mglue.obj ../../lib/windows-x64/ezcamt.lib
D:/EPICS/base-3.15.9/lib/windows-x64/Com.lib user32.lib
Creating library mezcaglue.lib and object mezcaglue.exp
Generating code
"Installing shared library ../../bin/windows-x64/mezcaglue.dll"
"Installing library ../../lib/windows-x64/mezcaglue.lib"
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/glue'
make -C ./documentation install
make[1]: Entering directory 'd:/EPICS/epics-labca-labca_3_8_1/documentation'
process_begin: CreateProcess(NULL, sed -n -e "s/\(.*[^b]subsection.*[{][
\t]*\)\(lca[a-zA-Z0-9]*\).*/\2/gp" manual.tex, ...) failed.
makefile:61: pipe: No error
\t]*\)\(lca[a-zA-Z0-9]*\)\(,\slca[a-zA-Z0-9]*\).*/\2/gp" manual.tex,
...) failed.
makefile:68: pipe: No error
\t]*\)\(lca[a-zA-Z0-9]*\)\(,\s\)\(lca[a-zA-Z0-9]*\).*/\4/gp" manual.tex,
...) failed.
makefile:70: pipe: No error
make[1]: 'install' is up to date.
make[1]: Leaving directory 'd:/EPICS/epics-labca-labca_3_8_1/documentation'
O.windows-x64 ../..
Error 2
On 03-01-2024 13:25, Freddie Akeroyd - STFC UKRI via Tech-talk wrote:
> Yes https://github.com/till-s/epics-labca/blob/7915ca4769f49eee1ceba77493ee3cda6bf2a51b/glue/Makefile#L204 uses "(" to run commands in a subprocess and that is /bin/sh specific
> Bo, does applying this change help?
> https://github.com/till-s/epics-labca/compare/master...FreddieAkeroyd:epics-labca:fix_windows_quoting
> Regards,
> Freddie
> From: Tech-talk <[email protected]> On Behalf Of Michael Davidsaver via Tech-talk
> Sent: 03 January 2024 01:29
> To: Mark Rivers <[email protected]>
> Cc: Giovanni Franzini <[email protected]>; [email protected]
> On 1/2/24 08:28, Mark Rivers via Tech-talk wrote:
>> Hi Bo,
>> The fatal error you are getting is because gitstring.c does not exist. But I think that is due to a non-fatal error earlier in the output:
>> gitstring.c.new gitstring.c || (perl -CSD -MExtUtils::Command -e rm_f
>> gitstring.c; perl -e 'rename("gitstring.c.new","gitstring.c")')
>> ') was unexpected at this time.
> Isn't "... was unexpected at this time" a cmd shell error?
> I guess this Makefile assumes SHELL=/bin/sh ?
>> So I think it is trying to rename gitstring.c.new to gitstring.c and that is failing. I think a perl expert is needed to help here?
>> Mark
>> From: Tech-talk <[email protected]> On Behalf Of boj via Tech-talk
>> Sent: Tuesday, January 2, 2024 9:03 AM
>> To: [email protected]
>> Dear all
>> I am still trying to get LabCA (matlab framework for EPCIS) to work
>> under windows 10. Based on the input from Freddie, I decided to try with
>> the Visual Studio compiler.
>> All went well with compiling the base EPICS, but still no success on the
>> LabCA (however now new error).
>> The setup is now
>> * Windows 10
>> * Visual Studio 2022 with c++
>> * Matlab R2022a
>> * epics-labca-labca_3_8_1
>> * EPICS version base-3.15.9
>> * EPICS_HOST_ARCH = windows-x64
>> Problem now seems to be regarding "No rule to make target 'gitstring.c',
>> needed by 'gitstring.obj'" (full output from Make below)
>> I would be very happy if anyone which have succeeded in compiling LabCA
>> under windows 10, could give some hints to which setup works
>> Best regards
>> Bo
>> Output from make is now:
>> O.windows-x64 ../..
>> checkRelease
>> O.windows-x64 ../..
>> ezca.c
>> Generating code
>> O.windows-x64 ../..
>> ini.cc
>> multiEzca.c
>> redefinition
>> ctrlC-polled.c
>> make[2]: *** No rule to make target 'gitstring.c', needed by
>> 'gitstring.obj'. Stop.
>> make: *** [D:/EPICS/base-3.15.9/configure/RULES_DIRS:85: glue.install]
>> Error 2
>> On 19-12-2023 13:02, Freddie Akeroyd - STFC UKRI wrote:
>>> Hi Boj,
>>> I'm not a user of labca, but we do use EPICS on windows and I have used matlab in the past, so I'm basing my answers on this rather than anything I can actually test for you unfortunately
>>> The program is failing to link as it cannot find some functions from the matlab mex/mx libraries, I see that libmx.lib and libmex.lib are included on the command line but these files will be in Microsoft import library format and gcc/mingw didn't used to read this format, hence why you may be getting undefined symbols. Normally with gcc/mingw you would be linking as e.g. -lmex and it would locate a libmex.dll.a file to reference libmex.dll If you were using the visual studio window compiler then it may work better as .lib is its native format. Does matlab provide *.dll.a files or just *.lib and *.dll ? You can create a mingw compatible .dll.a file the following way from the mingw shell
>>> # create libmex.def
>>> gendef libmex.dll
>>> # create libmex.dll.a from libmex.def
>>> dlltool --def libmex.def --output-lib libmex.dll.a
>>> (in some cases the -k argument may also be needed with dlltool, add that if you still get link undefined errors using libmex.dll.a)
>>> At one point I think it was possible to link directly against a dll in mingw and it would auto import, but I am not sure if that is still the case i.e. You would link against /d/Matlab2022a/extern/lib/win64/mingw64/libmx.dll rather than /d/Matlab2022a/extern/lib/win64/mingw64/libmx.lib however creating a .dll.a is probably the better approach
>>> Regards,
>>> Freddie
>>>> From: boj <[email protected]>
>>>> Sent: 19 December 2023 10:45
>>>> I looked a bit more carefully at the errors, and here are some details,
>>>> unfortunately I am not very skilled in either c/c++ programming or windows
>>>> programming, so that makes it hard for me to understand what is important.
>>>> The setup is:
>>>> * Windows 10
>>>> * MSYS2 MINGW64 compiler "complex" as recommended for the EPICS part
>>>> * Matlab R2022a
>>>> In the labca source code I have set
>>>> configure/RELEASE
>>>> BASE_SUBDIR=
>>>> EPICS_BASE=/home/boj/base-3.15.9/
>>>> MATLABDIR = /d/Matlab2022a
>>>> MATLIB_SUBDIR=win64/mingw64
>>>> In my .bash_profile for MSYS2 I have
>>>> EPICS_HOST_ARCH=windows-x64-mingw
>>>> PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
>>>> EPICS command line tools works
>>>> Included at the end of this mail is the full output of make, but as I understand
>>>> it the problem is in the linking of mezcaglue.dll I get:
>>>> gcc -DMATLAB_APP -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3 -
>>>> Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I.
>>>> -I.. -I../../include/compiler/gcc -I../../include/os/WIN32 -I../../include -
>>>> I/home/boj/base-3.15.9/include/compiler/gcc
>>>> -I/home/boj/base-3.15.9/include/os/WIN32
>>>> -I/home/boj/base-3.15.9/include -I../../ezca -
>>>> I/d/Matlab2022a/extern/include -o mglue.obj -c ../mglue.c
>>>> g++ -o mezcaglue.dll -shared -Wl,--out-implib,libmezcaglue.dll.a
>>>> -L/home/boj/epics-labca-labca_3_8_1/lib/windows-x64-mingw
>>>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw
>>>> /d/Matlab2022a/extern/lib/win64/mingw64/libut.lib
>>>> /d/Matlab2022a/extern/lib/win64/mingw64/libmex.lib -m64 ini.obj
>>>> multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj -lezcamt -lca -lCom -
>>>> luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>>>> C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-
>>>> mingw32/13.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe
>>>> : ini.obj:ini.cc:(.text+0x9b): undefined reference to `mexPrintf_800'
>>>> : ini.obj:ini.cc:(.text+0xfe): undefined reference to `mexCallMATLAB_800'
>>>> Which then continues with "undefined reference to `XXXX" for many lines and
>>>> end with
>>>> collect2.exe: error: ld returned 1 exit status
>>>> make[2]: *** [/home/boj/base-3.15.9/configure/RULES_BUILD:292:
>>>> mezcaglue.dll] Error 1
>>>> '/home/boj/epics-labca-labca_3_8_1/glue/O.windows-x64-mingw'
>>>> make[1]: *** [/home/boj/base-3.15.9/configure/RULES_ARCHS:58:
>>>> install.windows-x64-mingw] Error 2
>>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/glue'
>>>> make: *** [/home/boj/base-3.15.9/configure/RULES_DIRS:85: glue.install]
>>>> Error 2
>>>> I hope this makes sence, and maybe can give a hint to what I am dooing
>>>> wrong.
>>>> Best regards
>>>> Bo
>>>> Full output of make:
>>>> boj@dk1080799 MINGW64 ~/epics-labca-labca_3_8_1 $ make
>>>> make: git: No such file or directory
>>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/configure'
>>>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/makeMakefile.pl
>>>> O.windows-x64-mingw ../..
>>>> perl -CSD -MExtUtils::Command -e mkpath O.Common make -C O.windows-
>>>> x64-mingw -f ../Makefile TOP=../.. \
>>>> T_A=windows-x64-mingw install
>>>> '/home/boj/epics-labca-labca_3_8_1/configure/O.windows-x64-mingw'
>>>> perl -CSD /home/boj/base-3.15.9/bin/windows-x64-mingw/convertRelease.pl
>>>> checkRelease
>>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/configure'
>>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>>>> '/home/boj/epics-labca-labca_3_8_1/ezca/O.windows-x64-mingw'
>>>> gcc -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3 -Wall
>>>> -I/home/boj/base-3.15.9/include -MM -MF ezca.d -MT ezca.obj
>>>> ../ezca.c gcc -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3 -Wall
>>>> -I/home/boj/base-3.15.9/include -o ezca.obj -c ../ezca.c
>>>> ../ezca.c: In function 'ezcaLock':
>>>> ../ezca.c:89:25: warning: cast from pointer to integer of different size [-
>>>> Wpointer-to-int-cast]
>>>> 89 | (unsigned long)epicsThreadGetIdSelf()); \
>>>> ../ezca.c:570:9: note: in expansion of macro 'EZCA_LOCK'
>>>> 570 | EZCA_LOCK();
>>>> ../ezca.c: In function 'ezcaUnlock':
>>>> ../ezca.c:575:9: note: in expansion of macro 'EZCA_LOCK'
>>>> 575 | EZCA_LOCK();
>>>> ../ezca.c: In function 'ezcaPollCbInstall':
>>>> ../ezca.c:612:9: note: in expansion of macro 'EZCA_LOCK'
>>>> 612 | EZCA_LOCK();
>>>> ../ezca.c:611:1: warning: this 'if' clause does not guard...
>>>> [-Wmisleading-indentation]
>>>> 611 | if ( (i=Initialized) )
>>>> ../ezca.c:614:9: note: ...this statement, but the latter is misleadingly indented
>>>> as if it were guar ded by the 'if'
>>>> 614 | rval = pollCb;
>>>> ../ezca.c:97:25: warning: cast from pointer to integer of different size [-
>>>> 97 | (unsigned long)epicsThreadGetIdSelf()); \
>>>> ../ezca.c:618:9: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 618 | EZCA_UNLOCK();
>>>> ../ezca.c:617:1: warning: this 'if' clause does not guard...
>>>> 617 | if (i)
>>>> ../ezca.c:620:9: note: ...this statement, but the latter is misleadingly indented
>>>> 620 | return rval;
>>>> ../ezca.c: In function 'ezcaEndGroupWithReport':
>>>> ../ezca.c:713:33: note: in expansion of macro 'EZCA_LOCK'
>>>> 713 | EZCA_LOCK(); /* make *sure* mutex is not
>>>> relinquished by add ing a nest count */
>>>> ../ezca.c:715:33: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 715 | EZCA_UNLOCK();
>>>> ../ezca.c:966:13: warning: this 'if' clause does not guard...
>>>> 966 | if (Trace || Debug)
>>>> ../ezca.c:104:29: note: ...this statement, but the latter is misleadingly indented
>>>> as if it were gua rded by the 'if'
>>>> 104 | #define MARK_OUTSTANDING(n) do { if ( (ezcaOutstanding = (n)) )
>>>> ca_flush_io(); } while (0)
>>>> ../ezca.c:969:17: note: in expansion of macro 'MARK_OUTSTANDING'
>>>> 969 | MARK_OUTSTANDING(needs_work);
>>>> ../ezca.c:1063:29: warning: this 'if' clause does not guard...
>>>> 1063 | if (AutoErrorMessage)
>>>> ../ezca.c:1066:33: note: ...this statement, but the latter is misleadingly
>>>> indented as if it were gu arded by the 'if'
>>>> 1066 | if ( MONBLOCK == wp->worktype && wp->pval )
>>>> ../ezca.c: In function 'prologue':
>>>> ../ezca.c:4905:9: note: in expansion of macro 'EZCA_LOCK'
>>>> 4905 | EZCA_LOCK();
>>>> ../ezca.c: In function 'epilogue':
>>>> ../ezca.c:4934:9: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 4934 | EZCA_UNLOCK();
>>>> ../ezca.c: In function 'EzcaClearChannel':
>>>> ../ezca.c:5032:9: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 5032 | EZCA_UNLOCK();
>>>> ../ezca.c:5034:9: note: in expansion of macro 'EZCA_LOCK'
>>>> 5034 | EZCA_LOCK();
>>>> ../ezca.c: In function 'EzcaPendEvent':
>>>> ../ezca.c:5519:5: warning: this 'if' clause does not guard...
>>>> 5519 | if (Trace || Debug)
>>>> ../ezca.c:5522:9: note: ...this statement, but the latter is misleadingly indented
>>>> 5522 | if ( pollCb && pollCb() ) {
>>>> ../ezca.c:5529:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 5529 | EZCA_UNLOCK();
>>>> ../ezca.c:5546:1: note: in expansion of macro 'EZCA_LOCK'
>>>> 5546 | EZCA_LOCK();
>>>> ../ezca.c: In function 'EzcaPendIO':
>>>> ../ezca.c:5584:5: warning: this 'if' clause does not guard...
>>>> 5584 | if (Trace || Debug)
>>>> ../ezca.c:5587:9: note: ...this statement, but the latter is misleadingly indented
>>>> 5587 | if ( pollCb && pollCb() ) {
>>>> ../ezca.c:5590:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 5590 | EZCA_UNLOCK();
>>>> ../ezca.c:5595:1: note: in expansion of macro 'EZCA_LOCK'
>>>> 5595 | EZCA_LOCK();
>>>> ../ezca.c: In function 'my_connection_callback':
>>>> ../ezca.c:5697:1: note: in expansion of macro 'EZCA_LOCK'
>>>> 5697 | EZCA_LOCK();
>>>> ../ezca.c:5716:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 5716 | EZCA_UNLOCK();
>>>> ../ezca.c: In function 'my_get_callback':
>>>> ../ezca.c:5755:1: note: in expansion of macro 'EZCA_LOCK'
>>>> 5755 | EZCA_LOCK();
>>>> ../ezca.c:6949:13: warning: this 'if' clause does not guard...
>>>> 6949 | if (Trace || Debug)
>>>> ../ezca.c:6951:17: note: ...this statement, but the latter is misleadingly
>>>> 6951 | recycle_work(wp);
>>>> ../ezca.c:6963:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 6963 | EZCA_UNLOCK();
>>>> ../ezca.c: In function 'my_monitor_callback':
>>>> ../ezca.c:6999:1: note: in expansion of macro 'EZCA_LOCK'
>>>> 6999 | EZCA_LOCK();
>>>> ../ezca.c:7191:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 7191 | EZCA_UNLOCK();
>>>> ../ezca.c: In function 'my_put_callback':
>>>> ../ezca.c:7217:1: note: in expansion of macro 'EZCA_LOCK'
>>>> 7217 | EZCA_LOCK();
>>>> ../ezca.c:7249:13: warning: this 'if' clause does not guard...
>>>> 7249 | if (Trace || Debug)
>>>> ../ezca.c:7251:17: note: ...this statement, but the latter is misleadingly
>>>> 7251 | recycle_work(wp);
>>>> ../ezca.c:7263:1: note: in expansion of macro 'EZCA_UNLOCK'
>>>> 7263 | EZCA_UNLOCK();
>>>> ../ezca.c: In function 'print_discarded_channels':
>>>> ../ezca.c:7886:5: warning: this 'for' clause does not guard...
>>>> 7886 | for (cp = Discarded_channels; cp; cp = cp->next)
>>>> ../ezca.c:7888:9: note: ...this statement, but the latter is misleadingly indented
>>>> as if it were gua rded by the 'for'
>>>> 7888 | printf("\n");
>>>> g++ -o ezcamt.dll -shared -Wl,--out-implib,libezcamt.dll.a
>>>> -L/home/boj/base-3.15.9/lib/windows-x64-mingw -m64
>>>> ezca.obj -lca -lCom -lws2_32 -ladvapi32 -luser32 -lkernel32 -lwinmm
>>>> Installing shared library ../../bin/windows-x64-mingw/ezcamt.dll
>>>> mkdir ../../bin
>>>> mkdir ../../bin/windows-x64-mingw
>>>> Installing DLL stub library ../../lib/windows-x64-mingw/libezcamt.dll.a
>>>> mkdir ../../lib
>>>> mkdir ../../lib/windows-x64-mingw
>>>> make[1]: Leaving directory '/home/boj/epics-labca-labca_3_8_1/ezca'
>>>> make[1]: Entering directory '/home/boj/epics-labca-labca_3_8_1/glue'
>>>> make -C O.windows-x64-mingw -f ../Makefile TOP=../.. \
>>>> g++ -DMATLAB_APP -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3
>>>> -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common
>>>> -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/WIN32
>>>> -I../../include -I/home/boj/base-3.15.9/include/compiler/gcc
>>>> -I/d/Matlab2022a/extern/include -MM -MF ini.d -MT ini.obj ../ini.cc
>>>> -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc
>>>> -I/d/Matlab2022a/extern/include -MM -MF multiEzca.d -MT
>>>> -I/d/Matlab2022a/extern/include -MM -MF ctrlC-polled.d -MT
>>>> -I/d/Matlab2022a/extern/include -MM -MF gitstring.d -MT
>>>> -I/d/Matlab2022a/extern/include -MM -MF mglue.d -MT mglue.obj
>>>> ../mglue.c
>>>> -I/d/Matlab2022a/extern/include -o ini.obj -c ../ini.cc
>>>> -I/d/Matlab2022a/extern/include -o multiEzca.obj -c ../multiEzca.c
>>>> ../multiEzca.c:27: warning: "isnan" redefined
>>>> 27 | #define isnan _isnan
>>>> In file included from ../multiEzca.c:13:
>>>> C:/msys64/mingw64/include/math.h:586: note: this is the location of the
>>>> previous definition
>>>> 586 | #define isnan(x) \
>>>> In file included from ../multiEzca.c:32:
>>>> D:/Matlab2022a/extern/include/mex.h:197: warning: "printf" redefined
>>>> 197 | #define printf mexPrintf
>>>> In file included from ../multiEzca.c:24:
>>>> C:/msys64/home/boj/base-3.15.9/include/epicsStdio.h:41: note: this is
>>>> the location of the previous d
>>>> efinition
>>>> 41 | # define printf epicsStdoutPrintf
>>>> -I/d/Matlab2022a/extern/include -o ctrlC-polled.obj -c ../ctrlC-polled.c
>>>> -I/d/Matlab2022a/extern/include -o gitstring.obj -c gitstring.c
>>>> -I/d/Matlab2022a/extern/include -o mglue.obj -c ../mglue.c
>>>> ini.obj multiEzca.obj ctrlC-polled.obj gitstring.obj mglue.obj
>>>> -lezcamt -lca -lCom -luser32 -lws2_32 -ladvapi32 -luser32 -lkernel32
>>>> -lwinmm
>>>> : ini.obj:ini.cc:(.text+0x126): undefined reference to `mxGetScalar_800'
>>>> : ini.obj:ini.cc:(.text+0x1d9): undefined reference to `mexCallMATLAB_800'
>>>> : ini.obj:ini.cc:(.text+0x256): undefined reference to `mxGetScalar_800'
>>>> : ini.obj:ini.cc:(.text+0x37e): undefined reference to `mexCallMATLAB_800'
>>>> : ini.obj:ini.cc:(.text+0x39e): undefined reference to `mxGetScalar_800'
>>>> : ini.obj:ini.cc:(.text+0x4e6): undefined reference to `mexCallMATLAB_800'
>>>> : ini.obj:ini.cc:(.text+0x506): undefined reference to `mxGetScalar_800'
>>>> : ini.obj:ini.cc:(.text+0x5d0): undefined reference to
>>>> `mexCallMATLABWithTrap_800'
>>>> : ini.obj:ini.cc:(.text+0x5f7): undefined reference to `mxDestroyArray_800'
>>>> : ini.obj:ini.cc:(.text+0x678): undefined reference to `mexLock_800'
>>>> : ini.obj:ini.cc:(.text+0x6b1): undefined reference to `mexCallMATLAB_800'
>>>> : ini.obj:ini.cc:(.text+0x726): undefined reference to `mxIsChar_800'
>>>> : ini.obj:ini.cc:(.text+0x74e): undefined reference to `mxGetScalar_800'
>>>> : ini.obj:ini.cc:(.text+0x796): undefined reference to `mxGetN_800'
>>>> : ini.obj:ini.cc:(.text+0x7b9): undefined reference to `mxGetString_800'
>>>> : ini.obj:ini.cc:(.text+0x997): undefined reference to
>>>> : ini.obj:ini.cc:(.text+0x9c2): undefined reference to `mxDestroyArray_800'
>>>> : ini.obj:ini.cc:(.text+0xa48): undefined reference to `mexLock_800'
>>>> : ini.obj:ini.cc:(.text+0xa81): undefined reference to `mexCallMATLAB_800'
>>>> : ini.obj:ini.cc:(.text+0xb06): undefined reference to `mxIsChar_800'
>>>> : ini.obj:ini.cc:(.text+0xb36): undefined reference to `mxGetScalar_800'
>>>> : ini.obj:ini.cc:(.text+0xb86): undefined reference to `mxGetN_800'
>>>> : ini.obj:ini.cc:(.text+0xba9): undefined reference to `mxGetString_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x11d): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x145): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x3dd): undefined reference to
>>>> `mexPrintf_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x5c3): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x5db): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x6ea): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x914): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x91e): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x928): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0xe84): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1062): undefined reference to
>>>> `mxCalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x107a): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1238): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1242): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x124c): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1256): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1260): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x126a): more undefined references to
>>>> `mxFree_800' follow
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1326): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1346): undefined reference to
>>>> `mxCalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x136c): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x138e): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1847): undefined reference to
>>>> `mexPrintf_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x187f): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1e19): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1f51): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x1fe7): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x2063): undefined reference to
>>>> `mxCalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x322e): undefined reference to
>>>> `mxCalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x335b): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x35e4): undefined reference to
>>>> `mxMalloc_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x365a): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x3662): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x39d7): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x3ad4): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x3b42): undefined reference to
>>>> `mxFree_800'
>>>> : multiEzca.obj:multiEzca.c:(.text+0x3b68): more undefined references to
>>>> `mxFree_800' follow
>>>> : ctrlC-polled.obj:ctrlC-polled.c:(.text+0x5): undefined reference to
>>>> `utHandlePendingInterrupt'
>>>> : mglue.obj:mglue.c:(.text+0x29): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x38): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x9c): undefined reference to `mxIsCell_800'
>>>> : mglue.obj:mglue.c:(.text+0xac): undefined reference to `mxIsCell_800'
>>>> : mglue.obj:mglue.c:(.text+0xbc): undefined reference to `mxIsCell_800'
>>>> : mglue.obj:mglue.c:(.text+0xd3): undefined reference to `mxCalloc_800'
>>>> : mglue.obj:mglue.c:(.text+0xf4): undefined reference to `mxIsChar_800'
>>>> : mglue.obj:mglue.c:(.text+0x100): undefined reference to `mxGetM_800'
>>>> : mglue.obj:mglue.c:(.text+0x10e): undefined reference to `mxGetN_800'
>>>> : mglue.obj:mglue.c:(.text+0x11b): undefined reference to `mxMalloc_800'
>>>> : mglue.obj:mglue.c:(.text+0x136): undefined reference to `mxGetString_800'
>>>> : mglue.obj:mglue.c:(.text+0x156): undefined reference to `mxIsCell_800'
>>>> : mglue.obj:mglue.c:(.text+0x165): undefined reference to `mxGetCell_800'
>>>> : mglue.obj:mglue.c:(.text+0x1a9): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x1b8): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x1e4): undefined reference to `mxGetN_800'
>>>> : mglue.obj:mglue.c:(.text+0x214): undefined reference to `mxIsChar_800'
>>>> : mglue.obj:mglue.c:(.text+0x241): undefined reference to `mxGetM_800'
>>>> : mglue.obj:mglue.c:(.text+0x24c): undefined reference to `mxIsCell_800'
>>>> : mglue.obj:mglue.c:(.text+0x266): undefined reference to `mxCalloc_800'
>>>> : mglue.obj:mglue.c:(.text+0x2e4): undefined reference to `mxIsChar_800'
>>>> : mglue.obj:mglue.c:(.text+0x404): undefined reference to `mxIsChar_800'
>>>> : mglue.obj:mglue.c:(.text+0x41b): undefined reference to `mxGetString_800'
>>>> : mglue.obj:mglue.c:(.text+0x510): undefined reference to
>>>> : mglue.obj:mglue.c:(.text+0x581): undefined reference to `mxGetN_800'
>>>> : mglue.obj:mglue.c:(.text+0x58e): undefined reference to `mxGetM_800'
>>>> : mglue.obj:mglue.c:(.text+0x59b): undefined reference to `mxIsChar_800'
>>>> : mglue.obj:mglue.c:(.text+0x5ae): undefined reference to `mxIsCell_800'
>>>> : mglue.obj:mglue.c:(.text+0x5d5): undefined reference to `mxCalloc_800'
>>>> : mglue.obj:mglue.c:(.text+0x5fc): undefined reference to `mxGetM_800'
>>>> : mglue.obj:mglue.c:(.text+0x60a): undefined reference to `mxGetN_800'
>>>> : mglue.obj:mglue.c:(.text+0x617): undefined reference to `mxMalloc_800'
>>>> : mglue.obj:mglue.c:(.text+0x632): undefined reference to `mxGetString_800'
>>>> : mglue.obj:mglue.c:(.text+0x652): undefined reference to `mxGetCell_800'
>>>> : mglue.obj:mglue.c:(.text+0x65d): undefined reference to `mxIsChar_800'
>>>> : mglue.obj:mglue.c:(.text+0x699): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x6a6): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x6b3): undefined reference to
>>>> : mglue.obj:mglue.c:(.text+0x6d9): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x6ea): undefined reference to `mxFree_800'
>>>> : mglue.obj:mglue.c:(.text+0x71b): undefined reference to
>>>> `mxCreateCellMatrix_800'
>>>> : mglue.obj:mglue.c:(.text+0x732): undefined reference to
>>>> `mxDuplicateArray_800'
>>>> : mglue.obj:mglue.c:(.text+0x73f): undefined reference to `mxSetCell_800'
>>>> : mglue.obj:mglue.c:(.text+0x759): undefined reference to `mxIsCell_800'
>>>> : mglue.obj:mglue.c:(.text+0x76d): undefined reference to `mxIsDouble_800'
>>>> : mglue.obj:mglue.c:(.text+0x8b5): undefined reference to `mxGetPr_800'
>>>> Error 2
>>>> On 18-12-2023 18:49, Freddie Akeroyd - STFC UKRI wrote:
>>>>> Hi Bo,
>>>>> Do you see the same error as Giovanni saw, or are you getting a different
>>>> build failure?
>>>>> Regards,
>>>>> Freddie
- Re: LabCA for MATLAB Installation error boj via Tech-talk
- RE: LabCA for MATLAB Installation error Mark Rivers via Tech-talk
- Re: LabCA for MATLAB Installation error Michael Davidsaver via Tech-talk
- RE: LabCA for MATLAB Installation error Freddie Akeroyd - STFC UKRI via Tech-talk
medm pv info Siddons, David via Tech-talk
<2024>
2025
2026
<2024>
2025
2026
