- If your device is interfaced through messages over a byte-stream connection (like TCP) and the communication follows a request/response model - your test looks like exactly that -
you should not code your own asyn driver, but use StreamDevice.
I agree with that statement in most cases. However, there are important exceptions:
- When using non-standard EPICS records, such as the motor record, scaler record, mca record, etc. StreamDevice cannot be used for these. Since the driver name in this case is ct08,
this might be a counter using the scaler record.
- When dealing with complex devices where the “state” of the device is important for the communications. It is more difficult keep the state information in the database and act on it
appropriately than it is in the driver.
- When dealing with request/response protocols that can be much more efficient when processing multiple records when not using StreamDevice. For example, a single Modbus transaction
can update the state of 2000 bi records. It is much simpler and more efficient to use the optimized Modbus driver rather than StreamDevice.
If your device is interfaced through messages over a byte-stream connection (like TCP) and the communication follows a request/response model - your test looks like exactly that - you should
- Re: RE: A question on asyn application Ralph Lange via Tech-talk
- A question on asyn application cxy via Tech-talk
- Re: A question on asyn application Torsten Bögershausen via Tech-talk
- RE: A question on asyn application Mark Rivers via Tech-talk
- Re:RE: A question on asyn application cxy via Tech-talk
Re: mvme3100 epics and control motor Mark Rivers via Tech-talk
<2024>
2025
2026
Re:Re:Re: RE: A question on asyn application cxy via Tech-talk
<2024>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
