1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: RE: A question on asyn application
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 24 Jan 2024 17:46:45 +0100
On Wed, 24 Jan 2024 at 17:18, Mark Rivers <[email protected]> wrote:
  • If your device is interfaced through messages over a byte-stream connection (like TCP) and the communication follows a request/response model - your test looks like exactly that - you should not code your own asyn driver, but use StreamDevice.
I agree with that statement in most cases.  However, there are important exceptions:
  • When using non-standard EPICS records, such as the motor record, scaler record, mca record, etc.  StreamDevice cannot be used for these. Since the driver name in this case is ct08, this might be a counter using the scaler record.
  • When dealing with complex devices where the “state” of the device is important for the communications.  It is more difficult keep the state information in the database and act on it appropriately than it is in the driver.
  • When dealing with request/response protocols that can be much more efficient when processing multiple records when not using StreamDevice.  For example, a single Modbus transaction can update the state of 2000 bi records.  It is much simpler and more efficient to use the optimized Modbus driver rather than StreamDevice.
Yes. I fully agree.
~Ralph
A question on asyn application cxy via Tech-talk
Re: A question on asyn application Torsten Bögershausen via Tech-talk
RE: A question on asyn application Mark Rivers via Tech-talk
Re:RE: A question on asyn application cxy via Tech-talk
Re: RE: A question on asyn application Ralph Lange via Tech-talk
RE: RE: A question on asyn application Mark Rivers via Tech-talk
Prev: RE: RE: A question on asyn application Mark Rivers via Tech-talk
Next: EPICS db-file creation and installation with EPICS BASE 7 Hovanes Egiyan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Next: How to achive a huge number of PVs in Archive Appliance CAOUEN Loïc via Tech-talk
