I have developed IOC using PyDevice. The ao recored works functionally with python code., but VAL field remain 1 and RVAL change according to the PV set value. is any additional setting required in the IOC / record field / python code?
epics> dbpf PHASE_SHIFT:CHANNELA 2
DBF_DOUBLE: 2
epics> Channel 48 is set value - 2.0
dbpr PHASE_SHIFT:CHANNELA 4
ACKS: NO_ALARM ACKT: YES ADEL: 0 ALST: 1
AMSG: AOFF: 0 ASG : ASLO: 0
ASP : PTR (nil) BKLNK: ELL 0 [(nil) .. (nil)] BKPT: 00
DESC: DISA: 0 DISP: 0 DISS: NO_ALARM
DISV: 1 DOL : CONSTANT DPVT: PTR 0xaaab18f63890
DRVH: 0 DRVL: 0 DSET: PTR 0xffff8c4a6a90
DTYP: pydev EGU : EGUF: 0 EGUL: 0
EOFF: 0 ESLO: 1 EVNT: FLNK: CONSTANT
HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 0
HSV : NO_ALARM HYST: 0 INIT: 0
IVOA: Continue normally IVOV: 0 LALM: 1
LBRK: 0 LCNT: 0 LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0 LOPR: 0 LOW : 0
LSET: PTR 0xaaab18f5b790 LSV : NO_ALARM MDEL: 0
MLIS: ELL 0 [(nil) .. (nil)] MLOK: 80 de f5 18 ab aa 00 00
MLST: 1 NAME: PHASE_SHIFT:CHANNELA NAMSG:
NSEV: NO_ALARM NSTA: NO_ALARM OIF : Full OLDSIMM: NO
OMOD: 0 OMSL: supervisory ORAW: 2 ORBV: 0
OROC: 0 OUT : INST_IO @device1.setv('channel_A', (VAL))
OVAL: 2 PACT: 0 PBRK: PTR (nil) PHAS: 0
PINI: NO PPN : PTR (nil) PPNR: PTR (nil) PREC: 0
PRIO: LOW PROC: 0 PUTF: 0 PVAL: 2
RBV : 0 RDES: PTR 0xaaab18e11da0 ROFF: 0
RPRO: 0 RSET: PTR 0xffff8c353610 RVAL: 2
SCAN: Passive SDIS: CONSTANT SDLY: -1 SEVR: NO_ALARM
SIML: CONSTANT SIMM: NO SIMPVT: PTR (nil) SIMS: NO_ALARM
SIOL: CONSTANT SPVT: PTR (nil) SSCN: <nil> STAT: NO_ALARM
TIME: 2024-05-24 11:41:38.967049007 TPRO: 0 TSE : 0
TSEL: CONSTANT UDF : 0 UDFS: INVALID UTAG: 0
VAL : 1
epics>
Thanks
Vishnu
