1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 24 May 2024 09:09:39 +0200
On Fri, 24 May 2024 at 07:38, boj <[email protected]> wrote:
Thanks for the suggestion.
I read up om the BO record (I am running 3.15) using the HIGH field for the "Push bottom" behavior.
As I understand that documentation, the record is processed again when going low after the specified time.
I guess that will mean that the protocol is executed twice?  Any way to avoid that?
Yes, correct. No decent way to avoid that.
Then, just don't set the HIGH field. Whatever value is being written to the record, the protocol will be executed.
This brings back the problem that the response from the device depends on its current state
(it is different when going from On -> Off, and from Off -> Off).
As Dirk was asking: Do you need the response? Can't you just ignore it?
A Simple push button that executes an protocol entry once will be very useful for me.
Switch or buttons is a design choice.
Buttons always need a status, else you never know the current device state.
A switch position needs to be readable from the device or persisted (autoSaveRestore), else it might end up in the wrong position after an IOC reboot.
Discussing with colleagues, I found some very strong, almost religious, opinions in the underlying "trigger by state or by pulse" question.
The EPICS database allows to implement one using the other. Flexibility is nice!
Cheers,
~Ralph
ps. Having a record named after you is pretty cool.
RE: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Žiga Oven via Tech-talk
Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Ralph Lange via Tech-talk
Prev: PyDevice support VAL field remains 1 Vishnu Patel via Tech-talk
Next: Re: PyDevice support VAL field remains 1 Vishnu Patel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols boj via Tech-talk
Next: RE: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Žiga Oven via Tech-talk
