1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: PyDevice support VAL field remains 1
From: Vishnu Patel via Tech-talk <[email protected]>
To: "Tech Talk ([email protected])" <[email protected]>
Date: Fri, 24 May 2024 07:32:01 +0000
It was my mistake.
I was returning 1 each time execute python code, which was reflected in the VAL field of ao record.  Now VAL value has been returned in the python code.
The problem has been resolved.
Thanks all
Vishnu
Sent: 24 May 2024 11:51
To: Tech Talk ([email protected]) <[email protected]>
Subject: PyDevice support VAL field remains 1
     I have developed IOC using PyDevice.  The ao recored works functionally with python code., but VAL field remain 1 and RVAL change according to the PV set value.  is any additional setting required in the IOC / record field / python code?
epics> dbpf  PHASE_SHIFT:CHANNELA 2
DBF_DOUBLE:         2
epics> Channel 48 is set value -  2.0
dbpr  PHASE_SHIFT:CHANNELA 4
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: 1
AMSG:               AOFF: 0             ASG :               ASLO: 0
ASP : PTR (nil)     BKLNK: ELL 0 [(nil) .. (nil)]           BKPT: 00
DESC:               DISA: 0             DISP: 0             DISS: NO_ALARM
DISV: 1             DOL : CONSTANT      DPVT: PTR 0xaaab18f63890
DRVH: 0             DRVL: 0             DSET: PTR 0xffff8c4a6a90
DTYP: pydev         EGU :               EGUF: 0             EGUL: 0
EOFF: 0             ESLO: 1             EVNT:               FLNK: CONSTANT
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV : NO_ALARM      HYST: 0             INIT: 0
IVOA: Continue normally                 IVOV: 0             LALM: 1
LBRK: 0             LCNT: 0             LINR: NO CONVERSION LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW : 0
LSET: PTR 0xaaab18f5b790                LSV : NO_ALARM      MDEL: 0
MLIS: ELL 0 [(nil) .. (nil)]            MLOK: 80 de f5 18 ab aa 00 00
MLST: 1             NAME: PHASE_SHIFT:CHANNELA              NAMSG:
NSEV: NO_ALARM      NSTA: NO_ALARM      OIF : Full          OLDSIMM: NO
OMOD: 0             OMSL: supervisory   ORAW: 2             ORBV: 0
OROC: 0             OUT : INST_IO @device1.setv('channel_A', (VAL))
OVAL: 2             PACT: 0             PBRK: PTR (nil)     PHAS: 0
PINI: NO            PPN : PTR (nil)     PPNR: PTR (nil)     PREC: 0
PRIO: LOW           PROC: 0             PUTF: 0             PVAL: 2
RBV : 0             RDES: PTR 0xaaab18e11da0                ROFF: 0
RPRO: 0             RSET: PTR 0xffff8c353610                RVAL: 2
SCAN: Passive       SDIS: CONSTANT      SDLY: -1            SEVR: NO_ALARM
SIML: CONSTANT      SIMM: NO            SIMPVT: PTR (nil)   SIMS: NO_ALARM
SIOL: CONSTANT      SPVT: PTR (nil)     SSCN: <nil>         STAT: NO_ALARM
TIME: 2024-05-24 11:41:38.967049007     TPRO: 0             TSE : 0
TSEL: CONSTANT      UDF : 0             UDFS: INVALID       UTAG: 0
VAL : 1
epics>
Thanks
Vishnu
PyDevice support VAL field remains 1 Vishnu Patel via Tech-talk
Prev: Re: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Ralph Lange via Tech-talk
Next: RE: CryoTel GT Cooler: different startup and shutdown StreamDevice protocols Žiga Oven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: PyDevice support VAL field remains 1 Vishnu Patel via Tech-talk
Next: pv.read() after pv.write() returns old value instead of new value using org.phoebus.pv.PV Wang, Lin via Tech-talk
