1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Strange problem with EPICS areaDetector
From: Timo Korhonen via Tech-talk <[email protected]>
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Jun 2024 08:32:42 +0000
Ahh....I am not sure if I did something wrong, but urldefense messed up the link which was working in the message that I sent.
Should anyone be interested, maybe this works better: https://urldefense.us/v3/__https://wiki.ubuntu.com/ToolChain/CompilerFlags__;!!G_uCfscf7eWS!aTowUvt84biwwhUW7HZurB4yHgJnZxBOAGqGS5OXye_4R6j5AxXi-tNMwtlagOVF4MYnzbTNjFM6iiDlJiN5HKkdVWOH$
The D_FORTIFY_SOURCE can be easily found in the TOC. There are also a few further comments on the page about how to handle the issue.
Timo
On 2024-06-20, 09:08, "Tech-talk on behalf of Timo Korhonen via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
FWIW, this is what Ubuntu Wiki says on this matter:
https://urldefense.us/v3/__https://wiki.ubuntu.com/ToolChain/CompilerFlags <https://urldefense.us/v3/__https://wiki.ubuntu.com/ToolChain/CompilerFlags>*A-D_FORTIFY_SOURCE.3D3__;Iw!!G_uCfscf7eWS!ZXiAoKEIMfSS5NRgNhpT13otpnk7lIGejq1oXlNUwp2mQ5JomY6QGUoe7AxKez9xOToVpx40cY7O4IycM8t9IpWIFj5k$
"... Only activated when compiled with -O1 or higher."
A little bit odd is that the page also says "First enabled as -D_FORTIFY_SOURCE=2 in Ubuntu 8.10 and updated to -D_FORITFY_SOURCE=3 in Ubuntu 24.04." Apparently the update was already applied in Ubuntu 22.04.
Timo
On 2024-06-20, 08:52, "Tech-talk on behalf of Jörn Dreyer via Tech-talk" <[email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>> on behalf of [email protected] <mailto:[email protected]> <mailto:[email protected] <mailto:[email protected]>>> wrote:
Hi Michael,
yes, you are right that the level of optimization plays a role wether the check triggers a fault or not.
At leas thats what the documentation of the _FORTIFY_SOURCE macro says.
Jörn
Am Donnerstag, 20. Juni 2024, 07:28:29 MESZ schrieb Michael Davidsaver via Tech-talk:
> On 6/19/24 21:26, Michael Davidsaver wrote:
> > I see something like the following. All of the 'f's mean that GCC
> > is unable to track the sizes of the objects involved. I also don't
> > see a fault.
> >> X test.LINR ptemp=ffffffffffffffff,ffffffffffffffff papChoice=ffffffffffffffff,ffffffffffffffff i=0
> I spoke too soon. I can reproduce, but not with a -debug build.
> So I guess '-O2' vs '-O3' plays some role?
> > X test.LINR ptemp=ffffffffffffffff,28 papChoice=ffffffffffffffff,ffffffffffffffff i=0
> > X test.LINR ptemp=ffffffffffffffff,0 papChoice=ffffffffffffffff,ffffffffffffffff i=1
> > *** buffer overflow detected ***: terminated
> The inferred size of 'ptemp' is 28 bytes, which I can only assume comes from
> this line.
> > ptemp = &(pdbr_enumStrs->strs[0][0]);
> I don't understand why 28 and not 1, 30, or 30*40 ?
> The first iteration steps past this.
> > ptemp += sizeof(pdbr_enumStrs->strs[0]);
> This is certainly an odd way to iterate an array...
Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Re: Strange problem with EPICS areaDetector Timo Korhonen via Tech-talk
Prev: Re: IOC connection problem Gerrit Kühn via Tech-talk
Next: Re: [EXTERNAL] IOC connection problem Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Strange problem with EPICS areaDetector Timo Korhonen via Tech-talk
Next: Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
