1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: Strange problem with EPICS areaDetector
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Timo Korhonen <[email protected]>
Date: Thu, 20 Jun 2024 13:42:56 -0700
On 6/20/24 00:07, Timo Korhonen via Tech-talk wrote:
"... Only activated when compiled with -O1 or higher."
Ah, my mistake.  My debug build was "-O0".  (and the glibc documentation[3] does not mention this)
With "-O1" the s1len argument[1][2] to __strncpy_chk() is not optimized away,
so that stack frame is more meaningful.
I guess my advice for troubleshooting the next occurrence will include
adding "OPT_CFLAGS_NO += -O1" to configure/CONFIG_SITE and rebuilding.
[1] https://urldefense.us/v3/__https://github.com/bminor/glibc/blob/da905bb706672c84130226bfff9de7d6ba1f0eb6/debug/strncpy_chk.c*L23C1-L23C14__;Iw!!G_uCfscf7eWS!fLFdio7gXAYHe7XXuSBEls_YLMUGAJgyzVCWLCwyFU3qjbvuGrndvfEfIf1_wAepl2CsuNpkJaBueVITSJhzixt4_w$ [2] https://urldefense.us/v3/__https://github.com/bminor/glibc/blob/da905bb706672c84130226bfff9de7d6ba1f0eb6/string/bits/string_fortified.h*L100-L101__;Iw!!G_uCfscf7eWS!fLFdio7gXAYHe7XXuSBEls_YLMUGAJgyzVCWLCwyFU3qjbvuGrndvfEfIf1_wAepl2CsuNpkJaBueVITSJgZnVyUbg$ [3] https://urldefense.us/v3/__https://www.gnu.org/software/libc/manual/html_node/Source-Fortification.html__;!!G_uCfscf7eWS!fLFdio7gXAYHe7XXuSBEls_YLMUGAJgyzVCWLCwyFU3qjbvuGrndvfEfIf1_wAepl2CsuNpkJaBueVITSJgDgXBLUA$
A little bit odd is that the page also says "First enabled as -D_FORTIFY_SOURCE=2 in Ubuntu 8.10 and updated to -D_FORITFY_SOURCE=3 in Ubuntu 24.04." Apparently the update was already applied in Ubuntu 22.04.
Timo
On 2024-06-20, 08:52, "Tech-talk on behalf of Jörn Dreyer via Tech-talk" <[email protected] <mailto:[email protected]> on behalf of [email protected] <mailto:[email protected]>> wrote:
Hi Michael,
yes, you are right that the level of optimization plays a role wether the check triggers a fault or not.
At leas thats what the documentation of the _FORTIFY_SOURCE macro says.
Jörn
Am Donnerstag, 20. Juni 2024, 07:28:29 MESZ schrieb Michael Davidsaver via Tech-talk:
On 6/19/24 21:26, Michael Davidsaver wrote:
I see something like the following. All of the 'f's mean that GCC
is unable to track the sizes of the objects involved. I also don't
see a fault.
X test.LINR ptemp=ffffffffffffffff,ffffffffffffffff papChoice=ffffffffffffffff,ffffffffffffffff i=0
I spoke too soon. I can reproduce, but not with a -debug build.
So I guess '-O2' vs '-O3' plays some role?
X test.LINR ptemp=ffffffffffffffff,28 papChoice=ffffffffffffffff,ffffffffffffffff i=0
X test.LINR ptemp=ffffffffffffffff,0 papChoice=ffffffffffffffff,ffffffffffffffff i=1
*** buffer overflow detected ***: terminated
The inferred size of 'ptemp' is 28 bytes, which I can only assume comes from
this line.
ptemp = &(pdbr_enumStrs->strs[0][0]);
I don't understand why 28 and not 1, 30, or 30*40 ?
The first iteration steps past this.
ptemp += sizeof(pdbr_enumStrs->strs[0]);
This is certainly an odd way to iterate an array...
Re: Strange problem with EPICS areaDetector Jure Varlec via Tech-talk
Re: Strange problem with EPICS areaDetector Jörn Dreyer via Tech-talk
Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
Re: Strange problem with EPICS areaDetector Timo Korhonen via Tech-talk
Prev: Re: Strange problem with EPICS areaDetector Michael Davidsaver via Tech-talk
Next: Re: Strange problem with EPICS areaDetector Jure Varlec via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Prev: Re: Strange problem with EPICS areaDetector Timo Korhonen via Tech-talk
