1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Subject: Re: install epics-base: Perl Script Path Interpretation Issue on Windows
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: Ralph Lange <[email protected]>
Date: Thu, 27 Jun 2024 11:16:19 -0500
On 06/27, Ralph Lange via Tech-talk wrote:
> On Thu, 27 Jun 2024 at 17:30, J. Lewis Muir <[email protected]> wrote:
> > Is the no-space-or-parentheses-in-paths restriction specific to Windows?
> See savannah.gnu.org/bugs/?712
> The workaround in the Windows guide is specific.
> I have rarely seen spaces in paths on other systems, while they're
> everywhere on Windows. (And brackets.)
The workaround is Windows-specific, but given the bug report you
referenced (which I just briefly skimmed), at least the no-spaces
restriction is not, so IMO that should be stated as a restriction in the
installation instructions for the other platforms.  How common spaces
are in paths on other platforms seems irrelevant to me.
Lewis
install epics-base: Perl Script Path Interpretation Issue on Windows Hussein Matar via Tech-talk
Re: install epics-base: Perl Script Path Interpretation Issue on Windows Johnson, Andrew N. via Tech-talk
Re: install epics-base: Perl Script Path Interpretation Issue on Windows Ralph Lange via Tech-talk
Re: install epics-base: Perl Script Path Interpretation Issue on Windows J. Lewis Muir via Tech-talk
Prev: Re: install epics-base: Perl Script Path Interpretation Issue on Windows Ralph Lange via Tech-talk
Next: RE: Errors during building of asyn package Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <2024>  2025  2026
Next: Retrieve motor-record data from archiver appliance Heinz Junkes via Tech-talk
