1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building
To: Jonathan Hai <[email protected]>
Date: Mon, 10 Mar 2025 18:34:34 +0000
Hi Jonathan,
Last week I successfully built base 7.0.9, asyn, seq, sscan, and Galil on an Ubuntu system with those same specs.
Sent: Monday, March 10, 2025 12:50 PM
Subject: Re: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building
Hi Mark,
Yes, I did move my support directory to be out of epics-base. It fixed the problem!
Here are my specs:
  • Ubuntu 24.04
  • EPICS 7.0.9
  • GCC 13.3.0
Could these be causing any problems?
Jonathan Hai
Researcher/Tech Monkey
CNBL | Department of Physics and Astronomy
McMaster University
Sapere Aude
Sent: Monday, March 10, 2025 1:47 PM
To: Jonathan Hai <[email protected]>; [email protected] <[email protected]>
You don't often get email from [email protected]. Learn why this is important
Caution: External email.
Hi Jonathon,
What version of EPICS base are you using?  Have you modified anything in it?
Last week you reported a problem building asyn.  I could not reproduce your problem, and then Andrew Johnson suggested that you move support/ so it was not under EPICS base.  Did you do that, and did it fix your problem?
I am not aware of anyone else reporting a problem with lexer, so there must be something different with your installation.  Is this Ubuntu 22?  I built base successfully on that last week, including seq and sscan with base 7.0.9.
From: Tech-talk <[email protected]> On Behalf Of Jonathan Hai via Tech-talk
Sent: Monday, March 10, 2025 12:39 PM
To: [email protected]
Subject: Follow-up: Issues Installing Galil EPICS Drivers – seq & sscan Still Not Building
Hi Kasemir,
I appreciate the help so far regarding my Galil motor driver installation issues. I've followed the advice given and have attempted multiple fixes, but I’m still unable to get the required dependencies (seq and sscan) to build.
Recap of the Issue
  1. I need to install the Galil motor drivers, but the build fails because sscan does not compile.
  2. sscan fails because scanProg.o is missing, which (I believe) needs seq to be installed.
  3. seq fails to build due to a missing lexer.c, which should be generated from lexer.l by e_flex.
  4. e_flex is broken on my system, preventing lexer.c from being created.
Steps I Have Taken So Far
1. Verified e_flex and antelope Exist in EPICS Base
  • Both e_flex and antelope are present in /home/jonathanhai/epics-base/bin/linux-x86_64/.
  • Running antelope --version works, but running e_flex --help produces an error:
·         /home/jonathanhai/epics-base/bin/linux-x86_64/e_flex: unknown flag '-'
2. Checked for lexer.l in seq
  • lexer.l is present in /home/jonathanhai/support/seq/src/snc/, but running e_flex fails with:
·         /home/jonathanhai/epics-base/bin/linux-x86_64/e_flex: could not create
  • Running e_flex manually gives:
·         /home/jonathanhai/epics-base/bin/linux-x86_64/e_flex: can't open skeleton file DEFAULT_SKELETON_FILE
3. Checked for flex.skl (Skeleton File Required by e_flex)
  • Running:
·         find ~/epics-base -name "flex.skl"
returns no results, meaning this file is missing.
·         /home/jonathanhai/epics-base/configure/os/Linux/flex.skl: No such file or directory
4. Installed System flex and bison as an Alternative
  • Installed via:
·         sudo apt install flex bison
    • flex version: 2.6.4
    • bison version: 3.8.2
  • Tried running system flex manually:
·         cd ~/support/seq/src/snc
·         flex -o lexer.c lexer.l
    • Error:
o    lexer.l:1: premature EOF
5. Rebuilt EPICS Base
  • Ran a full rebuild:
·         cd ~/epics-base
·         make clean
·         make
  • No change, e_flex still does not work.
Current Issues & Questions
  1. Why is e_flex broken?
    • It fails with "unknown flag '-'" when run manually.
    • It also reports "can't open skeleton file DEFAULT_SKELETON_FILE" when used.
    • Should I be specifying a FLEX_SKEL environment variable?
  1. Why is lexer.l failing with "premature EOF" when running flex?
    • Could lexer.l be corrupted or incomplete?
    • If so, can I manually download a working version?
  1. Is there a way to bypass e_flex and manually create lexer.c?
    • If I download a pre-generated lexer.c, will the build proceed?
  1. Would switching to an older version of seq help?
    • If so, which version would you recommend?
I really appreciate any further guidance on this! Thanks again for your time.
When you build epics base, that generates base/bin/…./antelope and e_flex, so basically yacc and (f)lex.
Do you have the base/bin/HOST_ARCH folder on your PATH?
Then it should find those when building the other modules
Hi Jonathon,
Hi Kasemir,
Recap of the Issue
  • Running:
  • Installed via:
    • Error:
·         cd ~/epics-base
·         make clean
·         make
Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building Jonathan Hai via Tech-talk
Re: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building Jonathan Hai via Tech-talk
RE: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building Mark Rivers via Tech-talk
Prev: RE: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building Mark Rivers via Tech-talk
Next: [CSS/Phoebus] Adding widgets as children to other widgets, from Python Gonzalez, Jose Carlos via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: More Issues Installing Galil EPICS Drivers – asyn Jonathan Hai via Tech-talk
