1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: [CSS/Phoebus] Adding widgets as children to other widgets, from Python
From: "Gonzalez, Jose Carlos via Tech-talk" <[email protected]>
Date: Tue, 11 Mar 2025 10:45:12 +0000
I'm trying to use scripting to populate a CSStudio/Phoebus panel/display with a set of replica of a template panel, which shows information from a single monitored entity. In total, there would be N1 copies of that template in the panel (distributed in rows and columns). I'm following pretty much the example provided in the template sample panel.
Now, in fact I don't have 1 single set of entities, but 3 of them. So, I have two possibilitites:
a) I can create 3 similar panels, each of them showing one of these 3 sets, or
b) I can (my preferred solution, if possible) I can create 1 single panel with a Tabs or Navigator Tabs widget, with 3 pages, and show in each of them one of those 3 sets.
My only question is: how can I, from a Python script, make that the new template panel that I'm replicating is a child of one of those pages (instead of being a child of the display/panel itself). In the later case, I use:
    display = widget.getDisplayModel()
to get the display handler, and then
    for i in range(...):
        instance = createInstance(...)
        display.runtimeChildren().addChild(instance)
to add each single instance ans a child of the display.
How can I get the page handlers for the Tabs or Navigator Tabs widget, instead?
Thanks in advance,
J C
Jose Carlos Gonzalez
Max-Planck-Institut für Plasmaphysik
Experiment-IT - Tokamak Scenario Development - L6/18
Boltzmannstr. 2,
D-85748 Garching bei München
Phone +49 89 3299-1698
[email protected]
Re: [CSS/Phoebus] Adding widgets as children to other widgets, from Python Kasemir, Kay via Tech-talk
Prev: RE: Issues Installing Galil EPICS Drivers – sscan & seq Dependencies Not Building Mark Rivers via Tech-talk
Next: Keithley device reading failure LONG FENG via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: More Issues Installing Galil EPICS Drivers – asyn Érico Nogueira Rolim via Tech-talk
Next: Re: [CSS/Phoebus] Adding widgets as children to other widgets, from Python Kasemir, Kay via Tech-talk
