1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: areaDetector build system question
To: [email protected]
Date: Wed, 12 Mar 2025 22:10:08 -0700
On Wed, Mar 12, 2025 at 9:21 PM Jörn Dreyer via Tech-talk <[email protected]> wrote:
is it possible to build an areaDetector module outside of the tree?
Please check https://github.com/jeonghanlee/EPICS-env-support, which I developed only for the ALS-U EPICS environment to support only one camera model, because we only have one model.
You can install one by one in the specific dependencies' order of all area detector modules with simple makefile tricks. It requires heavy manual configurations, so I built that repo without repeating the manual procedure.
Two rules give you a hints
After this, ADCore, ADSimDetector, ADGenICam, and ADVimba will be installed in the same way other EPICS modules will be.
HTH,
Han
Background:
I have an areaDetector driver for a special camera that I would like to use in a setup using sumo.
I have sumo setup to to build all the dependencies for areaDetector.  I would like to get my camera code included to be alble to use
it in multiple ioc configurations.
My driver compiles if added inside the areaDetector tree, but as a normal EPICS module it fails. Has anybody achieved this?
It look very much that my CONFIG_SITE.local file is not read and thus the relevant configuration is missed.
Jörn
Jeong Han Lee, Dr.rer.nat.
Lawrence Berkeley National Laboratory
areaDetector build system question Jörn Dreyer via Tech-talk
Prev: Re: areaDetector build system question Mark Rivers via Tech-talk
Next: Re: areaDetector build system question Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
