On Thu, 13 Mar 2025 at 05:21, Jörn Dreyer via Tech-talk <[email protected]> wrote:
Sure. Mark pointed out a few that do it. For ITER's CODAC Core system, I'm building and packaging all modules separately: core, simdriver, genicam, aravis, pilatus, simba. I tried to use ad-core as it is and failed, as it does a few things in a non-standard way that makes such separation really hard. With one core module and many driver modules (getting more over time), I decided to help long-term maintenance by concentrating changes in the one core module. So, changes are mostly in ad-core. I have one patch file (unchanged since ADCore 3.11) that: - comments out all the plugins that we don't use - sets things up correctly in configure/CONFIG_SITE - removes all the auto-converted displays for display managers we don't use - improves the dbd file setup to cleanly separate ad-core "AD.dbd" and the whole stack "ADSupport.dbd" - installs iocBoot/EXAMPLE_commonPlugins.cmd and iocBoot/EXAMPLE_commonPlugin_settings.req (also renames them and puts .req into db/) - installs make snippets ADApp/commonDriverMakefile and ADApp/commonLibraryMakefile (renames them to mark them as AD things) With that streamlined ad-core, changes for the drivers are pretty minimal: - setting of EPICS_BASE and AREA_DETECTOR in a RELEASE.local - patch Makefile to include the Makefile snippets (commonDriverMakefile/commonLibraryMakefile) from their new locations/names in the install area The stuff is using ITER's build system (uuuuhh), located on our internal (eeeehh) Subversion (whooooaa) server. I'm happy to send the patches, though, or a combination of, e.g., core/simdetector sources that is set up this way. @Mark: If you were willing to move upstream AD in that direction, I could be talked into preparing a Pull Request. Cheers, ~Ralph
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
