1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: areaDetector build system question
From: Jörn Dreyer via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, [email protected]
Date: Wed, 19 Mar 2025 11:26:30 +0100
Many thanks to all the replies.
I got the module compiled outside of the main areaDetector tree. Indeed the trick was to get the correct settings for RELEASE.local and CONFIG_SITE.local.
Regards
Jörn
Am Sonntag, 16. März 2025, 07:44:05 Mitteleuropäische Normalzeit schrieb Abdalla Ahmad via Tech-talk:
> Here at SESAME, we build the used AD modules outside their tree just by modifying the configure/RELEASE file of any module, this is necessary for our RPM packaging. An example here is the RELEASE file we use to build ADCore:
> #RELEASE Location of external products
> # Run "gnumake clean uninstall install" in the application
> # top directory each time this file is changed.
> # -include $(TOP)/../configure/RELEASE_LIBS_INCLUDE
> # -include $(TOP)/RELEASE.local
> # -include $(TOP)/configure/RELEASE.local
> ASYN = /opt/epics/support/asyn
> ADSUPPORT = /opt/epics/support/areaDetector/support
> EPICS_BASE = /opt/epics/base
> WITH_BITSHUFFLE=YES
> WITH_BLOSC=YES
> WITH_GRAPHICSMAGICK=YES
> WITH_HDF5=YES
> WITH_JPEG=YES
> WITH_NETCDF=YES
> WITH_NEXUS=YES
> WITH_SZIP=YES
> WITH_TIFF=YES
> WITH_ZLIB=YES
> BITSHUFFLE_EXTERNAL=NO
> BLOSC_EXTERNAL=NO
> GRAPHICSMAGICK_EXTERNAL=NO
> HDF5_EXTERNAL=NO
> JPEG_EXTERNAL=NO
> NETCDF_EXTERNAL=NO
> NEXUS_EXTERNAL=NO
> SZIP_EXTERNAL=NO
> TIFF_EXTERNAL=NO
> XML2_EXTERNAL=NO
> ZLIB_EXTERNAL=NO
> More release files can be seen in the project’s repository: https://urldefense.us/v3/__https://github.com/AbdallaDalleh/epics-rpm-spec__;!!G_uCfscf7eWS!cJJXvFMKS7BD9BEHnMyDAyTfVI58P3-YL0z0QBO_PFLPvBjfT7pnNEE-9qFcwt_J_NVI7wFjTDprCIrKjStwY0qJ6Dt_iwY$
> Best Regards,
> Abdalla Al-Dalleh
> Control Engineer
> SESAME
> From: Tech-talk <[email protected]> On Behalf Of Johnson, Andrew N. via Tech-talk
> Sent: Thursday, March 13, 2025 7:43 PM
> To: Jörn Dreyer <[email protected]>; [email protected]
> Hi Jörn,
> At APS we use Sumo to build AreaDetector (including ADCore and ADSupport), many of the standard plugins as external modules, and many IOCs which use these. I suggested changes to the AreaDetector build system to make that work, although my PR<https://urldefense.us/v3/__https:/github.com/areaDetector/areaDetector/pull/72__;!!G_uCfscf7eWS!ZEKOdorgtIWuME8CwOpBrH-xyNxUDjjKJdQnru4Llgqu-ZwlKSiBForQWf7rCeWfvuuS_q5nJDpByOUT$> has bit-rotted somewhat in the 3-4 years since I last worked on it. Our local AreaDetector version has some additional changes that aren’t in the PR, but the plugins don’t require any modification IIRC.
> Here is the configure/MODULES file from our camera IOC area, showing that it is possible to do this:
> $ cat configure/MODULES
>     "extra": [
>         "ADCORE=$(AREA_DETECTOR)/ADCore",
>         "ADSUPPORT=$(AREA_DETECTOR)/ADSupport"
>     "module": [
>         "ADARAVIS:2.2.1-C2-1",
>         "ADGENICAM:1.10-C2-1",
>         "ADPOINTGREY:2.9-C2-1",
>         "ADSPINNAKER:3.3-C2-1",
>         "AREA_DETECTOR:3.12.1-C2-2",
>         "ASYN:4.42-C2-2",
>         "AUTOSAVE:5.10.2-C2-1",
>         "BASE:7.0.6.1-C2-3",
>         "BUSY:1.7.3-C2-1",
>         "CALC:3.7.4-C2-1",
>         "IOCSTATS:3.2.0-C2-2",
>         "IOCSTD:4.5.0-C2-1",
>         "NDDRIVERSTDARRAYS:1.4-C2-1",
>         "SEQ:2.2.9-C2-1",
>         "SSCAN:2.11.5-C2-1",
>         "ZLIB:1.2.11-C2-1"
> - Andrew
> Complexity comes for free, Simplicity you have to work for.
> On 3/12/25, 11:21 PM, "Tech-talk" <[email protected]<mailto:[email protected]>> wrote:
> Hi,
> is it possible to build an areaDetector module outside of the tree?
> Background:
> I have an areaDetector driver for a special camera that I would like to use in a setup using sumo.
> I have sumo setup to to build all the dependencies for areaDetector.  I would like to get my camera code included to be alble to use
> it in multiple ioc configurations.
> My driver compiles if added inside the areaDetector tree, but as a normal EPICS module it fails. Has anybody achieved this?
> It look very much that my CONFIG_SITE.local file is not read and thus the relevant configuration is missed.
> Regards,
> Jörn
areaDetector build system question Jörn Dreyer via Tech-talk
Re: areaDetector build system question Johnson, Andrew N. via Tech-talk
RE: areaDetector build system question Abdalla Ahmad via Tech-talk
Prev: Converting Application using sumo Jörn Dreyer via Tech-talk
Next: RE: Thermo Fischer FHT 6020 Radiation Monitor Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: RE: areaDetector build system question Abdalla Ahmad via Tech-talk
Next: StreamDevice : scope of system variables Peter Milne via Tech-talk
