1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Some questions about CaLab (Dariush Hampai)
From: Carsten Winkler via Tech-talk <[email protected]>
To: <[email protected]>
Date: Mon, 23 Jun 2025 07:31:49 +0200
The CA Lab does not have a function for writing multiple fields in a single channel access command.
Fields are written by adding the field name with a dot.
If you need to write to multiple fields, you can use array parameters as follows:
Carsten
Am 20.06.2025 um 21:02 schrieb [email protected]:
Send Tech-talk mailing list submissions to
	[email protected]
To subscribe or unsubscribe via the World Wide Web, visit
	https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
	[email protected]
You can reach the person managing the list at
	[email protected]
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
   1. Re: Problem with Newport CONEX-AGAP FTDI device on Linux
      (James P. Withrow)
   2. Re: Problem with Newport CONEX-AGAP FTDI device on Linux
      (Dmitry Yu. Bolkhovityanov)
   3. Some questions about CaLab (Dariush Hampai)
   4. RE: Problem with Newport CONEX-AGAP FTDI device on Linux
      (Mark Rivers)
Message: 1
Date: Fri, 20 Jun 2025 17:18:51 +0000
Cc: tech-talk EPICS <[email protected]>
Subject: Re: Problem with Newport CONEX-AGAP FTDI device on Linux
Message-ID: [email protected]"><[email protected]>
Content-Type: text/plain; charset="utf-8"
Mark -
It looks like the issue may be that the VID/PID pair (particularly the PID) may not be included in the currently running ftdi_sio driver.
A quick Google search turned up this incantation, which may be helpful:
echo "<VID> <PID>" >  /sys/bus/usb-serial/drivers/ftdi_sio/new_id
Untested, as I?m out of the office, but hopefully this may point you in the correct direction.
-Jim Withrow
Sent from my iPhone
On Jun 20, 2025, at 11:52, Mark Rivers via Tech-talk <[email protected]> wrote:
62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
[62363.655966] usb 1-4: New USB device found, idVendor=104d, idProduct=3008, bcdDevice= 6.00
[62363.655975] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62363.655978] usb 1-4: Product: CONEX-AGAP
[62363.655980] usb 1-4: Manufacturer: Newport
[62363.655982] usb 1-4: SerialNumber: A694ND5H
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20250620/5e715c9a/attachment.html>
Message: 2
Date: Sat, 21 Jun 2025 00:19:39 +0700 (+07)
From: "Dmitry Yu. Bolkhovityanov" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Content-Type: text/plain; charset="US-ASCII"; format=flowed
Hi Mark!
I suppose the problem is in product's ID.
Newport-CONEX-AGP's "idProduct=3006" *is* listed among supported IDs in
ftdi_sio_ids.h, see https://urldefense.us/v3/__https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/usb/serial/ftdi_sio_ids.h?h=v6.16-rc2__;!!G_uCfscf7eWS!cEIzCUjhW53L-KKEAV3e3SDEZCubl_LXE7ev4lxhWZfS5l5_fb1Uvx73nAo1Qmei1z1rHE3YjXYUZg_-sksd1QU4UU-cxedRxvU$
#define NEWPORT_CONEX_AGP_PID		0x3006
(and in ftdi_sio.c driver too)
while CONEX-AGAP's "idProduct=3008" is not, even in the latest kernel
version 6.16 (AFAIR, RHEL9 uses Linux kernet 5.14).
With best regards,
Dmitry
On Fri, 20 Jun 2025, Mark Rivers via Tech-talk wrote:
Folks,
I have an older Newport-CONEX-AGP controller that works fine on Linux.
https://urldefense.us/v3/__https://www.newport.com/f/agilis-piezo-linear-stage-with-conex-controller__;!!G_uCfscf7eWS!esBpnKdccckn_TlnsWE5ruJncpjWNfxHfi8SNZ2M5qWp8ab4wjlgsB18EO_4YOzuwREd1qW6ipequMg2cHFGxsaFyd4$
The device has a USB interface and uses FTDI.  When I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62289.315988] usb 1-4: new full-speed USB device number 10 using xhci_hcd
[62289.447505] usb 1-4: New USB device found, idVendor=104d, idProduct=3006, bcdDevice= 6.00
[62289.447514] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62289.447518] usb 1-4: Product: CONEX-AGP
[62289.447520] usb 1-4: Manufacturer: Newport
[62289.447522] usb 1-4: SerialNumber: A6UJN7YS
[62289.450490] ftdi_sio 1-4:1.0: FTDI USB Serial Device converter detected
[62289.450536] usb 1-4: Detected FT232R
[62289.451085] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB0
The device is now available on /dev/ttyUSB0.
I expected to be able to do the same thing with a newer CONEX-AGAP controller.
https://urldefense.us/v3/__https://www.newport.com/f/conex-piezo-absolute-positioning-mirror-mount__;!!G_uCfscf7eWS!esBpnKdccckn_TlnsWE5ruJncpjWNfxHfi8SNZ2M5qWp8ab4wjlgsB18EO_4YOzuwREd1qW6ipequMg2cHFG2VO-mdQ$
However, when I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62360.327898] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[62360.327934] ftdi_sio 1-4:1.0: device disconnected
[62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
Note that I do not get the messages about ftdi_sio detected or the message about attaching to ttyUSBx.
The new CONEX-AGAP works fine on Windows, where it appears as a COM port.  I can configure the COM port with EPICS:
drvAsynSerialPortConfigure("serial1", "COM5", 0, 0, 0)
asynOctetSetInputEos("serial1",0,"\r\n")
asynOctetSetOutputEos("serial1",0,"\r\n")
asynSetOption("serial1",0,"baud","921600")
asynSetOption("serial1",0,"bits","8")
asynSetOption("serial1",0,"stop","1")
asynSetOption("serial1",0,"parity","none")
asynSetOption("serial1",0,"clocal","Y")
asynSetOption("serial1",0,"crtscts","N")
Given the behavior on Windows, I think the CONEX-AGAP is also an FTDI device.  But if so, then why is Linux not recognizing it as such?
 	_________________________________________
 	  The Budker Institute of Nuclear Physics
 	  Novosibirsk, Russia
Message: 3
Date: Fri, 20 Jun 2025 17:27:15 +0200
To: [email protected]
Subject: Some questions about CaLab
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi all,
I have some problems with CaLab, necessary to integrate epics with a
LabView interface. In particular now I have two big problems:
1) i don't understand how to use multiple field in the same CA. For
example, my newport IOC includes some records of the type
mm4006:m11.HOMF
mm4006:m11.MOVN
etc...
CaLab Put.vi does not include the field. What do I do? if I put (for
example) mm4006:m11.HOMF and mm4006:m11.MOVN as PV I find two distinct
PVs...
2) I am trying to generate a monitor of the various IOCs. When starting
LabView there is no PV (via CaLab info.vi). If I start the IOCs I see
the PVs. However if I stop the IOCs, via command prompt (caget etc...) I
do not see (obviously) the active CA, while via CaLab info.vi the CA are
still active and give me the last values read. Even after a reset of PV,
using CaLab_Disconnect.vi, I still see the active CAs with the last
value read. Where am I going wrong?
Dariush
Attachment: smime.p7s
Description: Kryptografische S/MIME-Signatur
Re: Some questions about CaLab (Dariush Hampai) Dariush Hampai via Tech-talk
Prev: Re: EPICS Clients in C++ Ralph Lange via Tech-talk
Next: Re: Some questions about CaLab (Dariush Hampai) Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: RE: EPICS Clients in C++ [SEC=OFFICIAL] STARRITT, Andrew via Tech-talk
