Hi Carsten,
this means that if I send a CaLab get.vi with PV mm4006:m11 and
the array field [HOMF,MOVN] I receive an array of value [12,24]...
is it right?
The second question is more important... in someway even using
disconnect all PV (or sending directly the names of PV to
disconnect), with CaLab Info.vi I have in back all the PVs.
Is it possible that the problem is with the architecture of
Labview? i.e., Labview64 or Labview32?
Awaiting your replay
Dariush
Il 23/06/2025 07:31, Carsten Winkler ha
scritto:
The CA Lab does not have a function for writing multiple fields
in a single channel access command.
Fields are written by adding the field name with a dot.
If you need to write to multiple fields, you can use array
parameters as follows:
Carsten
Send Tech-talk mailing list submissions to
tech-talk at aps.anl.gov
To subscribe or unsubscribe via the World Wide Web, visit
https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
or, via email, send a message with subject or body 'help' to
tech-talk-request at aps.anl.gov
You can reach the person managing the list at
tech-talk-owner at aps.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of Tech-talk digest..."
Today's Topics:
1. Re: Problem with Newport CONEX-AGAP FTDI device on Linux
(James P. Withrow)
2. Re: Problem with Newport CONEX-AGAP FTDI device on Linux
(Dmitry Yu. Bolkhovityanov)
3. Some questions about CaLab (Dariush Hampai)
4. RE: Problem with Newport CONEX-AGAP FTDI device on Linux
(Mark Rivers)
Message: 1
Date: Fri, 20 Jun 2025 17:18:51 +0000
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk EPICS <tech-talk at aps.anl.gov>
Subject: Re: Problem with Newport CONEX-AGAP FTDI device on Linux
Message-ID: <EB8D328B-F88B-4848-8B6D-487C9884AA09 at cornell.edu>
Content-Type: text/plain; charset="utf-8"
Mark -
It looks like the issue may be that the VID/PID pair (particularly the PID) may not be included in the currently running ftdi_sio driver.
A quick Google search turned up this incantation, which may be helpful:
echo "<VID> <PID>" > /sys/bus/usb-serial/drivers/ftdi_sio/new_id
Untested, as I?m out of the office, but hopefully this may point you in the correct direction.
-Jim Withrow
Sent from my iPhone
On Jun 20, 2025, at 11:52, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
[62363.655966] usb 1-4: New USB device found, idVendor=104d, idProduct=3008, bcdDevice= 6.00
[62363.655975] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62363.655978] usb 1-4: Product: CONEX-AGAP
[62363.655980] usb 1-4: Manufacturer: Newport
[62363.655982] usb 1-4: SerialNumber: A694ND5H
URL: <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20250620/5e715c9a/attachment.html>
Message: 2
Date: Sat, 21 Jun 2025 00:19:39 +0700 (+07)
From: "Dmitry Yu. Bolkhovityanov" <D.Yu.Bolkhovityanov at inp.nsk.su>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Message-ID: <7d7eabd-831f-f51e-dc60-161ba8b28cc at starnew.inp.nsk.su>
Content-Type: text/plain; charset="US-ASCII"; format=flowed
Hi Mark!
I suppose the problem is in product's ID.
Newport-CONEX-AGP's "idProduct=3006" *is* listed among supported IDs in
ftdi_sio_ids.h, see https://urldefense.us/v3/__https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/drivers/usb/serial/ftdi_sio_ids.h?h=v6.16-rc2__;!!G_uCfscf7eWS!cEIzCUjhW53L-KKEAV3e3SDEZCubl_LXE7ev4lxhWZfS5l5_fb1Uvx73nAo1Qmei1z1rHE3YjXYUZg_-sksd1QU4UU-cxedRxvU$
#define NEWPORT_CONEX_AGP_PID 0x3006
(and in ftdi_sio.c driver too)
while CONEX-AGAP's "idProduct=3008" is not, even in the latest kernel
version 6.16 (AFAIR, RHEL9 uses Linux kernet 5.14).
With best regards,
Dmitry
On Fri, 20 Jun 2025, Mark Rivers via Tech-talk wrote:
Folks,
I have an older Newport-CONEX-AGP controller that works fine on Linux.
https://urldefense.us/v3/__https://www.newport.com/f/agilis-piezo-linear-stage-with-conex-controller__;!!G_uCfscf7eWS!esBpnKdccckn_TlnsWE5ruJncpjWNfxHfi8SNZ2M5qWp8ab4wjlgsB18EO_4YOzuwREd1qW6ipequMg2cHFGxsaFyd4$
The device has a USB interface and uses FTDI. When I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62289.315988] usb 1-4: new full-speed USB device number 10 using xhci_hcd
[62289.447505] usb 1-4: New USB device found, idVendor=104d, idProduct=3006, bcdDevice= 6.00
[62289.447514] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[62289.447518] usb 1-4: Product: CONEX-AGP
[62289.447520] usb 1-4: Manufacturer: Newport
[62289.447522] usb 1-4: SerialNumber: A6UJN7YS
[62289.450490] ftdi_sio 1-4:1.0: FTDI USB Serial Device converter detected
[62289.450536] usb 1-4: Detected FT232R
[62289.451085] usb 1-4: FTDI USB Serial Device converter now attached to ttyUSB0
The device is now available on /dev/ttyUSB0.
I expected to be able to do the same thing with a newer CONEX-AGAP controller.
https://urldefense.us/v3/__https://www.newport.com/f/conex-piezo-absolute-positioning-mirror-mount__;!!G_uCfscf7eWS!esBpnKdccckn_TlnsWE5ruJncpjWNfxHfi8SNZ2M5qWp8ab4wjlgsB18EO_4YOzuwREd1qW6ipequMg2cHFG2VO-mdQ$
However, when I plug in the device on my RHEL 9 machine I see these messages in dmesg:
[62360.327898] ftdi_sio ttyUSB0: FTDI USB Serial Device converter now disconnected from ttyUSB0
[62360.327934] ftdi_sio 1-4:1.0: device disconnected
[62363.524320] usb 1-4: new full-speed USB device number 11 using xhci_hcd
Note that I do not get the messages about ftdi_sio detected or the message about attaching to ttyUSBx.
The new CONEX-AGAP works fine on Windows, where it appears as a COM port. I can configure the COM port with EPICS:
drvAsynSerialPortConfigure("serial1", "COM5", 0, 0, 0)
asynOctetSetInputEos("serial1",0,"\r\n")
asynOctetSetOutputEos("serial1",0,"\r\n")
asynSetOption("serial1",0,"baud","921600")
asynSetOption("serial1",0,"bits","8")
asynSetOption("serial1",0,"stop","1")
asynSetOption("serial1",0,"parity","none")
asynSetOption("serial1",0,"clocal","Y")
asynSetOption("serial1",0,"crtscts","N")
Given the behavior on Windows, I think the CONEX-AGAP is also an FTDI device. But if so, then why is Linux not recognizing it as such?
_________________________________________
The Budker Institute of Nuclear Physics
Novosibirsk, Russia
Message: 3
Date: Fri, 20 Jun 2025 17:27:15 +0200
From: Dariush Hampai <dariush.hampai at lnf.infn.it>
To: tech-talk at aps.anl.gov
Subject: Some questions about CaLab
Message-ID: <239527c2-f231-4cea-b327-d81f47d38a06 at lnf.infn.it>
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi all,
I have some problems with CaLab, necessary to integrate epics with a
LabView interface. In particular now I have two big problems:
1) i don't understand how to use multiple field in the same CA. For
example, my newport IOC includes some records of the type
mm4006:m11.HOMF
mm4006:m11.MOVN
etc...
CaLab Put.vi does not include the field. What do I do? if I put (for
example) mm4006:m11.HOMF and mm4006:m11.MOVN as PV I find two distinct
PVs...
2) I am trying to generate a monitor of the various IOCs. When starting
LabView there is no PV (via CaLab info.vi). If I start the IOCs I see
the PVs. However if I stop the IOCs, via command prompt (caget etc...) I
do not see (obviously) the active CA, while via CaLab info.vi the CA are
still active and give me the last values read. Even after a reset of PV,
using CaLab_Disconnect.vi, I still see the active CAs with the last
value read. Where am I going wrong?
Dariush
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room: +39.06.9403.5248
Lab.: +39.06.9403.2286
Mob.: +39.06.9403.8025
Fax.: +39.06.9403.2597
- Re: Some questions about CaLab (Dariush Hampai) Kathryn Baker - STFC UKRI via Tech-talk
- Re: Some questions about CaLab (Dariush Hampai) Carsten Winkler via Tech-talk
<2025>
<2025>
