Dear Tech-Talk,
I have a question regarding the buffer overflow issue caused by
_FORTIFY_SOURCE=3 in Ubuntu 24.04.
I have seen that in EPICS 7.0.8.1, this problem was worked around by
redefining _FORTIFY_SOURCE to 2. Then, in EPICS 7.0.9, the flag was reset
to 3, but the issue was fixed in the code.
By comparing the two versions, I see a lot of changes, mostly in .c files,
and I assume most of them are related to fixing the buffer overflow issue.
First, I want to know if I understood this correctly.
Secondly, what is the solution for R3.15.9? Is setting -D_FORTIFY_SOURCE=2
enough? Or will there be a fix for this in a future R3.15.9 release?
Best regards
Bushra
- Re: Fix buffer overflow issue in Epics 3.15 Ralph Lange via Tech-talk
RE: Issues in MCA module with XFlash detector Abdalla Ahmad via Tech-talk
<2025>
RE: Issues with drvAsynIPServerPort for UDP Mark Rivers via Tech-talk
<2025>
