On 9/19/25 00:35, Marco Filho wrote:
Ah, I think I didn't properly understand this email on the first
read.
> Generally, I have found that the more effective way to
coordinate connect/disconnect is at the driver level. Generally
with a special device support to drive on-connect processing.
You mean disconnecting from the actual equipment before the PVs
are initialized and then only connecting once all the links are
properly initialized?
If so, how do you detect at driver level that that has happened?
I think you have right idea, although the other way around. My
thinking is that a driver initializes into a latched "error"
state, which is cleared by processing a record. I like this
approach because it naturally leads to handling the initial
connection the same as a re-connect.
In the asyn language, I suppose this would mean starting with
autoConnect=0, then setting it to 1 from a asynRecord.
I can imagine connecting some record to a calcout INAV field and
sending that value to the driver, but that only guarantees that
that particular record is initialized, no?
Correct, or similar conditions with eg. IVOA "Don't drive
outputs". And so far this has been enough for the cases I have
encountered.
Is there a better approach?
Thinking about it, it might help the situation if iocInit()
sequencing waited for local CA links to become connected. This
turns out not to be so difficult to achieve.
https://github.com/epics-base/epics-base/pull/713
Marco
On 9/18/25 07:54, Johnson, Andrew
N. via Tech-talk wrote:
Many of our IOCs use one or more “dbpf”
commands in their startup script (sometimes after an
epicsThreadSleep) ...
Nooooooo!
Finding a bunch of random, rarely commented, dbpf calls in an
IOC start script is to me a bad code smell. The same goes for
sleeps, only more so. Please investigate 'field(PINI,
"RUNNING")', or look at other ways to actually synchronize
startup.
... it should even be possible to handle
disconnections and later reconnections for links to remote
IOCs if you want to do that.
imo. any well written driver for an ethernet attached device
__needs__ to do this.
Generally with a special device support to drive on-connect
processing.
