1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Problem with drvAsynIPPortConfigure
To: Dariush Hampai <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 18 Sep 2025 15:45:21 +0000
That should definitely work.
Please send:
- The complete output when you rebuild the IOC application.
- The complete output when the IOC boots
- The output of the iocsh "help" command after the IOC boots.
-----Original Message-----
Sent: Thursday, September 18, 2025 10:43 AM
To: Mark Rivers <[email protected]>; [email protected]
Subject: Re: Problem with drvAsynIPPortConfigure
Hi Mark,
the base.dbd already there... however chanking the order the problem still remain...
PROD_IOC = mdrive_1IOC
# mdrive_1IOC.dbd will be created and installed DBD += mdrive_1IOC.dbd
# mdrive_1IOC.dbd will be made up from these files:
mdrive_1IOC_DBD += base.dbd
# Include dbd files from all support applications:
#mdrive_1IOC_DBD += xxx.dbd
mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_DBD += drvAsynIPPort.dbd
mdrive_1IOC_DBD += stream-base.dbd
# Add all the support libraries needed by this IOC #mdrive_1IOC_LIBS += xxx mdrive_1IOC_LIBS += stream mdrive_1IOC_LIBS += asyn
Il 18/09/2025 17:37, Mark Rivers ha scritto:
> Hi Dariush,
> I think you have the order of your dbd files wrong.  They should be in this order:
> Is stream-base.dbd part of the StreamDevice module, or is that something local to your site?  The files you listed did not include base.dbd, which should come first.  So I think it should really be:
> mdrive_1IOC_DBD += stream.dbd
> Mark
> From: Dariush Hampai <[email protected]>
> Sent: Thursday, September 18, 2025 10:21 AM
> To: [email protected]; Mark Rivers <[email protected]>
> Subject: Problem with drvAsynIPPortConfigure
> hi Community,
> I'm writing an IOC for industrial motor driver:
> I prepare the IOC, in particular:
> 1) in the configure/RELASE there is
> SUPPORT=$(EPICS_BASE)/synApps_6_3/support
> ASYN=$(SUPPORT)/asyn-R4-44-2
> STREAM=$(SUPPORT)/StreamDevice-2-8-24
> EPICS_BASE = /home/xlabsrv2/epics
> 2) in the mdrive_1IOC/src/Makefile there is mdrive_1IOC_DBD +=
> stream-base.dbd mdrive_1IOC_DBD += drvAsynIPPort.dbd mdrive_1IOC_DBD
> += asyn.dbd
> 3) in the mdrive_1IOC/Db/Makefile there is DB += mdrive_1IOC.proto DB
> += mdrive_1IOC.db DB += mdrive_1IOC.val
> 4) in the mdrive_1IOC/Db/mdrive_1IOC.val there is file db/mdrive_1IOC.db {
>       pattern { card, axis, ASYNPORT, MOT, EGU, homing, MRES, direct }
>           { 1, 1 , "ip_x", "mdrive_x", mm, 1, 411, + } }
> 5) in the st.cmd there is
> epicsEnvSet ("STREAM_PROTOCOL_PATH", "${TOP}/db") epicsEnvSet
> ("PORT_mdrive_x", "ip_x")
> drvAsynIPPortConfigure($(PORT_mdrive_x), "100.100.0.23:503")
> asynOctetSetInputEos($(PORT_mdrive_x),0,"\n\r")
> asynOctetSetOutputEos($(PORT_mdrive_x),0,"\n\r")
> asynSetTraceMask($(PORT_mdrive_x),-1,0x9);
> asynSetTraceIOMask($(PORT_mdrive_x),-1,0x2)
> These are the configurations. After make (all is ok), executing the
> st.cmd I receive the following error
> [xlabsrv2@xlabsrv2 iocmdrive_1IOC]$ ./st.cmd
> #!../../bin/linux-x86_64/mdrive_1IOC
> < envPaths
> epicsEnvSet("IOC","iocmdrive_1IOC")
> epicsEnvSet("TOP","/home/xlabsrv2/epics/IOCs/mdrive_1IOC")
> epicsEnvSet("SUPPORT","/home/xlabsrv2/epics/synApps_6_3/support")
> epicsEnvSet("ASYN","/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-4
> 4-2")
> epicsEnvSet("STREAM","/home/xlabsrv2/epics/synApps_6_3/support/StreamD
> evice-2-8-24")
> epicsEnvSet("EPICS_BASE","/home/xlabsrv2/epics")
> cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC"
> "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/db")
> epicsEnvSet ("PORT_mdrive_x", "ip_x")
> #X Axis
> drvAsynIPPortConfigure(ip_x, "100.100.0.23:503") ERROR st.cmd line 36: Command drvAsynIPPortConfigure not found.
> asynOctetSetInputEos(ip_x,0,"\n\r")
> ERROR st.cmd line 37: Command asynOctetSetInputEos not found.
> asynOctetSetOutputEos(ip_x,0,"\n\r")
> ERROR st.cmd line 38: Command asynOctetSetOutputEos not found.
> asynSetTraceMask(ip_x,-1,0x9);
> ERROR st.cmd line 40: Command asynSetTraceMask not found.
> asynSetTraceIOMask(ip_x,-1,0x2)
> ERROR st.cmd line 41: Command asynSetTraceIOMask not found.
> ## Register all support components
> dbLoadDatabase "dbd/mdrive_1IOC.dbd"
> mdrive_1IOC_registerRecordDeviceDriver pdbbase ## Load record
> instances
> #dbLoadRecords("db/mdrive_1IOC.db","user=xlabsrv2")
> dbLoadTemplate("db/mdrive_1IOC.val")
> dbLoadTemplate: Too many values given, line 14.
> cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC"
> iocInit
> Starting iocInit
> ## EPICS R7.0.8.2-DEV
> ## Rev. R7.0.8.1-142-g144f9756eac4e800f18d
> ## Rev. Date Git: 2025-02-05 10:16:16 -0600
> 2025/09/18 16:04:01.785392 _main_ Cannot find a bus named 'ip_x' for 'mdrive_x:model'
> 2025/09/18 16:04:01.785498 _main_ mdrive_x:model: Can't attach to bus
> ip_x 0
> 2025/09/18 16:04:01.785517 _main_ mdrive_x:model: Record
> initialization failed
> iocRun: All initialization complete
> ## Start any sequence programs
> #seq sncxxx,"user=xlabsrv2"
> epics>
> searching in previous threads I found missing the "drvAsynIPPort.dbd"
> in src/Makefile, but I already put it. Moreover I use "make clean
> all", and (to be sure) in this case I also remove db, dbd, and lib
> folders to restart with a clean make
> where ma I wrong?
> thank you in advance!!!
> Dariush
> p.s.: all other IOCs using drvAsynIPPortConfigure working properly...
> Dr. Dariush Hampai, PhD
> INFN - LNF
> X-Lab Frascati
> Via E. Fermi, 54 (ex 40)
> I-00044 Frascati (RM)
> Italy
> Mail Address:
> XLab-Frascati
> LNF-INFN
> Casella Postale 13
> Frascati (RM)
> Italy
> Room:	+39.06.9403.5248
> Lab.:	+39.06.9403.2286
> Mob.:	+39.06.9403.8025
> Fax.:	+39.06.9403.2597
INFN - LNF
X-Lab Frascati
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
RE: Problem with drvAsynIPPortConfigure Mark Rivers via Tech-talk
Re: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Prev: Re: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Next: Re: Help with bumpless IOC reboot, record linking and initialization concepts Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: Problem with drvAsynIPPortConfigure Henrique F. Simoes via Tech-talk
