1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Subject: Re: EPICS support for Fastech motors
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Rea Domitrović <rea.domitrovic at irb.hr>, Mark Rivers <rivers at cars.uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 26 Jun 2026 12:41:09 +0200
Hej Rea,
The most common protocol to talk to a motion controller
seems to be ASCII (and that is what we find everywhere...)
However, if you need to write binary data and read binary data
and you know how many bytes you get as a response from the controller,
you can use this function:
asynStatus asynMotorController::writeReadController(const char *output, char *input, size_t maxChars, size_t *nread, double timeout)
Note 1:
You can use the pre-allocated buffers
outString_, inString_
(as long as your data is shorter that the buffersize)
And yes, memcpy may be better than snprintf, kind of.
Note 2:
You can even build up your own data structure and use that.
Make sure to not mess up the endianess or alignemnts and try to
stick to fixed data type like uint8_t, uint16_t and friends.
Do not hesitate to ask more questions.
/Torsten
On 2026-06-26 09:50, Rea Domitrović via Tech-talk wrote:
Hi Mark,
thanks for taking the time. I followed the debug instructions you gave here: https://epics.anl.gov/tech-talk/2017/msg00282.php <https:// epics.anl.gov/tech-talk/2017/msg00282.php> - thanks for clarifying what is actually needed.
I suspect this message is what's wrong, i.e. the writes are not actually getting through to the motor:
2026/06/26 09:39:45.144 asynMotorController:writeFloat64 error, status=1 axis=0, function=1, value=-150000.000000 2026/06/26 09:39:45.148 devMotorAsyn::asynCallback: EXIT:zpos pasyn{Float64,Int32}->write returned
To me, it smells like the problem is in the fact the motor doesn't use ASCII-compatible strings to communicate - every message has to start with a five-byte header of the following structure: 0xAA, length, idempotence counter, 0x00, frame type. That null byte is presumably making communication difficult; that is why everywhere in the source code I used memcpy instead of sprintf to build the outString. A test IOC made with StreamDevice instead of Motor confirms the motor is responsive to that kind of communication; I was able to turn the servo on and poll it for position using StreamDevice, but not actually move it.
Is it even possible to use the Model 3 framework to communicate with something that uses such a specific and non-standard byte stream, or will I have to find a different way? Kind regards,
Rea
*Sent:* Thursday, June 25, 2026 4:35:51 PM
*To:* tech-talk at aps.anl.gov; Rea Domitrović
*Subject:* Re: EPICS support for Fastech motors
H Rea,
You have set the asynTraceMask to enable lots of debugging.  That is OK, but it makes it hard to see the real errors from warning and informational messages.  For example these messages are printed with ASYN_TRACE_FLOW, they are not really errors.
2026/06/25 15:29:48.311 asynPortDriver:getDoubleParam: port=motorExit error getting parameter 9 MOTOR_ENCODER_POSITION, in list 0, value undefined 2026/06/25 15:29:48.311 asynPortDriver:getDoubleParam: port=motorExit error getting parameter 5 MOTOR_VELOCITY, in list 0, value undefined
This message
2026/06/25 15:07:46.444 asynMotorController:writeFloat64: Set driver motorExit, axis 0 move absolute to 0.000000, base velocity=500.000000, velocity=25000.000000, acceleration=245000.000000
is being printed here.  It is just an informational message.
https://urldefense.us/v3/__https://github.com/epics-modules/motor/blob/__;!!G_uCfscf7eWS!fs3Q3dFfefRa8O3WpY_fCal9SNYY7rdJifOzcM2Lg1JdW_AoXJ374qo4mVpNfD9YB90Q8NWBtMExq9JM9cU$ f3d089bae20d04f8b9ed18fcfdc55274075d6a42/motorApp/MotorSrc/ asynMotorController.cpp#L328 <https://urldefense.us/v3/__https:// github.com/epics-modules/motor/blob/ f3d089bae20d04f8b9ed18fcfdc55274075d6a42/motorApp/MotorSrc/ asynMotorController.cpp*L328__;Iw!!G_uCfscf7eWS! YyBnhmn8oSzP0Q7YGyZRHwOrKRtwVx6pVJVzL_7hWYrhD4vCyf_2K9axzV2KLsXHJfby10TfQ8-jHe0SehaOIdd-KSC7aA$>
However, this message:
2026/06/25 15:07:46.445 asynMotorController:writeFloat64 error, status=1 axis=0, function=1, value=0.000000
is being printed here:
https://urldefense.us/v3/__https://github.com/epics-modules/motor/blob/__;!!G_uCfscf7eWS!fs3Q3dFfefRa8O3WpY_fCal9SNYY7rdJifOzcM2Lg1JdW_AoXJ374qo4mVpNfD9YB90Q8NWBtMExq9JM9cU$ f3d089bae20d04f8b9ed18fcfdc55274075d6a42/motorApp/MotorSrc/ asynMotorController.cpp#L428 <https://urldefense.us/v3/__https:// github.com/epics-modules/motor/blob/ f3d089bae20d04f8b9ed18fcfdc55274075d6a42/motorApp/MotorSrc/ asynMotorController.cpp*L428__;Iw!!G_uCfscf7eWS! YyBnhmn8oSzP0Q7YGyZRHwOrKRtwVx6pVJVzL_7hWYrhD4vCyf_2K9axzV2KLsXHJfby10TfQ8-jHe0SehaOIdfrAqeHkQ$>
Function=1 is a move absolute command, so it is consistent with the first message.  status=1 means that your driver's pAxis->move() function returned -1.  It was called from here: https://urldefense.us/v3/__https://github.com/epics-modules/motor/blob/__;!!G_uCfscf7eWS!fs3Q3dFfefRa8O3WpY_fCal9SNYY7rdJifOzcM2Lg1JdW_AoXJ374qo4mVpNfD9YB90Q8NWBtMExq9JM9cU$ f3d089bae20d04f8b9ed18fcfdc55274075d6a42/motorApp/MotorSrc/ asynMotorController.cpp#L324-L325 <https://urldefense.us/v3/__https:// github.com/epics-modules/motor/blob/ f3d089bae20d04f8b9ed18fcfdc55274075d6a42/motorApp/MotorSrc/ asynMotorController.cpp*L324-L325__;Iw!!G_uCfscf7eWS! YyBnhmn8oSzP0Q7YGyZRHwOrKRtwVx6pVJVzL_7hWYrhD4vCyf_2K9axzV2KLsXHJfby10TfQ8-jHe0SehaOIdeQizbqlg$>
If you set your asynTrace flags to ERROR|WARNING you will only see the more important messages.
*From:* Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Rea Domitrović via Tech-talk <tech-talk at aps.anl.gov>
*Sent:* Thursday, June 25, 2026 8:53 AM
*To:* tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi all,
thanks so much for pointing me in the right direction so far. I've got to the point where I've got the structure of a driver based on the MCB4B driver and with inspiration from the SmarAct driver; however, at runtime, I'm getting errors that I'm struggling to diagnose. If someone could help me understand, I would be most grateful. Relevant info is below. Best,
Rea Domitrović
Institut Ruđer Bošković
Zagreb, Croatia
Source code is here: https://urldefense.us/v3/__https://github.com/redomitro/motorFastech__;!!G_uCfscf7eWS!fs3Q3dFfefRa8O3WpY_fCal9SNYY7rdJifOzcM2Lg1JdW_AoXJ374qo4mVpNfD9YB90Q8NWBtMExNp2K54g$ <https:// urldefense.us/v3/__https://urldefense.us/v3/__https://github.com/redomitro/motorFastech__;!!__;!!G_uCfscf7eWS!fs3Q3dFfefRa8O3WpY_fCal9SNYY7rdJifOzcM2Lg1JdW_AoXJ374qo4mVpNfD9YB90Q8NWBtMEx0fR0RiM$ G_uCfscf7eWS! ckejUTszXgikK0HKxA_InFEgeEyYG2lD41P9WU4hEdAGledQERL0dK2U_KIYaLsarWXmtRkeqsmdlOkbbDFNsrR52DGXQg$>
IOCinit output:
2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_MOVE_REL, index=0 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_MOVE_ABS, index=1 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_MOVE_VEL, index=2 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_HOME, index=3 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_STOP_AXIS, index=4 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_VELOCITY, index=5 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_VEL_BASE, index=6 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_ACCEL, index=7 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_POSITION, index=8 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_RESOLUTION, index=12 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_ENCODER_RATIO, index=13 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_PGAIN, index=14 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_IGAIN, index=15 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_DGAIN, index=16 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_HIGH_LIMIT, index=17 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_LOW_LIMIT, index=18 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_CLOSED_LOOP, index=19 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_STATUS, index=25 2026/06/25 15:29:48.311 asynPortDriver:drvUserCreate: drvInfo=MOTOR_UPDATE_STATUS, index=26
2026/06/25 15:29:48.311 motorExit 0 registerInterruptUser
2026/06/25 15:29:48.311 asynPortDriver:getDoubleParam: port=motorExit error getting parameter 9 MOTOR_ENCODER_POSITION, in list 0, value undefined 2026/06/25 15:29:48.311 asynPortDriver:getDoubleParam: port=motorExit error getting parameter 5 MOTOR_VELOCITY, in list 0, value undefined 2026/06/25 15:29:48.311 asynMotorController:readGenericPointer: MotorStatus = status34, position=425203751.000000, encoder position=0.000000, velocity=0.000000
2026/06/25 15:29:48.311 motorExit asynManager::queueLockPort locking port
2026/06/25 15:29:48.311 motorExit asynManager::queueLockPort created queueLockPortPvt=0x561069c8f7a0 2026/06/25 15:29:48.311 motorExit asynManager::queueLockPort created queueLockPortPvt=0x561069c8f7a0, event=0x561069c979e0, mutex=0x561069c97990 2026/06/25 15:29:48.311 motorExit asynManager::queueLockPort taking mutex 0x561069c97990 2026/06/25 15:29:48.311 motorExit asynManager::queueLockPort queueing request 2026/06/25 15:29:48.311 motorExit addr 0 queueRequest priority 0 not lockHolder 2026/06/25 15:29:48.311 motorExit schedule queueRequest timeout in 2.000000 seconds 2026/06/25 15:29:48.311 motorExit asynManager::queueLockPort waiting for event
2026/06/25 15:29:48.312 motorExit 0 autoConnect
2026/06/25 15:29:48.312 asynPortDriver:connect:, pasynUser=0x561069c83188
2026/06/25 15:29:48.312 asynManager::portThread port=motorExit callback
2026/06/25 15:29:48.312 motorExit asynManager::queueLockPortCallback signaling begin event 2026/06/25 15:29:48.312 motorExit asynManager::queueLockPortCallback waiting for mutex from queueUnlockPort 2026/06/25 15:29:48.312 motorExit asynManager::queueLockPort got event from callback 2026/06/25 15:29:48.312 EXIT:zpos devMotorAsyn::statusCallback new value=[p:425203751.000000,e:0.000000,s:22] 2026/06/25 15:29:48.312 asynMotorController:writeFloat64: Set driver motorExit, axis 0 encoder ratio=1.000000 2026/06/25 15:29:48.312 asynMotorController:writeFloat64:: axis=0, function=13, value=1.000000
2026/06/25 15:29:48.312 asynFloat64SyncIO wrote: 1.000000e+00
2026/06/25 15:29:48.312 motorExit queueUnlockPort
2026/06/25 15:29:48.312 motorExit asynManager::queueUnlockPort waiting for event 2026/06/25 15:29:48.313 motorExit queueUnlockPort unlock mutex 0x561069c97990 complete. 2026/06/25 15:29:48.313 devMotorAsyn::init_controller, EXIT:zpos set encoder ratio to 1.000000 2026/06/25 15:29:48.313 devMotorAsyn::init_controller, EXIT:zpos setting of position not required, position=425203751.000000, mres=0.000200, dval=0.000000, rdbd=0.0002002026/06/25 15:29:48.313 EXIT:zpos devMotorAsyn::update_values, needUpdate=1 2026/06/25 15:29:48.313 devMotorAsyn::build_trans: EXIT:zpos motor_cmnd=19, pact=0, value=375000.000000 2026/06/25 15:29:48.313 devAsynMotor::build_trans: calling queueRequest, pmsg=0x561069c97c40, sizeof(*pmsg)=24pmsg->command=14, pmsg- >interface=1, pmsg->dvalue=375000.000000 2026/06/25 15:29:48.313 motorExit addr 0 queueRequest priority 0 not lockHolder 2026/06/25 15:29:48.313 devMotorAsyn::build_trans: EXIT:zpos motor_cmnd=20, pact=0, value=-375000.000000 2026/06/25 15:29:48.313 devAsynMotor::build_trans: calling queueRequest, pmsg=0x561069c97c90, sizeof(*pmsg)=24pmsg->command=15, pmsg- >interface=1, pmsg->dvalue=-375000.000000 2026/06/25 15:29:48.313 motorExit addr 0 queueRequest priority 0 not lockHolder
2026/06/25 15:29:48.313 asynManager::portThread port=motorExit callback
2026/06/25 15:29:48.313 devMotorAsyn::asynCallback: EXIT:zpos pmsg=0x561069c97c40, sizeof(*pmsg)=24, pmsg->command=14,pmsg- >interface=1, pmsg->ivalue=0, pmsg->dvalue=375000.000000, pasynUser- >reason=17 2026/06/25 15:29:48.313 asynMotorController:writeFloat64: Set driver motorExit, axis 0 high limit=375000.000000 2026/06/25 15:29:48.313 asynMotorController:writeFloat64:: axis=0, function=17, value=375000.000000
2026/06/25 15:29:48.313 devMotorAsyn::asynCallback: EXIT:zpos pmsg=0x561069c97c90, sizeof(*pmsg)=24, pmsg->command=15,pmsg- >interface=1, pmsg->ivalue=0, pmsg->dvalue=-375000.000000, pasynUser- >reason=18 2026/06/25 15:29:48.313 asynMotorController:writeFloat64: Set driver motorExit, axis 0 low limit=-375000.000000 2026/06/25 15:29:48.313 asynMotorController:writeFloat64:: axis=0, function=18, value=-375000.000000
Output when attempting to caput absolute position:
2026/06/25 15:07:44.438 192.168.0.204:3001 UDP write 3
\xaa\v\a
2026/06/25 15:07:46.444 asynMotorController:writeFloat64: Set driver motorExit, axis 0 move absolute to 0.000000, ba                       se velocity=500.000000, velocity=25000.000000, acceleration=245000.000000 2026/06/25 15:07:46.445 asynMotorController:writeFloat64 error, status=1 axis=0, function=1, value=0.000000 2026/06/25 15:07:46.445 devMotorAsyn::asynCallback: EXIT:zpos pasyn{Float64,Int32}->write returned
2026/06/25 15:07:46.445 EXIT:zpos devMotorAsyn::update_values, needUpdate=1
*Sent:* Wednesday, June 17, 2026 21:07
*To:* Torsten Bögershausen; tech-talk at aps.anl.gov; Rea Domitrović
Hi Rea,
      I see that driver developers prefer to use octet-based
    communication rather than use the manufacturer-provided libraries.
    Is there a reason why that is the case, or is it simply that octet-
    based communicaton is more universal?
Manufacturer libraries will be provided for specific operating system and specific versions of those OS. That can restrict where they can be deployed.  They may restrict redistribution, which prevents including them in the motor Github repository.  They almost certainly won't be supported on real-time OS like RTEMS or vxWorks.
    Further, the Fastech controller allows both octet-based
    communication and library-based communication, but octet-based
    communication requires the master to send a one-byte "sync number"
    which serves as an idempotence token. I assume it would be necessary
    to implement that myself; could I be using some sort of global
    variable, and how do I make sure that I never land on the same
    number twice in a row?
Many protocols have something like that.  You just have a member variable in your driver class that increments by 1 on each message it sends, and wraps back to 0 after 255.
*Sent:* Wednesday, June 17, 2026 8:34 AM
*To:* Torsten Bögershausen <tboegi at edom.se>; tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Hi Torsten,
thanks for pointing me in the right direction. I'm looking at the manual and the source for other submodules now (motorSmarAct and motorAcs); I see that driver developers prefer to use octet-based communication rather than use the manufacturer-provided libraries. Is there a reason why that is the case, or is it simply that octet-based communicaton is more universal?
Further, the Fastech controller allows both octet-based communication and library-based communication, but octet-based communication requires the master to send a one-byte "sync number" which serves as an idempotence token. I assume it would be necessary to implement that myself; could I be using some sort of global variable, and how do I make sure that I never land on the same number twice in a row? Kind regards,
Rea
*Sent:* Wednesday, June 10, 2026 1:49:41 PM
*To:* Rea Domitrović; tech-talk at aps.anl.gov
Hej Rea,
I haven't worked with them, no.
If you have Ethernet (not to be confused with EtherCAT),
I read the manual as if they use UDP for communication,
and knowing that you can write a simple model 3 driver, I think.
(Other suggestions are welcome of course)
/Torsten
On 2026-06-10 12:52, Rea Domitrović via Tech-talk wrote:
 > Hi all,
 > I'm working with some Fastech Ezi-Servo II Plus-E motors, and I was
 > wondering if someone had already worked with them and/or made an EPICS
 > driver or Motor submodule? This particular line of motors and
 > drives uses an Ethernet interface. Kind regards,
 > Rea Domitrović
 > Zagreb, Croatia
Oprez: Ova poruka stigla je od vanjskog pošiljatelja. Prije otvaranja poveznica ili privitaka provjerite pošiljatelja. Caution:This email originated from an external sender. Please verify the sender before opening links or attachments. *Oprez:* Ova poruka stigla je od vanjskog pošiljatelja. Prije otvaranja poveznica ili privitaka provjerite pošiljatelja. *Caution:*This email originated from an external sender. Please verify the sender before opening links or attachments. *Oprez:* Ova poruka stigla je od vanjskog pošiljatelja. Prije otvaranja poveznica ili privitaka provjerite pošiljatelja. *Caution:*This email originated from an external sender. Please verify the sender before opening links or attachments.
EPICS support for Fastech motors Rea Domitrović via Tech-talk
Re: EPICS support for Fastech motors Torsten Bögershausen via Tech-talk
Re: EPICS support for Fastech motors Rea Domitrović via Tech-talk
Re: EPICS support for Fastech motors Mark Rivers via Tech-talk
Prev: RFC: add a mechanism to call epicsExit when signals are received Timothy Speight - STFC UKRI via Tech-talk
Next: Re: EPICS support for Fastech motors Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  <2026
Prev: Re: EPICS support for Fastech motors Rea Domitrović via Tech-talk
ANJ, 26 Jun 2026 · Home · News · About · Talk · Base · Modules · Extensions ·
