<20122013  2014  2015  2016  2017  2018  2019  Index <20122013  2014  2015  2016  2017  2018  2019
Subject: Survey comments
Date: Mon, 4 Jun 2012 16:10:27 +0000
Hi Andrew,
Just a comment on your item 1:
>1.    Default installation should support C++ and python development
>We will be working on a python wrapper for EPICS Qt soon - (probably using SWIG?)
The path of least resistance seems to be using SIP and PyQt from:
http://www.riverbankcomputing.co.uk
All Qt-designer widgets can already be used in python code. Python widgets can be used in Qt-designer as plugins :
http://www.riverbankcomputing.co.uk/static/Docs/PyQt4/html/designer.html#writing-qt-designer-plugins
Also, I think working within the tried-and-true Model-View-Controller design pattern is a good choice for Qt and EPICS Qt.
Ivan
[email protected]
RE: Survey comments Andrew Rhyder
Prev: Survey comments Andrew Rhyder
Next: RE: Survey comments Andrew Rhyder
Index: <20122013  2014  2015  2016  2017  2018  2019
ANJ, 04 Jun 2012 · Home · News · About · Talk · Base · Modules · Extensions ·
