2012  2013  2014  <2015>  2016  2017  2018  2019  Index 2012  2013  2014  <2015>  2016  2017  2018  2019
Subject: RE: epicsQt-R3-1-0: Build Experience
To: "Williams Jr., Ernest L." <[email protected]>
Cc: "[email protected]" <[email protected]>, Lucas J Monteiro Carvalho <[email protected]>, "Babbitt, Alisha" <[email protected]>, Zai Wang <[email protected]>
Date: Wed, 10 Jun 2015 14:11:55 +0000
Hi Ernest
I am pretty much getting what you are Still not clear to me what is going on. I'll keep on looking into it. Let me know if you come across what is exactly the problem.
Regards
Andrew
-----Original Message-----
From: Williams Jr., Ernest L. [mailto:[email protected]]
Sent: Wednesday, 10 June 2015 7:58 PM
To: Andrew Rhyder
Cc: [email protected]; Babbitt, Alisha; Lucas J Monteiro Carvalho; Zai Wang; [email protected]; Szalata, Zenon M.; Williams Jr., Ernest L.
Hi Andrew,
Almost there :
Okay, in order to make this work I have to execute qmake manually in the <>/framework directory
So, the steps that work are:
cd <...>/epicsQt-R3-1-0
mkdir framework/designer
make clean
qmake
cd  <...>/epicsQt-R3-1-0/framework
qmake
make
make install
But there indeed is one more target directory for the plugin library:
/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64/designer
I had to copy  "libQEPlugin.so" to the <>/lib/linux-x86_64/designer folder after make install
=========== Below is the output of make install =======================================
[ernesto@icd-pc90626 epicsQt-R3-1-0]$ make install cd framework/ && ( test -e Makefile || /afs/slac/g/lcls/package/Qt-5.4.1/bin/qmake /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/framework/framework.pro -o Makefile ) && make -f Makefile install
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/framework'
install -m 755 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/framework/designer/libQEPlugin.so /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64/
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/framework'
Sent: Wednesday, June 10, 2015 2:31 AM
To: Andrew Rhyder
Hi Andrew,
I extracted the tar ball again and follow your instructions:
I still get the same result  :(
make[1]: Nothing to be done for `install'.
cd applications/QEGuiApp/ && ( test -e Makefile || /afs/slac/g/lcls/package/Qt-5.4.1/bin/qmake /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEGuiApp/QEGuiApp.pro -o Makefile ) && make -f Makefile install
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEGuiApp'
install -m 755 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEGuiApp/bin/qegui /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/bin/linux-x86_64/
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEGuiApp'
cd applications/QEReadArchiveApp/ && ( test -e Makefile || /afs/slac/g/lcls/package/Qt-5.4.1/bin/qmake /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEReadArchiveApp/QEReadArchiveApp.pro -o Makefile ) && make -f Makefile install
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEReadArchiveApp'
install -m 755 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEReadArchiveApp/bin/qerad /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/bin/linux-x86_64/
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEReadArchiveApp'
cd applications/QEMonitorApp/ && ( test -e Makefile || /afs/slac/g/lcls/package/Qt-5.4.1/bin/qmake /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEMonitorApp/QEMonitorApp.pro -o Makefile ) && make -f Makefile install
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEMonitorApp'
install -m 755 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEMonitorApp/bin/qemonitor /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/bin/linux-x86_64/
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEMonitorApp'
cd applications/QEWidgetDisplayApp/ && ( test -e Makefile || /afs/slac/g/lcls/package/Qt-5.4.1/bin/qmake /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEWidgetDisplayApp/QEWidgetDisplayApp.pro -o Makefile ) && make -f Makefile install
make[1]: Entering directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEWidgetDisplayApp'
install -m 755 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEWidgetDisplayApp/bin/QEWidgetDisplay /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/bin/linux-x86_64/
make[1]: Leaving directory `/afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/applications/QEWidgetDisplayApp'
install -m 755 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/documentation/QE_FrameworkOverview.pdf /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/documentation/
install -m 644 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/documentation/QE_GettingStarted.pdf /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/documentation/
install -m 644 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/documentation/QE_QEGuiAndUserInterfaceDesign.pdf /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/documentation/
install -m 644 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/documentation/QE_ReferenceManual.pdf /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/documentation/
install -m 644 -p /afs/slac.stanford.edu/g/lcls/vol8/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/epicsQt/epicsQt-R3-1-0/documentation/QE_ReleaseProcedure.pdf /afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/documentation/
Sent: Tuesday, June 9, 2015 11:36 PM
To: Williams Jr., Ernest L.
Hi Ernest
Can you please try creating the <...>/epicsQt-R3-1-0/framework/designer   directory before running qmake.
It appears that if the designer directory is present when qmake is run the appropriate install steps are set up in Makefile.
In detail:
make clean
qmake
make
make install
If you can confirm this work-around works for you I will fix it.
Regards
Andrew
Sent: Wednesday, 10 June 2015 1:14 AM
To: Andrew Rhyder
Hi Andrew,
I must have only tried makepackage.
The install does run.
However, I don't see that the library ("libQEPlugin.so") will be installed I deleted the library and ran make install; the library was not installed.
The executables do get installed. :)
Here is the output:
Sent: Tuesday, June 9, 2015 5:13 AM
Hi Ernest
My mistake... the library is installed as well. All the more reason to have a look at your install output please.
Andrew
Sent: Tuesday, 9 June 2015 15:47
To: Andrew Rhyder
Cc: [email protected]; Babbitt, Alisha; Lucas J Monteiro Carvalho; Zai Wang; [email protected]; Williams Jr., Ernest L.; Szalata, Zenon M.
Subject: epicsQt-R3-1-0:  Build Experience
Hi Andrew,
How is it going?
Thanks to you and the team for releasing 3.1.0
I am now trying to build your new epicsQT package:  "3.1.0"
First I built caQtDM version 3.9.3
For the build, process I was able to set some environment variables according to your documentation.
I have attached the script that I source before the build :)
I was also looking for a make install
Also, I tried makepackage but that did not work.
For us,  epicsQT_TOP = $EPICS_EXTENSIONS/src/epicsQt/epicsQt-R3-1-0
========= Still need to copy the application binaries manually =============== cd  <epicsQT_TOP>/applications/QEGuiApp/bin
cp qegui                      $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEMonitorApp/bin
cp qemonitor              $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEReadArchiveApp/bin
cp qerad                      $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
cd  <epicsQT_TOP>/applications/QEWidgetDisplayApp/bin
cp QEWidgetDisplay  $EPICS_EXTENSIONS/bin/$EPICS_HOST_ARCH
========= Still need to copy the framework libraries manually =============== cd  <epicsQT_TOP>/framework/designer
cp libQEPlugin.so        $EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH
cp libQEPlugin.so        $EPICS_EXTENSIONS/lib/$EPICS_HOST_ARCH/designer
Below: Are the environment variables prior to build process:
[ernesto@icd-pc90626 epicsQt-R3-1-0]$ env |grep QE
QE_CAQTDM_LIB=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64
QE_TARGET_DIR=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12
QE_FFMPEG=YES
QE_EPICS_BASE=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/base/base-R3-14-12-4_1-0
QE_CAQTDM=/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/src/caQtDM/caQtDM-R3-9-3
[ernesto@icd-pc90626 epicsQt-R3-1-0]$ env |grep QT
QTDIR=/afs/slac/g/lcls/package/Qt-5.4.1
CAQTDM_DISPLAY_PATH=/afs/slac/g/lcls/tools/caQtDM/display/Tests:/afs/slac/g/lcls/tools/caQtDM/display/iocAdmin
QTINC=/afs/slac/g/lcls/package/Qt-5.4.1/include
QTLIB=/afs/slac/g/lcls/package/Qt-5.4.1/lib
CAQTDM_DISPLAY=/afs/slac/g/lcls/tools/caQtDM/display
QT_PLUGIN_PATH=/afs/slac/g/lcls/package/qwt-6.1.2/plugins:/afs/slac/g/lcls/epics/R3-14-12-4_1-0/extensions/extensions-R3-14-12/lib/linux-x86_64:/afs/slac/g/lcls/package/Qt-5.4.1/plugins
Cheers,
Ernest
epicsQt-R3-1-0: Build Experience Williams Jr., Ernest L.
RE: epicsQt-R3-1-0: Build Experience Andrew Rhyder
RE: epicsQt-R3-1-0: Build Experience Williams Jr., Ernest L.
Prev: RE: epicsQt-R3-1-0: Build Experience Williams Jr., Ernest L.
Next: Set caLabel visible Monteiro Carvalho, Lucas Jose
Index: 2012  2013  2014  <2015>  2016  2017  2018  2019
Next: RE: edl2ui - Byte and ChoiceButton mapped Williams Jr., Ernest L.
