<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS drivers for CAN and RS232 / TCP/IP
From: Matthias Clausen DESY -MKV2/KRYK- <[email protected]>
Date: Thu, 07 Apr 1994 22:41:24 EDT
>> From: [email protected] (Martm Pi )
>> Organization: Instituto de Astrofmsica de Canarias
>> At IAC we are experimenting using CANbus systems in telescope
>> control applications. Currently we have a PC-CAN node in the
>> system but we are looking for CAN/VME cards with EPICS drivers
>> (running with VxWorks).
>> Somebody know if exist EPICS drivers for CAN, RS-232 and TCP/IP ?
>I heard that DESY is looking into this.
>Jeff
CAN
True - there's currently a VxWorks CAN 'driver' existing for the
CAN-IP module. At least two CAN modules talk to each other. This work is
done in anothr group at DESY. We will continue with this work which
probably will start in autumn. If we could work together with othrs I would
be really interested. Specially implementing the CAN-services is something
which needs more efford and should be shared.
There is another institute in Germany using CAN on VxWorks they are not
EPICS oriented and their code might come from a commercial company.
I could ask ...
RS 232
We run two protocols on RS 232 using the Greenspring IP module.
I have to check but I am afraid that the VxWorks-driver origially was
purchased from a german company.
But the EPICS device support is DESY-code.
TCP/IP
We have written a device support using UDP communication for the FNAL
'classic Protocol'. If this help s let me know...
Our current developments and drivers will be soon made available on our WWW
server.
Matthias
	Matthias Clausen		Deutsches Elektronen Synchrotron
	 Gruppe: KRYK			       DESY/Hamburg, Germany
Prev: Re: Ascii file formats and the use of EDIF winans
Next: Re: Ascii file formats and the use of EDIF winans
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Ascii file formats and the use of EDIF watson
Next: CA WAN/gateway extensions notes watson
