Subject: |
CA WAN/gateway extensions notes |
[email protected] |
Date: |
Sun, 10 Apr 94 15:24:16 -0400 |
Marty, Jeff, Bob, & John:
Here's my notes (finally) from our discussion at LANL (blurred somewhat
by time) on the subject of extending CA beyond a single subnet:
1. Extension should support the possibility of read/write or read-only
to remote PV's without administrative overhead (that is, it should
be possible without having to edit a gateway PV list).
2. Read-only, read/write, and no-access mix in both directions.
3. (Optional -- this idea was considered not important during
discussions) Possibility of imposing access control by a simple
list.
4. No remote subnet message for local PV's (that is, the first broadcast
must be constrained to the local subnet if desired).
5. CA able to handle one or more local networks on the first broadcast
(needed for OPI's with multiple network interfaces)
6. User configurable list of subnets or addresses, with control over
which addresses are used in the first broadcast.
7. Must be ready by June 1, preferably earlier for beta test. (This
constraint was requested by CEBAF to support end station to accelerator
data exchanges during commissioning).
It was agreed that 7 precludes developing a full blown name server. Jeff's
idea (developed by the group) was for CA to support a list of addresses
to contact for PV's. These addresses could be either subnet broadcast
addresses, or IP addresses of specific IOC's. The list would be user
specifiable at run time (not compiled in), with a delimiter to indicate
which addresses are used on the first try. E.g. a list might be of the
form:
ip1, ip2; ip3; ip4, ip5
In this case, the initial broadcast is sent to ip1 and ip2. After a timeout,
it is sent to ip1, ip2 and ip3. On the next timeout it would be sent to all
five. Other discussion also suggested that the time interval between
retries also be run-time configurable.
Just think: you could make an OPI display which showed the up status of
all EPICS collaboration IOC's !!!
Chip
Re: Ascii file formats and the use of EDIF watson
CA WAN/gateway extensions notes mrk
<1994>
2025
2026
EPICS drivers for CAN and RS232 / TCP/IP Matthias Clausen DESY -MKV2/KRYK-
<1994>
2025
2026
