<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Ascii file formats and the use of EDIF
Date: Fri, 08 Apr 94 20:52:10 -0400
Here's a few thoughts from a CAPFAST user:
My gut feeling is that using EDIF as the sole db format may be more
work than it is worth.  If the EDIF file contained all the graphical
info, it would be bigger and therefore load slower than the current
gdct ascii files.
We currently do several filter steps on the EDIF file generated by
CAPFAST, including name mangling, and doing that at dbLoadXxx time
would also slow rebooting.  As previously noted, flat files are much easier
to apply filters to, especially awk and sed type filters (which we use).
With an ASCII load, we could eliminate the last atdb step.
For these reasons, I'm in favour of supporting (yuck) more than
a single ascii format.  (I'd still wish for some way to move designs between
gdct and CAPFAST, but currently don't have the resources to solve that
problem here at CEBAF.)
I'm satisfied with the benchmarks already run, and am willing to have
the binary format dropped and support only the gdct ASCII format (with
dbLoad remaining for another release or two for backward compatibility).
Chip
Prev: Re: Ascii file formats and the use of EDIF winans
Next: CA WAN/gateway extensions notes watson
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: EPICS drivers for CAN and RS232 / TCP/IP Matthias Clausen DESY -MKV2/KRYK-
