<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Living on and on...
Date: Fri, 13 May 94 17:05:15 MDT
Paul writes
>I've been messing around with the little utilities from the
><epics>/share/src/toolsComm/ca directory and I've noticed that when I:
>	caget <recordname>
>If the recordname exists or does not exist the caget process will not die.
>The shell returns the prompt to me, but if I look at the process table, there
>caget sits.
>So I wrote my own caget which does the following:
>	ca_task_initialize()
>	ca_search()
>	ca_pend_io()
>	ca_get()
>	ca_clear_channel()
>	ca_task_exit()
>and I see the same behavior.
First off, I'm assuming your running on a workstation not an IOC.
Disregard the rest if this assumption is incorrect.  One could get
such results if there is not a CArepeater task running on the
workstation when you run a CA client.  In this case the
CArepeater task is initiated from your process and is named
whatever your process is named, i.e. caget, dm, etc.  While you're
running the process you can actually see two processes with the
same name.  When you exit, you'll see one process left.  It is
really the CArepeater.  To eliminate this problem, you can start this
task before you run CA clients--we add a line to run startCArepeater
when we boot our workstations so we don't have to deal with it.
By doing this, CArepeater runs as a process with its own name.  I
think Jeff is planning in a future release to have the CArepeater
get its own name as the process name even when initiated from another
process so this won't happen.
	Deb
Prev: Living on and on... Paul Banta
Next: Re: Limits on CA message size? John R. Winans
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Portability Pratik Gupta
