<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Xy240
Date: Mon, 22 Aug 94 09:45:03 PDT
I've been using the Xy240 with r3.11.  The .ascii file lines were not commented
out as cjm described but there was a bug in the file drvXy240.c that makes it so
that when you use particular bits (ie, bo records), the rest of the word will get
scrambled.  This file has been unchanged since at least 3.7.  I modified
xy_bo_driver() lines 346 and 347 to be:
        dio[card].dptr->port4_5 = (unsigned short)(work >> 16);
        dio[card].dptr->port6_7 = (unsigned short)work;
The lsw/msw positions of port4_5 and port6_7 were reversed with respect to the
rest of the driver.
I gather there is a move afoot to have fewer device drivers active in the release,
and this probably accounts for the ascii lines being commented out.
Carl Lionberger
Lawrence Berkeley Laboratory
Prev: Xy240 Chris Mayer
Next: returned mail for tech_talk Marty Kraimer
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Xy240 Chris Mayer
