<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: devLib, locationProbe routine
Date: Wed, 26 Oct 1994 14:41:25 BST
On Wed, 26 Oct 1994 08:36:30 -0600 Marty Kraimer wrote:
> > From [email protected] Wed Oct 26 08:21 CDT 1994
> > Am I right in thinking that the routine  locationProbe  in devlib returns
> > SUCCESS to indicate that the given address does *not* respond to VME
accesses of
> > any size?  I presume the aim here is to indicate that this area of the
memory
> > map is currently not used.
> No it returns success (0) only if something responds AND no one else has
> requested something from the rage of addresses requested. Thus ALL non 0
> returns values are errors.
That's not what my version (3.11.4) does - has anyone actually tested it?
->devAddressMap
value = 0 = 0x0
->locationProbe 1, 0x200000
value = 34144265 = 0x2090009
->*0xf0200000
_rsrv_free_clientQ + 0xef24fabc = 0xf0200000: value = -14204673 = 0xff2740ff =
_rsrv_free_clientQ + 0xfe2c3bbb
->locationProbe 2,0x80000000
value = 0 = 0x0
->*0x80000000
0x80000000: value =
Bus Error
Program Counter: 0x00053e1a
Status Register: 0x3000
Access Address : 0x80000000
(I have a card at A24:0x200000, none at A32:0x80000000, no addresses registered)
I presume from your description that a driver should call  locationProbe  before
calling  devRegisterAddress  which is probably reasonable (although it means
that devLib has to use  sysBusToLocalAdrs  twice and there is more work needed
in converting a driver).
- Andrew
          ,_}\_.        Andrew Johnson, Technology Division
         /      \       Royal Greenwich Observatory
~~~~~~~~| ,--/;. )~~~~  Madingley Road, Cambridge, UK
    .,  |/  (/  U       Phone: +44 (0)1223 374823
  .`., /_\ . .          Net: [email protected]
     wwWWWww'           WWW: http://cast0.ast.cam.ac.uk/~anj/
Prev: devLib, locationProbe routine Andrew Johnson
Next: Re: get_convert_table and DBF_STRING sources Marty Kraimer
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: devLib, locationProbe routine Marty Kraimer
