<19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: devLib, locationProbe routine
Date: Wed, 26 Oct 1994 13:19:11 BST
Am I right in thinking that the routine  locationProbe  in devlib returns
SUCCESS to indicate that the given address does *not* respond to VME accesses of
any size?  I presume the aim here is to indicate that this area of the memory
map is currently not used.
Should I be using this in my driver to check that a board is present?  The older
drivers use vxMemProbe, which returns OK if something responds.  It seems wrong
to expect an error code (S_dev_addressOverlap) as the status return indicating
success (ie board found), which is what I would have to do if I used the
locationProbe  routine.
Are there plans to modify the existing drivers to use the devLib facilities?
- Andrew
          ,_}\_.        Andrew Johnson, Technology Division
         /      \       Royal Greenwich Observatory
~~~~~~~~| ,--/;. )~~~~  Madingley Road, Cambridge, UK
    .,  |/  (/  U       Phone: +44 (0)1223 374823
  .`., /_\ . .          Net: [email protected]
     wwWWWww'           WWW: http://cast0.ast.cam.ac.uk/~anj/
Prev: get_convert_table and DBF_STRING sources mcgehee
Next: Re: devLib, locationProbe routine Andrew Johnson
Index: <19941995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: get_convert_table and DBF_STRING sources Marty Kraimer
