Subject: |
Re: NI VXIcpu-030 |
[email protected] (Jeff Hill) |
Date: |
Tue, 17 Jan 95 10:13:48 MST |
> When I run EPICS 3.11 on my National Instruments VXIcpu-030s, I get the message:
> VXI internal failure VXI resman: NI cpu030 init failed
> during iocInit time. The NI supplied resman (version 2.6.1) is started at boot
> time. There are no modules other than the VXIcpu-030 in the VXI crate. What
> does this message mean? What should I do about it?
This message results from the EPICS resource manager detecting that the NI
resource manager has already configured your NI VXIcpu-030 based system. When
this situation occurs the EPICS resource manager will exit early (without
modifying the system). Normally a single resource manager is responsible for
system configuration when a VXI system initializes.
The above message needs to be modified to indicate the cause of the problem
(and not just the symptom).
Many existing EPICS VXI drivers use calls in the EPICS VXI library that
rely on tables built by the EPICS VXI resource manager.
Jeff
______________________________________________________________________
Jeffrey O. Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos, NM 87545 USA FAX 505 665 5107
Re: TS - EAST from GMT Deb Kerstiens
Re: TS - EAST from GMT Andrew Johnson
<1995>
2025
2026
NI VXIcpu-030 Ric Claus
EPICS and Solaris 2.x greene%denali.UUCP
<1995>
2025
2026
